Author Topic: I found a weird yellow switch keyboard from the 90s  (Read 3454 times)
Offline garuger
« on: Fri, 25 May 2018, 14:16:36 »
https://imgur.com/a/0qmYSIw
As shown in the pics above it has yellow switches which i was able to
identify as https://deskthority.net/wiki/Taiwan_jet_axis
However the weird thing is that the board and switches it has it is mismatched
by the enclosure it is in.
As seen here https://www.reddit.com/r/MechanicalKeyboards/comments/3b3b2n/help_ive_found_an_old_dytcom_k160_keyboard/
the enclosure belongs to a k160 with cherry blue switches
while my keyboard enclosure should be like this https://klikkyklik.wordpress.com/category/klik/page/3/
Anyone can explain it ?
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
Re: I found a weird yellow switch keyboard from the 90s
« Reply #1 on: Fri, 25 May 2018, 21:59:56 »
Maybe someone swapped the switches in it...
Offline nogoodnames444
  • I like keyboards
« Reply #2 on: Sat, 26 May 2018, 02:19:47 »
Who make those color sliders though
Offline garuger
« Reply #3 on: Sat, 26 May 2018, 10:42:03 »
wdym
Offline rich1051414
« Reply #4 on: Sun, 03 June 2018, 06:20:03 »
Aristotle Yellow?
Offline Sup
« Reply #6 on: Mon, 04 June 2018, 01:26:22 »
They are smooth as retooled switches but have some inconsistency.
current
Coming soon
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #7 on: Mon, 04 June 2018, 01:43:43 »
Looks like Taiwan Jet Axis yellow.
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #8 on: Tue, 05 June 2018, 00:16:07 »
You got lucky on the ones you've tried, then. The "Aristotle Yellows" that I've tried are by far the worst switch I've ever used, it's almost unusably scratchy.
