Author Topic: Tp4 wants Nt-Cutter  (Read 3597 times)
Tp4 wants Nt-Cutter
« on: Mon, 10 April 2017, 18:59:22 »
But. Tp4 am afraid to try new things..
What ya'll think... Tp4 haz the Olfa right now.
Re: Tp4 wants Nt-Cutter
« Reply #1 on: Mon, 10 April 2017, 19:00:25 »
Speak English TP.
I ordered a nut milk bag today.
Offline nmur
  • ಠ_ಠ
« Reply #2 on: Mon, 10 April 2017, 19:05:04 »
« Reply #3 on: Mon, 10 April 2017, 19:10:03 »
Speak English TP.
hahaha..
make sure to get a large one, because the smaller ones you can't squeeze as easily, and the holes clog really fast..  so the larger the bag, the less you have to go in and clear out the swarf.
« Reply #4 on: Mon, 10 April 2017, 19:20:20 »
Speak English TP.
hahaha..
12" x 12"
Gonna use it to make some cold brew coffee.
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #5 on: Mon, 10 April 2017, 19:22:01 »
If there's one constant that will always be in my life, it's amusing tp4 OT threads on GH.  Bless.
« Reply #6 on: Mon, 10 April 2017, 19:35:20 »
Analogue Nt?
« Reply #7 on: Mon, 10 April 2017, 19:44:06 »
« Last Edit: Mon, 10 April 2017, 20:07:53 by SpAmRaY »
Offline fanpeople
« Reply #8 on: Mon, 10 April 2017, 19:44:55 »
Speak English TP.
« Reply #9 on: Mon, 10 April 2017, 20:06:42 »
even by tp standards, this is a ****ty post
« Reply #10 on: Mon, 10 April 2017, 20:08:25 »
« Reply #11 on: Mon, 10 April 2017, 20:40:57 »
Speak English TP.
I'm not sure you need this for cold brew unless you're planning on making gallons at a time ?
the reason is.. you'd be using coarse grinds for cold brew..  and they settle really fast to the bottom of the jar,  so if you just pour over a regular smaller filter,  only very little grinds will actually reach the lip of the vessel you're pouring out of..
I just use my regular stainless steel mesh sieve and it's only 3inches diameter round.  I would say this small sieve is enough to filter 5 to 10 liters of cold brew before being filled up
« Reply #12 on: Mon, 10 April 2017, 21:06:16 »
Speak English TP.
So long as I can clean it good enough I can also use this thing for yogurt etc.
Offline heedpantsnow
  • Old enough to know better
« Reply #13 on: Tue, 11 April 2017, 07:12:44 »
Speak English TP.
I use a paint strainer bag to make almond milk. Was $3.99 at Lowe's for 2!
Though I will say that it's hard to make almond milk for less than $3.50 (what a carton costs at the store) unless you have an exceptionally cheap source of almonds.
With cold brew, make sure you use a good grinder. Coarse grinding is the hardest for a grinder to do consistently.
I'm back.
« Reply #14 on: Tue, 11 April 2017, 07:23:43 »
I've got one of those Japanese hand grinders, it works good for the aeropress.
I'll just have to figure out how to change the settings on it.
Of course it doesn't do much at one time.
« Reply #15 on: Tue, 11 April 2017, 07:25:34 »
That will probably work
I'm back.
« Reply #16 on: Tue, 11 April 2017, 07:40:57 »
Is there a distinction between food plastic and paint strainer plastic ?
Offline fanpeople
« Reply #17 on: Tue, 11 April 2017, 07:44:29 »
Speak English TP.
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #18 on: Tue, 11 April 2017, 16:52:30 »
read the title and thought TP wanted a new Windows NT version, named "Cutter" :D
