Author Topic: Dehydrators  (Read 2468 times)
Offline digi
  • elite af tbh
  • keyboard game on fleek
Dehydrators
« on: Tue, 03 October 2017, 17:16:56 »
Thinking about getting a dehydrator to make jerky, I have lots of meats I need to get creative with. Anyone make their own jerky here?
Re: Dehydrators
« Reply #1 on: Tue, 03 October 2017, 17:27:50 »
I have done it, pretty simple. Come up with a good seasoning mix. Soy sauce first, then dry rub is a good start.
Slice meat with the grain, not against, otherwise it will crumble.
- D Trump 2026-10-24
Re: Dehydrators
« Reply #2 on: Tue, 03 October 2017, 17:40:46 »
DIY
All it is,   is  a fan,  a heating coil,  and an enclosed food rack..
Use a furnace filter behind the fan to reduce dust..
Easiest way, I could think of is...  A cardboard box, or wooden crate + space heater + box fan + furnace filters.
Offline AuthenticDanger
Re: Dehydrators
« Reply #3 on: Tue, 03 October 2017, 17:50:01 »
Just use a box fan:
http://www.instructables.com/id/Box-Fan-Jerky/
I've done it and it's pretty easy. You don't want to heat the meat. You want it to remain COOL while you remove moisture.
F Keys belong on the left.
Re: Dehydrators
« Reply #4 on: Tue, 03 October 2017, 17:55:09 »
Just use a box fan:
it depends on where u live..
if you're in the cold, as in right now, it's winter,  you're gonna need some heat, otherwise it'd take forever..
Re: Dehydrators
« Reply #5 on: Tue, 03 October 2017, 17:59:32 »
Just use a box fan:
It seems that most people think you need heat to make jerky. I just wanted to communicate that you want the meat to stay cool, and not cook it while you dry it.
