Author Topic: NAS HDD Recovery Tools ??  (Read 10446 times)
Offline HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
« on: Mon, 09 April 2018, 05:54:13 »
Hey guys,
Somehow recently i miss click remove button on the shares folder in my "WD My Cloud". All the files on that folder deleted.
I already tried using the Z-a-recovery (premium license) but the files on the NAS not shown at all, all just the system file
Is there any recommendation to get some files at least back / recovered ?
Most of the files are JPG/PSD/PSB
I appreciate for any helps :thumb:
« Last Edit: Mon, 09 April 2018, 05:55:53 by HendyZone »
Offline Leslieann
Re: NAS HDD Recovery Tools ??
« Reply #1 on: Mon, 09 April 2018, 06:28:40 »
I was going to say you need to pull the drive from the NAS and connect it using a sata cable but then I noticed RAID, it always complicates things (I'll bite my tongue on that issue as it won't solve your problem). If it's still in the NAS you may need to pull the drive in order to get direct access, trying to recover files through a usb or ethernet connection doesn't give you the same hardware level access.
As silly as it sounds, I've seen Recuva recover files expensive programs couldn't.
« Last Edit: Mon, 09 April 2018, 06:30:14 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #2 on: Mon, 09 April 2018, 07:22:35 »
I've always suspected Recuva is an NSA affiliated corporation, they know their stuff alrite.
Offline HendyZone
  • HHKB Elite
« Reply #3 on: Mon, 09 April 2018, 08:16:40 »
Yeah i have disassemble the HDD from the enclosure
same like this one ->
connect on WIN 7 using this USB 3 SATA adapter :
Recuva, well noted will try it then  :thumb: :thumb:
Thanks a lot~
Will try Recuva then :thumb: :thumb:
« Last Edit: Mon, 09 April 2018, 08:19:03 by HendyZone »
Offline HendyZone
  • HHKB Elite
« Reply #4 on: Mon, 09 April 2018, 08:41:06 »
Update:
Try purchase Recuva Pro, no partition detected
They even can't read the NAS disk size :(
K, L, M, N, O all from NAS drive
Offline gjkrisa
« Reply #5 on: Mon, 09 April 2018, 11:48:54 »
If it's that important I'd try these guys
https://www.werecoverdata.com
Here is a good review video for them
Offline Leslieann
« Reply #6 on: Tue, 10 April 2018, 03:30:16 »
No, not Sata to usb, no adapters, period.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline HendyZone
  • HHKB Elite
« Reply #7 on: Tue, 10 April 2018, 08:21:18 »
Thank you for the info, but looks like that service will cost very expensive
Looks like ZAR deep scan method working now, at least it needs around 17 Hours to complete the scanning.
Trying to recover it and will close the thread once success, hopefully the software useful for others people later :thumb:
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #8 on: Tue, 10 April 2018, 09:30:57 »
Ultimately if you don't keep your data backed up, the cost of recovery becomes very expensive.
Offline Leslieann
« Reply #9 on: Tue, 10 April 2018, 17:03:43 »
If it works like most, that is just the scan and depending on what it finds, then you you get the fun of trying to sort though the things you trashed or revised, if some have the same file name and even figuring out if it's intact or can be rebuilt...
There's a reason data recovery is so expensive.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #10 on: Wed, 11 April 2018, 07:47:22 »
Not to mention the hardware costs for opening one up if necessary.
« Reply #11 on: Wed, 11 April 2018, 08:53:47 »
Love that Laminar-air-Flow !!
Offline HendyZone
  • HHKB Elite
« Reply #12 on: Thu, 12 April 2018, 06:07:25 »
Thank you all,
I can recommend this powerful software for NAS - standard HDD should be works great too i think
https://www.z-a-recovery.com/
License cost : $69.95(US)
around 200 GB files got recovered in ~17 hours :p
CASE CLOSED :thumb: :thumb:
« Reply #13 on: Thu, 12 April 2018, 21:42:26 »
That's fantastic!
Congratulations on a successful outcome :)
Offline Kennedy
« Reply #14 on: Wed, 18 April 2018, 04:26:54 »
If it is NAS drive, I can suggest a software which I have used. I did not create any restore point, so when the data was lost I had no choice other than purchasing a NAS recovery tool.
https://www.remosoftware.com/recover-data-from-network-drive. But this is slightly costly than what you have recommended.
I even tried using Recuva, but unfortunately it did not work for me.
Offline Coreda
« Reply #15 on: Wed, 18 April 2018, 04:37:34 »
Thank you all,
I wonder how this compares to PhotoRec, in terms of recovery power (GUI vs CLI aside). I'll keep it in mind. Looks like the original filenames were intact which is a bonus.
Offline HendyZone
  • HHKB Elite
« Reply #16 on: Wed, 18 April 2018, 05:07:10 »
Yeah Recuva not works for NAS, try ZAR if you need recover files later :thumb:
I have tried PhotoRec / TestDisk which is CLI both through OS X Terminal / Windows didn't work at all (no files shown). I followed the procedure on their web.
Offline Kennedy
« Reply #17 on: Wed, 18 April 2018, 05:16:25 »
Yeah.. sure. Thank you
