Author Topic: How do you store your key caps sets?  (Read 23831 times)
Offline phinix
« on: Fri, 16 February 2018, 12:45:25 »
When not mounted n your keyboards, how do you store your keycap sets?
In special boxes? Bags?
I wish there were special caps trays we could use, like with mx stems, so we could stick each cap in it and store this way...
Offline Visionaire
Re: How do you store your key caps sets?
« Reply #1 on: Fri, 16 February 2018, 13:25:47 »
While they're not exactly cheap, you can buy these:
https://originative.co/products/keycap-tray
Offline eksuen
  • Ambassador of explosions.
« Reply #2 on: Fri, 16 February 2018, 15:30:13 »
Most of my sets are GMK, so I just keep them in their trays. The rest are in plastic bags. All of the trays and bags then go into a big plastic bin.
Offline phorx
  • ¯\_(ツ)_/¯
Offline seville57
« Reply #4 on: Sun, 18 February 2018, 03:03:38 »
Like this:
Sometimes in plastic bags.
Offline os
    • trash site, don't come here
« Reply #5 on: Sun, 18 February 2018, 03:08:55 »
« Reply #6 on: Sun, 18 February 2018, 13:28:07 »
bags in a drawer
« Reply #7 on: Mon, 19 February 2018, 19:53:36 »
To say this topic comes up regularly would be an understatement!
After a quick search, I found a few links, copied here for posterity.
Happy reading! :D
Offline Deefenestrate
« Reply #8 on: Wed, 21 February 2018, 08:43:24 »
https://www.originative.co/
Couldn’t find them there - site looks whacked.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #9 on: Wed, 21 February 2018, 09:46:39 »
Drona boxes for Kallax cupboards.
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #10 on: Wed, 28 February 2018, 20:55:46 »
You're looking for originativeco.com
On these
« Reply #11 on: Thu, 01 March 2018, 19:49:36 »
On these
I'd never have the patience to put mine on one of those :))
  • (⌐■_■)⊃━☆゚.*・。゚
Re: HoWHen o you store your key caps sets?
« Reply #12 on: Thu, 01 March 2018, 20:00:36 »
On these
It's not so bad. When you take them off of a board, you put them on there. Or when you get a set from /r/mm, and you organize them to make sure you've got everything, you throw 'em on. ehh
« Reply #13 on: Thu, 01 March 2018, 20:06:57 »
On these
a lot better than the floor method i've used in the past
Offline KPrepublic
    • KPrepublic
« Reply #14 on: Fri, 02 March 2018, 02:31:19 »
store like this
190144-0
Or like this :)
190146-1
Offline captsis
  • Formerly matt2dlg
« Reply #15 on: Fri, 02 March 2018, 03:06:31 »
Labeled ziplocks put in storage bins on a shelf. looking into those trays though, I have a few that came with sets and if I have one ill use it. Looks a lot nicer
Offline a_ak57
« Reply #16 on: Thu, 08 March 2018, 00:23:27 »
I just keep them in the original packaging (i.e. the trays for GMK, bags for SP, etc).  Then I throw all those into a cardboard box.
Offline ojrask
  • juuh elikkäs
« Reply #17 on: Thu, 08 March 2018, 08:47:36 »
Mine are in the cardboard boxes they came with in the mail. Inside the boxes there are either the bags or trays or whatever they sit in.
Need to find some better storage method, maybe just plastic cases with names taped on them. Would be nice to buy some glass jars to display the nice colorways in.
Current:
Coming up:
IC/GB:
« Reply #18 on: Thu, 08 March 2018, 15:10:59 »
Yup. I just got mine in a bag.. nothing fancy..  no one looks at them.. not even me.
Offline captsis
  • Formerly matt2dlg
« Reply #19 on: Thu, 08 March 2018, 20:06:17 »
Sometimes I get really down when I think about how many sets I have but dont use. Just sitting in a box, waiting to be sold or traded :/
Offline yqliang
« Reply #20 on: Thu, 08 March 2018, 22:34:05 »
On these
Did not know these existed. I will probably get some. Thanks.
Nightfox Zealios 65g | Input Club K-Type Halo True | CM Masterkeys Pro S MX Brown x Norbauer Case | SA Carbon | SA Hyperfuse | XDA MiTo Godspeed | DSA K Bares Miami Dolch | ePBT WoB
Want: Satisfaction 75 | Space65 | GMK Dot
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #21 on: Sun, 11 March 2018, 15:23:49 »
On these
Definitely recommend them. Much nicer than storing them in bags, in a drawer. I have my unused sets on display on a book shelf.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #22 on: Mon, 12 March 2018, 15:23:06 »
Alternatively instead of buying one of those trays, why not an actual keyboard?
https://item.taobao.com/item.htm?spm=a230r.1.14.28.32661c9efXUtTJ&id=561628837463&ns=1&abbucket=5#detail
Offline BWLR
  • bowler caps
    • bowler caps
« Reply #23 on: Tue, 14 January 2020, 08:58:38 »
On these
Whatever happened to these? I can't find them anywhere online?
Offline phinix
« Reply #24 on: Tue, 14 January 2020, 10:28:54 »
Offline BWLR
  • bowler caps
    • bowler caps
« Reply #25 on: Tue, 14 January 2020, 10:34:26 »
Aha, I couldn't find them on the site for some reason. I just asked about it on the 1up discord too and they say that EnjoyPBT no longer use/produce those trays. Shame.
Offline OtherBarry1992
« Reply #26 on: Thu, 16 January 2020, 08:08:19 »
I have a GMK Skeletor Set that didn't come with a case so unfortunately they're in a bag :(
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #27 on: Tue, 21 January 2020, 09:38:51 »
Idk.. put them on my keeb?
Just my thoughts
Offline phinix
« Reply #28 on: Tue, 21 January 2020, 09:53:03 »
Do you have enough keebs to take all the caps sets you have?
Offline Steezus
  • Keeper of Facts
« Reply #29 on: Tue, 21 January 2020, 12:09:45 »
I try to typically keep a 1/1 ratio of keysets to keyboards/builds. That still does not remotely solve the issue because there is always an abundance of extra keys that aren't being used. I just keep the extras in labeled plastic bags and then throw them all in a storage container.
Offline Ckeeb
  • Meet ZOOM64 Keyboard!
    • MELETRIX
« Reply #30 on: Thu, 06 February 2020, 22:07:09 »
What about this (69RMB/10 USD, not including shipping)
OEM/SA/DSA
https://detail.1688.com/offer/589807254735.html?spm=a26352.13672862.offerlist.59.5e912b4dZrNPy7
Offline phinix
« Reply #31 on: Fri, 07 February 2020, 01:52:22 »
Well, I order 5 of those JTK boxes that are now on sale on Drop.
I picked Max version - these will be enough to take two TKL sets. Also, Max can take high profile caps, like SA, which is majority of my collection.
Once they arrive in April, I shall post photos how my caps land in them :)
Offline bananasplit_00
« Reply #32 on: Fri, 07 February 2020, 02:11:33 »
Thai food boxes and ziplock bags in a place that sees no light is my way. Is it ideal? nah. Does it work? yep.
« Reply #33 on: Fri, 07 February 2020, 15:25:12 »
In Zip-Loc bags shoved into a box shoved into a closet somewhere.
« Reply #34 on: Wed, 04 March 2020, 19:52:27 »
In a box :( but I'm going to be picking up some trays soon
Offline phinix
« Reply #35 on: Thu, 05 March 2020, 03:04:18 »
I'm hoping those JTK boxes arrive next month.
I will be able to move all my sets in those.
Will show pics here:)
Offline thelaughingman
  • Simultaneously the most starry-eyed idealist and t
« Reply #36 on: Sat, 07 March 2020, 05:02:55 »
you mean these?  :cool: :cool: :cool:
237212-0237214-1
Offline phinix
« Reply #37 on: Sat, 07 March 2020, 13:07:22 »
Yep, these. Should be delivered April.
