Author Topic: How to fix (wrongly) bent copper plate of Cherry MX blue.  (Read 8530 times)
Offline Wasp
  • Insect spray adversary.
« on: Sat, 24 March 2018, 22:57:31 »
Hi forum (again),
I run also into a second problem while lubing my Cherry MX blues and this is even more frustrating: I bend the inner clicking metal plate of 2 switches. I guess it happened while opening the switches housing of the neighbouring switch.
Sadly I cannot find any detailed explanation or picturing of how they have to look like or how the shortens of the switch works. Sure, I can listen to 1 trillion sound tests, actuation graphs etc. pp. but not how to "build" .. or in my case: how to repair one.
I can achieve two things:
  • I can bend it to let it trigger all the freaking time.
  • I can bend it to not trigger at all.
..sadly I have no f$%&*!ng idea of the correct setting in between. Ironically I can barely tell a difference between both of these settings of the metal plate by naked eye! :'(
Can anybody help me in this matter with hints, tricks or maybe just a detailed photo of what the magic behind this copper plate is???
Thanks in advance
Wasp
Quick update:
Could manage to fix all my broken keys a.k.a. bend copper plates by somehow proper re-flexing. Even though it's not perfect. In case I got some acceptable shots with the phone I will post some details tomorr..later.  :rolleyes:
« Last Edit: Sun, 25 March 2018, 01:02:02 by Wasp »
Offline TerryMathews
Re: How to fix (wrongly) bent copper plate of Cherry MX blue.
« Reply #2 on: Sun, 25 March 2018, 21:53:52 »
easy way, desolder it, solder in another switch.
I can't believe I'm about to type this but I agree with TP4. Even if you can get the leaf bent back into the right position, you've probably significantly decreased the switches lifetime before failure.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #3 on: Tue, 27 March 2018, 09:27:28 »
hey hey don't diss TP. and yeah, spend the extra few cents and just use a new switch lol
Offline Wasp
« Reply #4 on: Wed, 28 March 2018, 13:24:29 »
I find them pretty expensive. At least the only offer I found so far for Cherry MX blue switches is not a few cents but almost 1 €  per switch! Since they come in a package of 10 peaces it doesn't even pay back if I could save some of the old ones.
Probably would go for gateron blues by now anyway. So they are a bit cheaper. However if you can point me to the correct offer where they cost just a few cents, I would be happy...
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #5 on: Wed, 28 March 2018, 13:26:43 »
Oh, I was just thinking you had some lying around. When you buy in packs of 80 or so they're only like $0.3 a piece. Try the free stuff thread, tons of people have switches lying around that I'm sure they'd be happy to post to you
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
Bore Awards
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #7 on: Fri, 30 March 2018, 18:04:05 »
If you were in the US i'd be happy to mail you some for free.. not worth it overseas though. I'm guessing someone on your continent could hook you up though.
-Dana
