Author Topic: What DPI/Sensitivity have you guys been using lately?  (Read 49149 times)
Offline Encabulator
« on: Sun, 30 April 2017, 21:48:54 »
It doesn't seem a thread has been made about this (at least lately.) I was somewhat curious what DPI/Windows sensitivity you all use for day to day use. Everywhere else I've seen this question asked it turns into an argument about what sensitivity is the best. I use windows sens 6/11 with 1200 dpi (steel series rival). I used to use 400 dpi when I played more games such as counter strike but I'm finding it more convenient to use a higher sensitivity for standard use. I don't know know how sensitivity functions with older mice so I'm sorry if this question doesn't cover any of you stone age mouse users  :p
relax bro.. no one will bite ur head off on geekhack.. this is not that kind of community...   hahahahahahaha
Though tp4 will personally chew you out if you start selling $60 orings.
Re: What DPI/Sensitivity have you guys been using lately?
« Reply #1 on: Sun, 30 April 2017, 21:54:14 »
10K DPI G900
Offline Encabulator
« Reply #3 on: Mon, 01 May 2017, 01:03:24 »
10K DPI G900
Blowing on your mouse would make it go all the way across the screen!
« Reply #4 on: Mon, 01 May 2017, 01:05:09 »
10K DPI G900
no if you haz a 4k monitor. hahahahah
//cry ,   tp4 = poor,  don't haz 4k monitor..
Offline Leslieann
« Reply #5 on: Mon, 01 May 2017, 04:50:28 »
I believe it's around 5800 DPI, with 1000mhz refresh.
Keep in mind though, in Linux, 5800 is equal to about 7400 in Windows.
However, I turn down the sensitivity in the OS to increase the precision and disable the OS acceleration, which ends up being about the same as using around 6500 at default settings in Windows.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline SBJ
  • Tactile pls
« Reply #6 on: Mon, 01 May 2017, 05:29:24 »
1600 dpi 1000hz
Offline bastones
« Reply #7 on: Mon, 01 May 2017, 06:06:30 »
1000 DPI, running Mac OS X. My mouse has a DPI button so I can adjust it between 600/1000/1600. Generally always have it at 1000.
Offline iLLucionist
  • Topre is Love.
« Reply #8 on: Mon, 01 May 2017, 06:37:02 »
I dunno if what I'm saying is true... but I've recently moved from the Avior 7000 (PWM 3310) to the G403 (PWM 3366) and I now use my mouse at LOWER sensitivity. It went back from 3200-3000 to 2400 for regular / drawing illustrator etc and for FPS / osu / aimbooster 1600.
I have the impression that giving large swings, going from left to right of the screen, I need lower dpi on the G403 for some reason. Like somehow the sensor picks up faster like "oh we swinging now? here we gooo". And yes, I have and had mouse smoothing / acceleration off.
Offline davkol
  •  Post Editing Timeout
« Reply #9 on: Mon, 01 May 2017, 07:53:23 »
The number (DPI) alone means nothing.
I have a 30" screen estate w/ 100 dpi. My mouse (w/ PWM 3310/3360) is set to 1200-1600 dpi, and there are no sensitivity/acceleration adjustments. Thus, I can cross the screen by moving the mouse ca. 5 cm. Meanwhile, my larger trackball (Kensington Slimblade) is stuck at 400 dpi, but I use software acceleration to cross the screen with a single flick.
I don't use MS Windows.
Offline Encabulator
« Reply #10 on: Mon, 01 May 2017, 08:28:30 »
10K DPI G900
I would be broke if I had were to buy a 4k monitor. It would have to be 144hz too, I can never go back to that choppy disgusting 60hz.
Offline iLLucionist
  • Topre is Love.
« Reply #11 on: Mon, 01 May 2017, 08:34:06 »
10K DPI G900
Well.. good news! 4k at 144hz only 2000 dollars for you sir!
I present to you the very toijt... the very fasha... the new Acer Predator X27 with local dimming, 4k, 144hz, ips, 4ms I guess:
Offline SBJ
  • Tactile pls
« Reply #12 on: Mon, 01 May 2017, 11:02:49 »
Holy smokes!
Both price and specs are beefy af.
Offline iLLucionist
  • Topre is Love.
« Reply #13 on: Mon, 01 May 2017, 11:31:21 »
Holy smokes!
Yeah in practice I don't really see the point of such screens. 1080 Ti already struggles keeping up 100+ Hz @ QHD with everything on ultra. So what's the point of these screens?
Offline davkol
« Reply #14 on: Mon, 01 May 2017, 11:51:47 »
Vendors want to make money, obviously. Specs on paper bring semi-informed customers.
Unfortunately, neither specs on paper, nor unboxing videos say anything about flicker and other quality/usability problems.
Offline kekstee
« Reply #15 on: Mon, 01 May 2017, 12:35:20 »
Just use the DPI that gives you a good result on the desktop starting at 6/11 in Windows.
I'm at 800DPI on 1440p. But I can imagine some would prefer 1200 at that size.
You could then adjust it in games if you want, but actually ~1.0 @800DPI happens to feel pretty good in CS, which is probably the game I'm most picky with my settings in.
Offline Leslieann
« Reply #16 on: Mon, 01 May 2017, 16:36:10 »
To a point, you are correct, however it's an easy way to compare.
Something to note, and this elaborates on my settings a bit.
Software acceleration is fine for general computing. While you cross one screen in 5cm, I cross dual 25in 1080p screens in less than half of your movement, and with (near) pixel level precision.  If I used the settings you do, I would see jumps of 5-7 pixels or more and that just leads to insanity inducing levels of frustration when doing photo or CAD work.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline SBJ
  • Tactile pls
« Reply #17 on: Tue, 02 May 2017, 03:10:29 »
I agree completely.
« Reply #18 on: Tue, 02 May 2017, 03:13:05 »
10K DPI G900
this thing is useless unless it can do the full ulmb at high brightness.  gotta evaluate its ulmb performance.. that's the key..
Offline iLLucionist
  • Topre is Love.
« Reply #19 on: Tue, 02 May 2017, 07:25:41 »
10K DPI G900
yess... it aint out yet so we cannot know for sure for now. I think ulmb will dissapoint. I have never seen a proper implementation so far. sounds more marketing to me. I mean perhaps they can turn out backlight locally, but you would still have ips glow that also makes black appear grey.
« Reply #20 on: Tue, 02 May 2017, 08:25:08 »
blacks appearing grey is ok for me, because as long as you have lighting behind the monitor, it compensates for the glow.
The greatest problem is ULMB..
ULMB requires very high brightness flashing whenever we turn down the persistence rate.   the shorter the flash, the more clear the Motion quality.
However, the shorter the flash, the less bright the image..
So that flash has to be super bright..   This is the main hold back..
An entire array of super bright leds plus driver are going to cost 3 to 400 and might require active cooling.
Offline ndumdr
  • Jung Wheein
« Reply #21 on: Thu, 04 May 2017, 15:37:12 »
I change it depends on what I'm doing, but usually when I just want to surf the interwebs I use 1500 dpi.
Offline digisax
« Reply #22 on: Fri, 05 May 2017, 20:28:58 »
I'm at 1200 or so on my G403 wireless and at stock on my trackball.
niu mini - R2 T1s, MT3 Dev/TTY
Offline daerid
    • Rossipedia
« Reply #23 on: Sun, 07 May 2017, 15:10:27 »
G900, G403, and G Pro all @ 800dpi on 3x24" 4K monitors
« Reply #24 on: Mon, 08 May 2017, 23:13:44 »
8k mouse
6k trackball
I use 2 23in monitors.
Offline woll3
    • ESL Profile
« Reply #25 on: Tue, 09 May 2017, 03:54:07 »
Well, thats because it does, and regardless of Device FW, 3310 has smoothing.
Offline Duckyreddy
  • Better skadoodle, poodle.
« Reply #26 on: Wed, 06 September 2017, 02:02:35 »
3K Mouse in browsing
800 in-game  :thumb:
Ducky One Cherry MX Silent Reds
Leopold FC660M MX Blue
Logitech G403/ Razer Naga 2014
Offline exitfire401
  • The Force is Re/\l
« Reply #27 on: Wed, 06 September 2017, 02:03:43 »
450 in shooters
1600 while browsing
1850 while in MOBA
G502 proteus spectrum
Offline Boskr
« Reply #28 on: Thu, 07 September 2017, 07:46:26 »
Have been using 800 DPI for as long as I can remember. Dead-middle on Windows sensitivity, as I've read that not having it right in the middle can make your mouse really inconsistent.
I have many friends that use insanely high DPIs because they think it's better, completely ignoring that the huge majority of pro FPS players use 400 or 800  :D :D
It's not that I want to be a pro or that I think I am one, but I've gotten comfortable using those settings and I definitely think low sens + big mousepad has improved my ability to play FPS games.
I'd probably use a bit higher if I played MOBA or RTS games, though. I'd also consider using a higher DPI when browsing, but I use a ZOWIE FK1+, and the DPI can't really be adjusted except when the mouse is just turning on, so I just roll with 800.
At work, I use a Logitech MX Master, but I've never installed the software for it, so whatever the default DPI on it is, I use that.
« Last Edit: Thu, 07 September 2017, 07:52:20 by Boskr »
Levinson split 40%, Gat Greens, DSA Blank
GH60, Cherry Browns, OEM Granite
Razer BWX TE, Gat Blacks+RGB, DSA Blank, No Logo (522 Solder Joints!!!)
Razer BWX TE, Razer Greens+RGB, All Stock (girlfriend's)
MagicForce 68, Cherry Reds, TaiHao Dasher
Corsair K70, Cherry Reds+RGB, Stock Caps
Ask me about Soldering/Assembly/Other services in NC!
Offline jackalopephoto
« Reply #29 on: Tue, 10 October 2017, 08:25:08 »
I have a Roccat Kone Pure that has a max 8200 DPI and I use 2400 dpi for gaming and 3200 dpi for other purposes. I can't even imagine the wrist and elbow strain people experience using low DPI
Offline rich1051414
« Reply #30 on: Thu, 12 October 2017, 13:48:39 »
9000 dpi, lowest sensitivity.
Offline Ceraon
« Reply #31 on: Mon, 16 October 2017, 16:57:20 »
For me the point of such a screen is that reading text on it, which is what I spend most of the time doing, for example coding or reading/writing e-mails, would be more pleasant.  My current mobile phone has 1440 x 2560 on a 5.3" screen and the text is always looks smooth and clear.  The same is not true of 1920x1080 on a 24" screen even at over 3' away.  Anti-aliasing helps but it is not perfect.
So for that, I am not especially interested in how quickly the screen refreshes or how fast things draw as long as the image persists sufficiently between refreshes that the whole screen does not appear to flicker that is fine.
Offline Ceraon
« Reply #32 on: Mon, 16 October 2017, 17:10:48 »
Back to the question I am trying a new trackball, a Kensington Orbit with Scroll Wheel and I have no idea what DPI it uses.
I am also not sure if it is as meaningful as people suppose.  Assuming the inch here is an inch of mouse movement on the desk, in the early days of mice the mouse would report one mickey of movement at the minimum distance the sensor could detect.  That means a mouse with a sensor that can detect smaller movements would report more mickeys for the same amount of movement on the desk, i.e. higher DPI.  That means if you can achieve the necessary precision with your fingers you should be able to move the pointer faster, because you are having to traverse less space on the desk, but with the same precision as before.  However, as soon as the marketing departments at the manufacturers find that people think higher DPI is better the people developing the product will be put under pressure to increase DPI without increasing cost and sooner or later someone will have the idea of just reporting 5 mickeys of movement for the smallest movement the sensor can detect and, if that mouse was previously 400 DPI, marketing it as 2000 DPI.  It would move the pointer at 5x the speed compared to the 400 dpi model but with only 1/5 of the precision and it would not be doing anything that could not be done in software on the PC.
Offline iLLucionist
  • Topre is Love.
« Reply #33 on: Wed, 18 October 2017, 15:48:10 »
Ever since I got my 3 monitor setup, I started to use the mouse less and less, so the need for dpi dropped. Whatever dpi I pick, swiping between leftmost and rightmost monitor is annoying. My dpi is currently 3000, and that is ok for moving around, but not for, for instance, drawing in illustrator.
I try to rely exclusively on keyboard for window navigation and arrangement, and only use mouse to click buttons in browser, and drawing mostly.
Offline maylily
    • Custom keyboard | Artisan keycap
« Reply #34 on: Sun, 22 October 2017, 00:09:24 »
i'm 800 both in CS:GO and working ( sometime working i'm up to 2000 )
Offline Shenpai
  • always found
    • padoru
« Reply #35 on: Wed, 15 November 2017, 18:04:54 »
1800 DPI @ QHD
Nunu | KR FC660C
Offline thearctican
« Reply #36 on: Thu, 16 November 2017, 08:50:54 »
I sit at 800 with no acceleration, and 6/11 in Windows. Mac OS I HAVE to turn off acceleration just because I've gotten so used to it.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #37 on: Thu, 16 November 2017, 18:14:51 »
800@1000hz
Offline lordgiblite
« Reply #39 on: Thu, 16 November 2017, 21:12:30 »
I usually run around 1800 dpi with a 2200 dpi quick toggle option. It's for the rare occasion I need more speed  ;)
Offline Shenpai
  • always found
    • padoru
« Reply #40 on: Fri, 17 November 2017, 00:09:56 »
1800 DPI @ QHD
QHD is soooo 2007..
It's all about 4k Now..
Hey shut your mouth, there's no 4K 144hz.... yet
Nunu | KR FC660C
« Reply #41 on: Fri, 17 November 2017, 01:09:30 »
1800 DPI @ QHD
QHD is soooo 2007..
QHD is garbage.. only poor people use QHD..
According to Noisy turtle, people can't even see 60fps.
Offline Shenpai
  • always found
    • padoru
« Reply #42 on: Fri, 17 November 2017, 01:18:26 »
1800 DPI @ QHD
QHD is soooo 2007..
Help I'm losing brain cells~
Nunu | KR FC660C
Offline Bucake
« Reply #43 on: Tue, 21 November 2017, 02:53:16 »
usually 800 at 6/11 windows sens, or 1800 at 4/11 windows sens :)
there are some exceptions - playing older 2D games for example which have a low resolution like 640x480, they're usually played better at ~400cpi
Offline dwarf.factory
  • Hi Im Dwarf!
    • Dwarf Factory
« Reply #44 on: Thu, 31 May 2018, 05:16:40 »
usually 400 DPI, 5/11 window sense. My mouse is Rival 300
My pure desire is GOLD
Offline Lansky
  • Realest motherthocker
« Reply #45 on: Thu, 31 May 2018, 06:23:44 »
Logitech G703 with 6/11 in Windows, acceleration on and 1400 DPI.
I use an eDPI of 910 in CSGO (still 1400 DPI, 0.65 sens, raw input on, acceleration off).
Offline rich1051414
« Reply #46 on: Fri, 01 June 2018, 01:48:03 »
Yeah, DPI + Sensitivity needs to be stated. Both effect pointer speed. One should favor a higher dpi and lower sensitivity until the speed is right, or actually, a sensitivity of '1' if it is allowed. This will reduce rounding errors from multiple software rounding stages.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #47 on: Fri, 01 June 2018, 10:47:58 »
Oh right. Minor changes:
800cpi/dpi@1000hz & 0.00 accel with xorg.conf.d/*.conf
Offline JianYang
« Reply #48 on: Fri, 01 June 2018, 11:28:45 »
Rounding errors should sum to zero over a long period - they use Bresenham's algorithm. But I agree with the sentiment - my sensitivity is always set to unity.
Offline JianYang
« Reply #49 on: Fri, 01 June 2018, 11:31:41 »
Your slimblade must be broken, cause both of mine is most definitely 800cpi. But that is also quite disappointing, since the sensors can do 2000. I have an urge every now and then to stick a teensy in at and unleash it's potential.
