Author Topic: Much Ham  (Read 2612 times)
Much Ham
« on: Fri, 31 March 2017, 01:31:47 »
So Tp4 were @ the costco yesterday looking at the prosciutto and serrano..
Basically $150 for the whole big leg 15lbs.
Now,   is that way too much to buy ?   How long does it take to eat all that..
Quite like the flavor the times've tried it, but noticed it's quite salty..  Are --NORMAL-- (Non T-Rex) people able to finish this quantity in a reasonable amount of time, before spoilage ?
Offline steinerlein
Re: Much Ham
« Reply #1 on: Fri, 31 March 2017, 01:56:16 »
AFAIK it doesn't really go bad if you keep it dry enough..
And you  need a really sharp knife to cut really thin slices
Gesendet von meinem XT1572 mit Tapatalk
Re: Much Ham
« Reply #2 on: Fri, 31 March 2017, 02:41:18 »
I bet we could use that in a week in the summer out at the cottage. Wood fire pizzas.
Offline nugglets
Re: Much Ham
« Reply #3 on: Fri, 31 March 2017, 02:43:22 »
It's cured meat. As long as you aren't reckless, it will last a few months easily. Just slice off what you want to eat, because the slices won't last nearly as long as the whole.
As for how long it takes to eat all that, it really depends. In my family a whole leg would last a couple of weeks at the most.
Offline fanpeople
Re: Much Ham
« Reply #4 on: Fri, 31 March 2017, 04:02:59 »
Just hang it up on your front porch, it will last years. In fact wait at least 6 months before cutting it up for maximum flavour
Re: Much Ham
« Reply #5 on: Fri, 31 March 2017, 05:21:44 »
What about them attack birds..
I know I got a bunch of deers around these parts.. so.... idk, there could be bears ?
Offline fanpeople
Re: Much Ham
« Reply #6 on: Fri, 31 March 2017, 07:46:43 »
Just put up a sign next to your ham that says "no attack birds, deer or bears" that way they will know the ham is not for them.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Much Ham
« Reply #7 on: Fri, 31 March 2017, 08:31:43 »
All y'all with y'alls crazy wildlife. Do like we do, and kill them all. Then, ALL the ham is for you!
Offline digi
  • elite af tbh
  • keyboard game on fleek
Re: Much Ham
« Reply #8 on: Fri, 31 March 2017, 11:36:46 »
Let me tell you something right now, if you never experienced the deliciousness of fresh cut prosciutto off the leg with a pint of your fav and some cheese, you're not "lifing" correctly. Pull the trigger on that bad boy and invite your buddies over!
Re: Much Ham
« Reply #9 on: Fri, 31 March 2017, 13:13:48 »
idk why lockheed hasn't sold us auto turrets yet, I've always wanted auto turrets for home defense..
