Author Topic: Yo guys, Belts !!  (Read 5605 times)
Yo guys, Belts !!
« on: Wed, 07 February 2018, 23:45:02 »
So,  Tp4 puts on pants..  And adjust the belt, Everything's fine..
but, then Sits in the computer chair, and suddenly the belt is too tight.
There's no real middle ground..
Even with elastic pants,  like sweat pants,  Haz wear the elastic part slightly above Hip level, so that it doesn't apply pressure to the stomach while seated.
Has Anyone found a solution to this problem..
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Yo guys, Belts !!
« Reply #1 on: Thu, 08 February 2018, 01:07:28 »
Only if I've eaten too much :p .
Offline ghostjuggernaut
« Reply #2 on: Thu, 08 February 2018, 03:07:40 »
I think things become compacted when you sit down, which causes the belt to constrict on you.
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #3 on: Thu, 08 February 2018, 03:12:47 »
Just wear yoga pants.
Online fanpeople
« Reply #4 on: Thu, 08 February 2018, 04:04:29 »
Dont wear pants. No pants, no problem.
Offline AMongoose
  • happy workman user
« Reply #5 on: Thu, 08 February 2018, 07:25:03 »
Get one of those belts that has two rings and is adjustable to any length not just set steps.
A thinner narrower belt that's not very stiff also helps but then it's worse at being a belt. How much stuff do you carry in your pockets?
The type of pant's your using and what you had for lunch also pays an important role.
Biggest problem to fabric belts is they don't go too well can't be worn with shirts, I like the winter just because I can wear a more comfortable belt to sit in the office all day with it being covered.
Also, do people not doing sports actually use elastic pants!?
Offline futurecrime
  • Get Zooted
« Reply #6 on: Thu, 08 February 2018, 08:11:21 »
Undo your belt when you sit down.
« Reply #7 on: Thu, 08 February 2018, 12:17:20 »
I understand the mechanics..
But is this socially acceptable?
Offline futurecrime
  • Get Zooted
« Reply #8 on: Thu, 08 February 2018, 12:20:08 »
Just be discreet.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #9 on: Thu, 08 February 2018, 13:39:04 »
If you need the belt to actually hold pants up, so not get the ones with two rings. The belts are rarely stuff enough with the right texture to stay where you put them.
This is what I wear, I have had it almost 14 years. If you need to loosen it a touch, just a bit of pressure with your thumb from the underside is all that is needed. It doesn't slip, and does not have set points. You can put it where ever you want
188408-0
Offline MKULTRA
  • telling it how it is
« Reply #10 on: Thu, 08 February 2018, 14:36:39 »
suspenders
Offline AMongoose
« Reply #11 on: Fri, 09 February 2018, 09:17:27 »
Yeah, if you carry lots of stuff I would suggest a stiffer belt, but for comfort i would say a thin double ring that can slide and open a bit is better.
Offline Melvang
« Reply #12 on: Fri, 09 February 2018, 10:09:47 »
Your mileage may have been differ by than mine, but I have yet to find a belt with two ring retention that holds up anything. The concept works, but material selection is the killer.. Because there is no hard edge or texture on the rings, there isn't much to grab and hold.
Offline AMongoose
« Reply #13 on: Fri, 09 February 2018, 10:21:11 »
That's what I'm saying, they don't hold much.
I was recommending them for comfort only, I see the fact that they slide and open a bit has a feature not a downside.
the only thing I carry with on my pants pocket is a small knife, pants stay mostly put even without a belt. but if one carries a lot of gear I totally agree with you.
« Reply #14 on: Mon, 12 February 2018, 19:54:15 »
Get elastic belt.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #15 on: Tue, 13 February 2018, 11:29:55 »
I wear a web belt like many militaries around the world do. Adjustable to any size and quite comfortable as well. I had one as a Marine ROTC and still wear one now. I had this one:
And wear this one now:
Online fanpeople
« Reply #16 on: Wed, 14 February 2018, 04:02:12 »
Holy **** you just past blasted me with that skatey belt
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #17 on: Thu, 15 February 2018, 03:55:20 »
I wear a 20 year old Dragon web belt (similar to the volcom belt). It even has a bottle opener built in. It is the only way to go.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #18 on: Thu, 15 February 2018, 08:24:04 »
Ha, the Volcom belt has a bottle opener too!
Offline Volucris
  • beep boop
« Reply #19 on: Thu, 15 February 2018, 22:27:34 »
Gotta wear your belt higher. Been using an Area Ranger Belt for years and it holds up a pistol and extra mag very comfortably.
KUL ES-87 - MX Browns
Offline eksuen
  • Ambassador of explosions.
« Reply #20 on: Fri, 16 February 2018, 15:46:07 »
Double D-ring belts do not stay put. There are good friction lock belts that are "infinitely adjustable" out there. I wear the Cinchy from Carbon Tactics with tactical nylon and it works great. I was worried it would be too stiff and uncomfortable, but I've found the stiffness to be useful for clipping on a pocket knife.
Offline ander
  • I type, therefore I am
« Reply #21 on: Sun, 18 February 2018, 02:37:18 »
