Author Topic: Maximum Brave ?  (Read 3972 times)
Maximum Brave ?
« on: Sat, 11 March 2017, 12:07:07 »
Tp4 has just finished popping the popcorn..
Walking upstairs with the unopened bag..
Then a late kernel popped in the bag,
---- Tp4 proceeds to yelp,
-----------dropped the bag,
-----------------and ran up the stairs behind the hallway for cover..
//Brave...
Think should probably go outside more,   This is getting ridiculous..
Re: Maximum Brave ?
« Reply #1 on: Sat, 11 March 2017, 12:09:08 »
.....I don't even know what to say
Re: Maximum Brave ?
« Reply #2 on: Sat, 11 March 2017, 12:10:04 »
idk.. in the moment,  it was more like, jesus Snipers...
Offline heedpantsnow
  • Old enough to know better
Re: Maximum Brave ?
« Reply #3 on: Sat, 11 March 2017, 12:15:19 »
Glad you made it out alive bro
I'm back.
Re: Maximum Brave ?
« Reply #4 on: Sat, 11 March 2017, 12:18:26 »
Come to the cabin, no snipers here
Re: Maximum Brave ?
« Reply #5 on: Sun, 12 March 2017, 20:18:11 »
Popcorn is mechanically problematic..
After you pop it, it becomes really big, approx 10:1 ratio in volume of the unpopped kernals..
This dramatically reduces the consumption efficiency. You're not eating alot of food.  Yet, it's time consuming because you can't put that many popped popcorns in the mouth at one time..
Perhaps we require some sort of Re-Compression technique to get to a more reasonable 3:1 or 4:1
Re: Maximum Brave ?
« Reply #6 on: Tue, 14 March 2017, 14:08:09 »
Got 23 unpopped kernals today..
This has been the worst ever..
My previous max was 17
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Maximum Brave ?
« Reply #7 on: Tue, 14 March 2017, 14:43:39 »
PAWPCAWRN
Re: Maximum Brave ?
« Reply #8 on: Wed, 15 March 2017, 21:04:52 »
And if they went off one by one it would sound like a machine gun.
Or fireworks.
Or just swallow the unpopped ones really quickly and see if they will pop in your stomach.
Offline nmur
  • ಠ_ಠ
Re: Maximum Brave ?
« Reply #9 on: Wed, 15 March 2017, 21:09:24 »
can't you just eat the popped kernels
then take the leftover unpopped kernels, put them aside
then the next time you have popcorn, do the same thing; add to the unpoppeds
eventually you will get a full serving of kernels
Offline Belfong
Re: Maximum Brave ?
« Reply #10 on: Wed, 15 March 2017, 21:13:12 »
how loud can a popcorn goes?
My faith in the church of tp4 is getting weaker by each post.
Re: Maximum Brave ?
« Reply #11 on: Wed, 15 March 2017, 21:20:03 »
The sound of popcorn is heavenly, *POP POP*
Offline unoab
Re: Maximum Brave ?
« Reply #12 on: Wed, 15 March 2017, 22:54:04 »
How about putting your popped kernels in a vacuum chamber, depressurize them, and then repressurize the chamber quickly.  You could probably repeat the process a few times as well and should then achieve a bowl of shriveled kernels that will probably resemble eating tiny nougats of chewy skin, ha ha.
Most people have seen this process done with marshmallows but the same should work for popped corn, unless the matrix/structures that encompass the air pockets are more resilient and can withstand the forces of being repressurized while air re-permeates back into them..
Re: Maximum Brave ?
« Reply #13 on: Wed, 15 March 2017, 22:58:20 »
Hrrrrrrrrrrrrm....
Tp4 doesn't own a vacuum chamber..
it's on my list of stuff to buy , right after Geiger counter.
Offline unoab
Re: Maximum Brave ?
« Reply #14 on: Wed, 15 March 2017, 23:10:07 »
I think a geiger counter would only fuel any paranoia you might have, I would push it further down the list.
Re: Maximum Brave ?
« Reply #15 on: Thu, 16 March 2017, 04:52:04 »
I've also got hydraulic press before geiger..  worry not .. hahahaha
Re: Maximum Brave ?
« Reply #16 on: Thu, 16 March 2017, 04:54:13 »
PAWPCAWRN
took me 2 days to recognize the trek here..
hahahahahhaa..
Chyros didn't stress the CAWRNNNNN  enuff...
