Author Topic: When's your next 'Puter upgrade ??  (Read 3842 times)
« on: Sat, 24 March 2018, 20:07:29 »
Tp4 will probably update at least 1x computer next yr because of meltdown/spectre..
But Overall,  Probably a large overhaul in 10yrs..
Offline mike52787
  • Alps Aficionado
Re: When's your next 'Puter upgrade ??
« Reply #1 on: Sat, 24 March 2018, 20:32:59 »
hopefully not for a few years, supposing my aging and bought used hardware doesnt fail. maybe some more ram when prices come down to earth.
Offline xondat
  • i'm not a star
« Reply #2 on: Sat, 24 March 2018, 20:34:29 »
Partial upgrades will be more hard drives, and then (if the prices come down) I'd love to do a dual GPU setup for ALL THE FPS :))
After those... Years I hope.
« Reply #3 on: Sat, 24 March 2018, 20:40:28 »
New processor and mobo. I literally cannot upgrade my cpu w/o getting a new mobo (and literally cannot upgrade my GPU w/o upgrading either of those... which means I'd need a new PSU as well) so it's got to be a double shot.
Basically I need a new computer, except for storage and memory. Current setup should last another 1-2 years though, so priorities come first and a new computer is like at the bottom of my priority list.
Offline Elth
« Reply #4 on: Sat, 24 March 2018, 21:38:45 »
Probably within the next few months. 2500k -> 8700k
Offline Belfong
« Reply #5 on: Sat, 24 March 2018, 21:43:30 »
Already upgraded last year... now I am thinking of upgrading the monitor. Need 4K, USB-C (for the Mac), IPS, 27", G-Sync - and it seems IMPOSSIBLE to find one like that. The nearest is a LG 27UD88 - but it is FreeSync - linky:
https://www.amazon.com/dp/B01CDYB0QS/?tag=httpwwwtechsp-20
« Reply #6 on: Sat, 24 March 2018, 21:56:03 »
hrrrmm.. I would say def don't do that because of meltdown/spectre.. but if you got a lan-party you gotta get to.. hahahaha
« Reply #7 on: Sat, 24 March 2018, 21:56:37 »
Nothing that small will handle 4k HDR very well..
So you're better off getting a 50 inch TV..
Offline Belfong
« Reply #8 on: Sat, 24 March 2018, 23:08:39 »
That LG is getting raves reviews. Raves, I’m telling ya.
Offline iLLucionist
  • Topre is Love.
« Reply #9 on: Sun, 25 March 2018, 04:13:31 »
I want a tempered glass case, purple lighting, black sleeved cables. a 1080 Ti (or 1180 Ti by then). I WANT TO BUILD A BEAST. But no moneeyssss.
Offline TalkingTree
    • My projects
« Reply #10 on: Sun, 25 March 2018, 04:31:13 »
I'm considering a Ryzen 2700X with a ITX mobo. I currently have a 4770K on a ATX mobo.
I'm still wondering if it's worth upgrading.
« Reply #11 on: Sun, 25 March 2018, 05:39:27 »
I expect that my main PC should last five years with its current CPU and mobo: i7 7700 on mATX.
I have room for more RAM, discrete GPU and more storage but don't need any yet.
Would have got Ryzen 2400G if I had built a system today, probably mITX. I don't need umpteen cores and I don't play much games.
Offline SBJ
  • Tactile pls
« Reply #12 on: Sun, 25 March 2018, 06:19:37 »
Going to be upgrading my 4790k to an 8700k.
Don't know when, but at some point this year.
« Reply #13 on: Sun, 25 March 2018, 21:02:17 »
My last but one upgrade was late 2009 so about 8 years ago.
My last upgrade was late last year.
Hopefully this one will last as long as the other one, which would make my next upgrade sometime around  2025.
:p
Offline JP
« Reply #14 on: Sun, 25 March 2018, 21:14:50 »
I'm sticking with my i7 3770k with 32 GB DDR3 and a GTX 1050 4GB GPU for the foreseeable future. Does everything I need plus I could overclock it if more power is needed. I might upgrade GPU next but that will be a while.
About Me | The Collection
Offline Leslieann
« Reply #15 on: Mon, 26 March 2018, 00:19:56 »
Those bugs are highly over-rated for home users.
It's a big deal if you have a server, but home users should be far less worried.
Most of that can be done for a few dollars.
Sleeving you can do yourself it's just time consuming, lighting can be done super cheap, and there is a pretty nice tempered glass case for just $60.
The only real issue here is that 1080... Bend over.
I've done systems of this caliber, they cost a lot and while they run well, you can get 90% of the performance for a lot less money. That last 10% in computing is rarely a wise choice.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline yuppie
« Reply #16 on: Mon, 26 March 2018, 00:33:56 »
I really need to upgrade my Skylake i5 6700k, but I've been avoiding it due to motherboard incompatibility. I don't want to buy a new board and chip for an incremental upgrade. I get really good frames on most of the games I play. Sea of Thieves is always around 100 FPS, for instance.
"Overall, it's a good community..  wish you well on your Pokemon Journey.." - TP4
Current Trades -- Wishlist
Offline RyuDragoon
« Reply #17 on: Mon, 26 March 2018, 15:26:16 »
I've been watching these SSD prices for a while now. Hoping to score a 1TB SSD under $200 sometime soon!
« Reply #18 on: Mon, 26 March 2018, 16:05:46 »
You missed out, 2016 black friday 700GB , $99
