Author Topic: Underwater Toast [Paging Chyros]  (Read 6374 times)
« on: Fri, 23 March 2018, 09:08:21 »
Yo Chyros,
If you put bread under Super Heated water 350C in one of those pressure vessels.
Will it toast ?
Does it require oxygen and other gasses ?  what if the toast is floating in the space above the super heated water *still inside the vessel*
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Underwater Toast [Paging Chyros]
« Reply #1 on: Fri, 23 March 2018, 09:45:29 »
I'm having difficulty imagining the setup, and I'm not completely sure about your definition of "toast", but if you mean that the bread acquires that characteristic brown colour and flavour, you do not need oxygen, as this process is a result of intramolecular reactions and not molecular oxidation.
I suspect that at 350 C it might take a while because a toaster gets considerably hotter than that.
« Reply #2 on: Fri, 23 March 2018, 10:10:10 »
Hrmm
does super heating vessels have to be clean except for the water inside ?
Or would the introduction of the bread make it unstable..
« Reply #3 on: Fri, 23 March 2018, 11:15:08 »
Now I actually want to know if a toaster would work in a zero-oxygen environment. I don't see why not, but the act of burning something in that way may actually require oxygen.
Offline chyros
  • a.k.a. Thomas
« Reply #4 on: Fri, 23 March 2018, 13:22:50 »
Hrmm
Wait, you want the bread actually INSIDE the thing?
« Reply #5 on: Fri, 23 March 2018, 13:27:04 »
Hrmm
So take the bread, put it in the distilled water,  ALL inside the super-heating vessel..
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
« Reply #6 on: Fri, 23 March 2018, 13:40:07 »
You don't need oxygen to make toast, because heat doesn't require oxygen to radiate. But you can't do it in water. Toasting bread removes the moisture, it's a key part of the process, if you put toast in super heated water you would just be cooking the bread. You would end up with either gross milky bread water, or disgusting cooked, soaked bread.
« Reply #7 on: Fri, 23 March 2018, 13:46:44 »
Hrrmm.. i suppose we need to define the Toast part more carefully.
My query is more specifically,  will the toast turn brown/blackish when sealed in along with super heated water @ 350 C.
Offline emenelopee
  • *klomp klomp klomp* I step on your house 🦖
« Reply #8 on: Fri, 23 March 2018, 13:47:23 »
Wait, toasting is not an oxidation process?
Also bread is already cooked. Making it wet and hot would make a bread-y soup.
« Reply #9 on: Fri, 23 March 2018, 13:48:25 »
The question here is,  will it be Brownish/black soup, or Beige soup..
« Reply #10 on: Fri, 23 March 2018, 14:17:43 »
Nah, toasting food is not the same thing as making toast, and making toast isn't an oxidation process. And a lot of the ingredients you cook with are already cooked, you can still cook them again.
Offline chyros
  • a.k.a. Thomas
« Reply #11 on: Fri, 23 March 2018, 14:28:53 »
No, it's an amino acid reaction known as the Maillard process: https://en.wikipedia.org/wiki/Maillard_reaction .
Offline emenelopee
« Reply #12 on: Fri, 23 March 2018, 14:33:17 »
Well colour me educated, I have learned something today.
Also: Bread Soup:
« Last Edit: Fri, 23 March 2018, 14:34:52 by emenelopee »
« Reply #13 on: Fri, 23 March 2018, 14:43:53 »
Also: Bread Soup:
Oohh, and Bread Pudding! A personal favorite!
« Reply #14 on: Fri, 23 March 2018, 14:48:42 »
You could easily do a water extraction method to separate the bread molecules into a much purer form, but it would need to be done in ice cold water not hot water. Getting the bread wet and breaking down it's structure does not in any way mean you cannot reform it into a more pure bread.
« Reply #15 on: Fri, 23 March 2018, 15:04:50 »
Here's how I'd imagine this would be done..
ASSSUMING the bread COULD brown in the super heated water..
You'd DO THAT,
Then freeze dry the bread..
You would end up with what's essentially just toast. .
Offline emenelopee
« Reply #16 on: Fri, 23 March 2018, 15:17:53 »
I'm sure reconstituted superheated then freeze-dried bread is as delicious as it sounds, but, and this is just a thought, have you tried a toaster?
« Reply #17 on: Fri, 23 March 2018, 15:20:24 »
That's no fun.. !!
Which would you rather have,  Microwave smores, or Campfire smores, OR Volcano Smores..
« Reply #18 on: Fri, 23 March 2018, 15:30:55 »
you cannot make s'mores in a microwave, no matter what lies you've heard
Offline emenelopee
« Reply #19 on: Fri, 23 March 2018, 15:42:19 »
I like my smores blended with beet juice as the liquid base.
« Reply #20 on: Fri, 23 March 2018, 16:16:16 »
You would probably end up with a ****ty psuedo-bagel. It wouldn't be toast. The closest you could come would be some sort of sous vide process, but the bread 'pouch' would need to be some sort of high temp poly or a metal; congratulations, you just made a toaster that is more expensive, and less functional than this: https://www.amazon.com/dp/B00N8XFFDI/ref=psdc_289938_t2_B0015XGNEI
« Reply #21 on: Fri, 23 March 2018, 17:11:32 »
Ugh, TP: Church of Halverson Science and Research Branch
« Reply #22 on: Fri, 23 March 2018, 17:47:27 »
Here you go TP4, a toaster that uses water....
https://www.wired.com/2016/10/review-balmuda-toaster/
« Reply #23 on: Fri, 23 March 2018, 17:55:25 »
Just today, Tp4 is testing pureed celery Leaves and Orange peels.. BOILED in water..
About to drink it right now..   Hope I don't get Assplosion.. !!
Offline chyros
  • a.k.a. Thomas
« Reply #24 on: Sat, 24 March 2018, 04:46:51 »
This thread is hurting my science gland.
« Reply #25 on: Sat, 24 March 2018, 07:59:15 »
But the main mystery remains unsolved chyros. !!
Offline chyros
  • a.k.a. Thomas
« Reply #26 on: Sat, 24 March 2018, 09:16:07 »
It will not "toast". Toasting involves the material becoming crispy. Putting bread in water makes it soggy.
« Reply #27 on: Sat, 24 March 2018, 09:19:48 »
Right, but will it brown in the super heated water ?
If that can happen,  and then we freeze dry it afterwards,  it's --essentially-- like toast.
Offline chyros
  • a.k.a. Thomas
« Reply #28 on: Sat, 24 March 2018, 12:15:30 »
Yes, it should still brown, although the temperature might not be ideal.
Also, freeze-dried toast doesn't sound great, either.
« Reply #29 on: Sat, 24 March 2018, 16:04:50 »
I regret ever being a part of this discussion. I knew better. I am sad that blocking TP4 does not stop his posts from appearing when I browse the forum.
« Reply #30 on: Sat, 24 March 2018, 16:53:55 »
Muahahahahhahahahaha
