Author Topic: Question. Grits.  (Read 5477 times)
Question. Grits.
« on: Fri, 20 July 2018, 20:08:55 »
Is the consistency suppose to be like wet sand ?
Or did I under do it ?
Re: Question. Grits.
« Reply #1 on: Fri, 20 July 2018, 20:14:48 »
Add some cheese.
« Reply #3 on: Fri, 20 July 2018, 20:22:16 »
It's supposed to be like cream of wheat texture.
Offline TheNamesTy45
« Reply #4 on: Fri, 20 July 2018, 21:48:32 »
Put the grits down, TP.
Offline HotRoderX
« Reply #5 on: Fri, 20 July 2018, 22:08:48 »
They need to be Thick like wet sand on a beach but.. not overly thick... should stick to your spoon but be moist. There also the wall test just fling them against the wall. They stick there gold if they run down the wall to much water. There like mash potatoes in that way.
« Reply #6 on: Fri, 20 July 2018, 22:14:45 »
Should there be small grains that are kind of hard to chew ?
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #7 on: Fri, 20 July 2018, 22:17:35 »
No, lol
Offline HotRoderX
« Reply #8 on: Fri, 20 July 2018, 22:17:56 »
umm hmm nooo they shouldn't be hard grains should be soft. No thick clumps
« Reply #9 on: Fri, 20 July 2018, 22:18:54 »
Guess I must've undercooked it..
« Reply #10 on: Sat, 21 July 2018, 02:46:45 »
Are you cooking regular or instant??
« Reply #11 on: Sat, 21 July 2018, 04:28:59 »
Ask Natalie Portman to pour it down your pants!
« Reply #12 on: Sat, 21 July 2018, 08:09:04 »
/headscratch.
I'm only aware of Grits mentioned in the film (My Cousin Vinny)
Ultimately,  I would say Marisa Tomei is way h0tter than N-port.
« Reply #13 on: Sat, 21 July 2018, 09:12:06 »
Grits and polenta are essentially the same thing, but polenta is rarely eaten bare and alone.
My mother made grits, stirred in garlic and cheese, and baked it in a deep dish with additional cheese and bread crumbs (or ground up corn flakes) on top for a dazzling side dish.
- D Trump 2026-10-24
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #14 on: Sat, 21 July 2018, 10:00:08 »
The Roots will teach you about the grits.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #16 on: Sat, 21 July 2018, 15:34:34 »
This flashed through my mind for some reason.
Thieves in the strobe deep freeze your pose. For the disease that grows underneath your toes holds up a reason y'alls gold never seems to glow. Now we can all breath slow once the fiend's exposed. It goes heave ho. You never got the grit right. Bark fame but you never put the grit down. Hawk styles but you never got the grit right. Put the grit down. Grit right. Get down.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #17 on: Sat, 21 July 2018, 15:57:15 »
So... this stuff is basically boiled corn puree? Oo
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #18 on: Sat, 21 July 2018, 16:55:30 »
The grocery stores in my area all carry grits variety packs alongside plain grits. Quaker Oats Country Bacon is decent imho.
edit - To be fair I grew up with purina wheat and oatmeal. I haven't had grits since about grade 12 (00's), back when I was dating someone that grew up with the stuff.
« Last Edit: Sat, 21 July 2018, 18:03:13 by csmertx »
« Reply #19 on: Sat, 21 July 2018, 18:12:12 »
The corn has to be processed to get there. If I remember correctly, it is soaked in an alkaline solution to make the kernels puff up into "hominy" (much better than grits, in my opinion) and then dried out again and ground into a coarse meal. Then it gets boiled again to reconstitute it.
« Reply #20 on: Sat, 21 July 2018, 19:15:09 »
It's dried and milled.
Offline chyros
  • a.k.a. Thomas
« Reply #21 on: Sun, 22 July 2018, 02:37:37 »
Oh my god, that sounds even worse! Oo
Offline Blackehart
« Reply #22 on: Mon, 23 July 2018, 11:04:51 »
it basically ground up hominy.
SOOOOOO good as a side with corned beef hash.
GAH...
I'm hungry now.
« Reply #23 on: Mon, 23 July 2018, 12:55:25 »
apparently nobody reads previous posts
« Reply #24 on: Mon, 23 July 2018, 13:12:58 »
GAH...
I'm hungry now.
Mmmmm... hashhhh.... shhhhhhhhhhh
