Author Topic: Okay, here's the deal. I need to learn how to type....But how?  (Read 3196 times)
Offline Severe
  • HHKB Zealot
Here's the deal, all my keyboards have no letters on them, I can touch type easily but it's a bastardized version of touch typing, 5 fingers on the right hand and just my index on my left
How do i fix this god awful habit?
HHKB Pro 2 Black Lubed 55g
Logitech G502 (Gaming) Logitech MX Master 2 (Day to day)
Offline xondat
  • i'm not a star
Re: Okay, here's the deal. I need to learn how to type....But how?
« Reply #1 on: Sat, 06 May 2017, 12:08:23 »
Force yourself to use the "correct" fingers. You'll take a hit in typing speed, but it's the only way.
Offline Encabulator
« Reply #2 on: Sat, 06 May 2017, 12:10:19 »
I went from 1 finger on my right hand and 3 on my left hand to proper touch typing 100 wpm with https://www.typingclub.com and using 10fastfingers.com for practice. The trick is you have to have discipline. Nobody is going to stand behind you making sure you're using the right hand. If you want to improve you have to be devoted.
relax bro.. no one will bite ur head off on geekhack.. this is not that kind of community...   hahahahahahaha
Though tp4 will personally chew you out if you start selling $60 orings.
« Reply #3 on: Sat, 06 May 2017, 13:09:27 »
IMHO, typing doesn't truly require the  fjfjfjfjfjfj  jjjj ffff   type of practice..
What you really need is a key map on screen and some short words,
Then instead of looking at your hands,  just look at the sheet map, and FEEL for the letter with your hands without looking at your hands, LOOK at the keymap on screen..
This will be a simulation of what's happening for touch typing as you eventually develop the memory .   You're FEELING for the keys
fjfjfjfjfjfj  imho is going to make this process slower.   because instead of making the entire motion to the key, people just place their finger over the key they know is the right key,  and do ffff jjjj..  That's not the same feeling as moving to f or moving to j..
So they're fundamentally developing the wrong set of motions doing that type of practice.
« Reply #4 on: Sat, 06 May 2017, 19:14:56 »
When my kids were starting the teacher recommended a black handkerchief draped over the hands while typing.
Cheap, easy, and versatile.
- D Trump 2026-10-24
Offline Doluded
  • road to black star
« Reply #5 on: Sun, 07 May 2017, 22:01:53 »
https://www.reddit.com/r/MechanicalKeyboards/comments/5rzyd8/psa_to_those_who_dont_touch_type/?st=J2FJIXZ0&sh=f53445b2 I found this on Reddit a while ago and have it saved until I finally want to type correctly.
« Reply #6 on: Mon, 08 May 2017, 00:31:24 »
I changed to dvorak in order to learn to type correctly and it worked pretty well
If you can already touch type qwerty maybe using something colemak would be a good change.
« Reply #7 on: Mon, 08 May 2017, 07:54:12 »
//grinds teeth.....
//won't say nothin''   buh.. u knowwww.....   u knowwwwwwww.....
Offline Shapey Fiend
« Reply #8 on: Mon, 08 May 2017, 10:17:26 »
Use the correct positioning, play some sort of typing game (Typing of the Dead is a classic.. don't know how easy it is to find for PC now though) and don't look at the keyboard.
Offline OkinaDaikon
« Reply #9 on: Mon, 08 May 2017, 11:02:37 »
Yeah man I agree, Typing of the dead is a fun way to learn!
Forcing yourself not to look will pretty much do the trick. If you can't do that, put a small towel over your hands while you type so you can see the keyboard :)) [or go blank keycaps :) ]
« Reply #10 on: Mon, 08 May 2017, 12:13:04 »
If ya'll decide on typing of the dead..
MAKE SURE.. to type the SPACES as well..  the game doesn't require you to do it,  but it will not count it as a mistake either..
In order to ensure better meshing between your typing of the dead skills with NORMAL typing,  it's best that you type the space ..
Eventually, you will be so adept at typing/ typing games that it won't make a difference either way,  but this phase of initial training is important, because you want your base skills to be built as ~strong and ~correct as possible.
Another important thing is resting..   Don't play an hour a day.. that's over-training too much, and it will not improve your skills nearly as efficiently as 30 minutes a day..   which allows your background learning processes to encode into reflex memory.
