Author Topic: KVM built into Keyboard  (Read 6014 times)
Offline aernan
« on: Wed, 15 February 2017, 17:36:19 »
I have a possibly silly idea. Are there any keyboards that have two outputs with the a Keyboard Mouse switch directly into the keyboard?
Offline jal
  • I can't believe it's not gravy!
Re: KVM built into Keyboard
« Reply #1 on: Thu, 16 February 2017, 20:32:32 »
Never seen one. And it would still be missing the 'M', which is a bit problematic. I mean, I have done things with computers blind, but that was command line, and an absolute last resort.
Building in monitor support would (a) be really complex engineering - anything beyond VGA ranges from complex to very complex and high bandwidth, and modern standards like DP involve DRM, which means licensing.
And (b), that would be a really funky-looking, chunky keyboard. The heat-sinks could be fun decorative elements.
A while back I was considering the possibility of a self-bugging keyboard. Insert your own thumb drive, and have it record all your keystrokes as a last-ditch backup. That would require more than a Teensy offers.
« Reply #2 on: Fri, 17 February 2017, 07:04:28 »
i think they don't do it because of how many cables you'd end up with on the table.
« Reply #3 on: Fri, 17 February 2017, 07:24:46 »
What would be the purpose?
Many KVM switches allow switching between hosts using a key-combination, which allows you to have the switch out of the way. There is also software that acts as a virtual KVM switch but that requires of course that both machines are running.
Offline Leslieann
« Reply #4 on: Fri, 17 February 2017, 17:31:11 »
I would rather spend $200 on a cheap 4 port kvm and enjoy my nice keyboard than have 20 cables on my desk connected to a keyboard I had few choices on, and paid $1000 for.
KVMs are not cheap, especially with even  remotely newer technology in them, then add a cheap, over priced keyboard (they can't buy in bulk), and your $200 4port KVM just became a $1000 bit of equipment that eats cables (keyboards move around, which is bad for things like shielded DVI cables and such).
Remember, a 4 port KVM has a minimum of 15 cables attached, integrating the keyboard only saves you one cable, are you sure you want that on your desk?
Just buy a KVN with a key switch toggle and hide it under your desk, you will be much happier.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline MaNiFeX
  • Wu Tang Killa Keebs
    • MaNiFeX.net
« Reply #5 on: Mon, 20 February 2017, 00:58:49 »
Not exactly what you are looking for, but BAM: https://www.cybernetman.com/en/all-in-one-pc/keyboard-pc
