Author Topic: Artificially Inducing SPRING Wear  (Read 1988 times)
« on: Fri, 12 May 2017, 19:44:13 »
If we assume typical key wear works at 6 key presses per second.
so 50 million strokes for Cherry MX is,  2315 hours of key compression.. 96.45 days
If you take your mx keyboard, flip it over,  put some weights ontop, leave it fully compressed for 48.225 days, that's approximately Half the total length of compressions..
Does that make any sense?   Could we artificially induce spring wear this way ?
Re: Artificially Inducing Key Wear
« Reply #1 on: Fri, 12 May 2017, 19:49:09 »
I guess we could do some under the curve calcuations.. but then we would need experimental data on rate of key acceleration for both up and down stroke..
Re: Artificially Inducing SPRING Wear
« Reply #2 on: Fri, 12 May 2017, 20:36:15 »
Expected spring clothing......
« Reply #3 on: Fri, 12 May 2017, 20:37:37 »
Pretty sure on geekhack,  it's hoody or t-shirt year round..
« Reply #4 on: Fri, 12 May 2017, 20:39:19 »
Tanks year round
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #5 on: Sat, 13 May 2017, 18:53:17 »
Is there any evidence for the existence of helical spring wear in keyboard switches?
The primary documented (but not conclusively understood) wear is that of the plastic parts, but thin leaf contacts such as those in Futaba keyboards can also fail and need reshaping. With use, bounce time and contact resistance increases, and eventually this will go out of tolerance. With Cherry switches, chatter is the main mode of failure but that tends to be issues with new and comparatively young keyboards, not something I can recall being found in vintage examples. Generally, either the contacts stop working correctly, or the switch just feels bad, but to what extent if any do switches lose their spring strength?
Besides, surely weakening the spring by keeping it pressed is a wholly different issue to degradation from repeat compressions.
The awkward issue with failure is the simple question: do we only ever buy old keyboards that have not yet failed? That is, if a keyboard does see failure, is it discarded instead of sold on? This applies to not just the switches but keycap printing, leading if so to a false impression of failure rates and a false understanding of failure modes.
Bore Awards
