Author Topic: Post Your Monitor Backlight Hours  (Read 19998 times)
« on: Fri, 14 July 2017, 16:11:36 »
I'm running 2 24" Dell U2410 monitors
The left one is at 11656 hours and the right one at 11539 hours.
Looking back at when I received these and accounting for holidays, vacations etc, I have averaged ~11hrs a day on them.  :)) 8)
Offline Leslieann
Re: Post Your Monitor Backlight Hours
« Reply #1 on: Fri, 14 July 2017, 21:48:44 »
23105 and 22686
I got them probably about 6 years ago.
I refuse to dignify them with saying what they are other than dual 25in. 1080p.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #2 on: Fri, 14 July 2017, 22:09:43 »
I don't want to post mine, it's embarrassing, because it's an awful number which exclaims how Tp4 has wasted and is continuing to waste his life in front of the PC.
« Reply #3 on: Sun, 16 July 2017, 21:53:53 »
How do you find this information?
« Reply #4 on: Sun, 16 July 2017, 21:59:40 »
On my dell monitors you have to start them in service mode the process for which you can typically find by googling.
Some monitors may have this information in the standard menu, not sure otherwise.
Offline Leslieann
« Reply #5 on: Sun, 16 July 2017, 22:19:11 »
On mine it was simply in the monitor menu under information.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #6 on: Thu, 17 May 2018, 15:31:36 »
An old Cheepie monitor.
It was super budget back in the day ~$200 in 2011
The spec sheet says 300cd brightness..
I just tested it today, 60cd maximum, even after warm-up
24,388 hours.
Doubt it could do 300cd when new.. But 60cd def shows its age...
« Reply #7 on: Sat, 19 May 2018, 08:33:30 »
Just checked my one and only HP LP2065 which I've had since I got back from uni 12 years pretty much to the day ago - 11792 backlight hours.  That means I've only wasted about 11% of my life sat in this chair :))
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #8 on: Sun, 20 May 2018, 12:17:37 »
AFAIK there is no easy way to pull the hours from my monitor (AOC E2070SWN). But, pen/paper/calculator says somewhere between 18,600-23,360hrs
« Reply #9 on: Sun, 20 May 2018, 13:16:39 »
U lie mertx, u no use AOC E2070SWN..  u use dat 4k
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #10 on: Sun, 20 May 2018, 13:22:16 »
 :eek: so that's why my math was off..
« Reply #11 on: Sun, 20 May 2018, 13:26:23 »
chk out dis spec: AOC E2070SWN
20000000:1 (dynamic contrast ratio)..
hahahahahaha..
If max brightness is 200cd,  then its black point is 0.0001cd
They used Alien technology to build dis monitor ..
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #12 on: Sun, 20 May 2018, 13:39:18 »
hahahahahaha..
Yea buddy! That's way better then 600:1
« Reply #13 on: Sun, 20 May 2018, 23:16:15 »
How would you ever know this information?
oh, someone asked this... seems like too much work.
Offline Leslieann
« Reply #14 on: Mon, 21 May 2018, 03:51:30 »
Yeah, pressing two buttons is hard.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline JP
« Reply #15 on: Mon, 21 May 2018, 07:23:48 »
I went looking for this info until I realized that mine is led  :))
About Me | The Collection
« Reply #16 on: Mon, 21 May 2018, 07:25:48 »
??  lcds have either ccfl or led backlit hour..    led degrade just like ccfl,  which is why monitors keep an hour count.
Offline JP
« Reply #17 on: Mon, 21 May 2018, 13:37:53 »
Hmm, In that case I may look again as I did not see any similar information from my monitors menu.
Offline typo
« Reply #18 on: Thu, 21 June 2018, 22:19:17 »
Finally new Eizo CG3145 came tonight. If you do not know google it. 50 grand monitor lol. Tools of the trade. By the first time I checked it, it had 2 minutes 27 seconds. Of course they test this but they reset it before it leaves the factory. The picture on this is unreal. Kind of expected. Ready for a not joke Borat? This is not a cheap display HAHA.
« Reply #19 on: Thu, 21 June 2018, 22:38:33 »
I don't understand how it produces 0.001cd black level on IPS ??
-edit- oh i see..  it's using dat super -future tech panasonic panel with per-pixel light adjustment.
What it is , is an IPS panel, overlayed ontop of a TN panel.
The TN panel controls the brightness per pixel,  and the IPS controlls the color..
Dis is the FUTURE..
$31,000
Hrrrrmmm... should hit general consumer market ~ 5-7 years..  Sooner if Samsung joins the race..
« Reply #20 on: Fri, 22 June 2018, 07:19:56 »
Hrrrrmm.. now that I think about it.. TN itself can not go down to 0.001..
Which means both the TN and IPS must work in conjunction to get that 1m to 1 contrast ratio..
Amazing stuff.. !!
« Reply #21 on: Fri, 22 June 2018, 11:55:39 »
Hrrrm..  It might actually be Ips over Ips,  because if it had ips over tn,  then that reduces lag, but then the contrast uniformity would be much worse.
Theoretically, an even superior panel could be ips over ips over ips..   But that would raise backlight requirement even higher to the point of wasteful..
Offline typo
« Reply #22 on: Fri, 22 June 2018, 20:48:38 »
I think it is AH-ips over S-ips? I know I indulge but I use this to work. Be kind of stupid to get this for gaming lol. Especially since the lag is bad. Good luck get it for $31k. We paid just over 50. Now it has 17 hours 21 minutes lol.
« Reply #23 on: Fri, 22 June 2018, 21:22:48 »
I think the lag is probably due to the high bit LUT..
