Author Topic: 6 years and I still cant stay on a single switch  (Read 6571 times)
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« on: Thu, 23 August 2018, 17:55:41 »
Anyone else out there tire of the switches they liked using and swap to a different switch and love it and then find yourself going for another one in a endless cycle?
Switches I have used for more than 2 weeks in the last 8 months
Cherry Brown Stock
Cherry Black Stock
Gateron Black Stock
Gateron Brown 67g lubed *
Kailh Speed Silver
Kailh Speed Copper
Kailh Pro Purple *
Kailh BOX Brown
Kailh Hako True *
Kailh Halo True
Cherry Clear - 62g
Zealios R2 65g
Gateron/KBfans Brown Silent
Pingmaster Alps Switches (Linear)
Topre HHKBPro2
* - ones I prefer the most
These aren't all the switches I have, these are just the switches I have used regularly in the last 8 months
Offline Sup
Re: 6 years and I still cant stay on a single switch
« Reply #1 on: Thu, 23 August 2018, 21:04:22 »
I guess first you have to find out if you like Clicky,tactile,Linear switches. From there you go for your favorite weight.  And from there you make a meme switch and boom you got your switch for you.
My plans are getting outemo v2 housing with halo trues with gateron yellow springs in a canoe :).
current
Coming soon
Offline Rubbermilitia
« Reply #2 on: Thu, 23 August 2018, 21:07:24 »
Whats special about the outemo v2 housing? Right now gateron yellow is my favorite, after trying many other switches.
I started with clicky switches for the novelty of the click, then moved on to tactile because the click is annoying after while, then moved onto linears even though I think clicky/tactile is more exciting, I think linears are just a better typing experience. I tried cherry reds, built my own linears with cherry brown spring, gateron milky housing and cherry black stem, then finally moved onto gat yellow which I think I like best so far.
I would like to try tealios and lubed kailh box black next
Offline Glod
    • YouTube Channel
« Reply #3 on: Thu, 23 August 2018, 21:18:28 »
I guess what I'm getting at and wasnt clear
Im not mad at changing switches all the time,  I love the variety and that hasn't changed over 6 years.  I don't think I can stick with one switch
Sent from my SM-N950U using Tapatalk
« Reply #4 on: Thu, 23 August 2018, 21:21:46 »
yeah I have consistently moved from one switch to the next pretty much monthly. But I like to think that it is all part of the process of finding the perfect switch. I still like to think that I can find the perfect end game board/switch and get out of this hobby permanently so I can finally save some money lol.
Offline pixelpusher
« Reply #5 on: Thu, 23 August 2018, 21:26:24 »
Cherry Brown Stock
Cherry Black Stock
Gateron Black Stock
Kailh Speed Silver
Kailh Speed Copper
Kailh Pro Purple *
Kailh BOX Brown
Kailh Hako True *
Kailh Halo True
Cherry Clear - 62g
Zealios R2 65g
Topre HHKBPro2
Nice taste in switches, sir.  I also have all of the switches you've listed above and rank hako true and purple pro up there in the top for sure.  I also really like lubed stock clears and lubed cherry blacks.  I find myself tired of a switch after about a week.  I will start thinking that I hate all of my keyboards, and then I pull out something I haven't used in a while to find it's actually pretty nice.
I also have found that I really like the 67g zilents too.  And when I'm really feeling like I've wasted all of my money on switches I hate I pull out my Dell bigfoot or SSK.
Oh, and for me the worst thing in the world is when you find something wrong with your nice keyboard.  Like when you find that the spacebar hangs if you push it just a certain way on your $500 build.  And once you notice it, you can't stop from pressing it just that way.  These are good times to go out and get some fresh air or sketch something with a pencil :)
« Last Edit: Thu, 23 August 2018, 21:31:07 by pixelpusher »
Offline Sup
« Reply #6 on: Thu, 23 August 2018, 21:43:31 »
I have some prototype v2 outemo switches. These have a super tactile leave and if you combine them with halo trues they become like holy pandas. That's what people told me at least. And yes Gateron yellow is also my favorite switch :). But i am kinda going toward cherry instead of Gateron since Gateron leaves get worn out in the long term making them scratchy.
If you used your Gateron yellow keyboard longer then 3 months try to compare most used keys with keys that didn't almost get used. You will feel a noticeable difference
current
Coming soon
« Reply #7 on: Thu, 23 August 2018, 21:45:26 »
Did your gateron yellows become lighter with use? Or heavier? What changed over time?
Offline Sup
« Reply #8 on: Thu, 23 August 2018, 21:49:04 »
Some keys became noticeable more scratchier. My asdw was super scratchy compared to the keys that haven't been used a lot.
You can read more in this topic.
https://geekhack.org/index.php?topic=97026.0
current
Coming soon
« Reply #9 on: Thu, 23 August 2018, 21:51:30 »
Oh ok. I wonder if lube could help prevent that?
Offline Sup
« Reply #10 on: Thu, 23 August 2018, 21:52:37 »
No idea i lubed the stems only not the housing. So who knows but it's clearly that it's the leaf that causes the issue.
current
Coming soon
« Reply #11 on: Fri, 24 August 2018, 00:18:36 »
Glod is not a Keyboard-Addict..
Glod is a Shopping-Addict..
Offline Norz
« Reply #12 on: Fri, 24 August 2018, 08:58:32 »
Which switches are both clicky and super light ? (read: lighter than mx blue)
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #13 on: Fri, 24 August 2018, 09:00:08 »
Cherry Brown Stock
Cherry Black Stock
Gateron Black Stock
Kailh Speed Silver
Kailh Speed Copper
Kailh Pro Purple *
Kailh BOX Brown
Kailh Hako True *
Kailh Halo True
Cherry Clear - 62g
Zealios R2 65g
Aren't they all basically the same anyway? :p
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
« Reply #14 on: Fri, 24 August 2018, 09:18:41 »
Cherry Brown Stock
Cherry Black Stock
Gateron Black Stock
Kailh Speed Silver
Kailh Speed Copper
Kailh Pro Purple *
Kailh BOX Brown
Kailh Hako True *
Kailh Halo True
Cherry Clear - 62g
Zealios R2 65g
What the **** did you just ****ing say about my switches, you little ****? Ill have you know I graduated top of my class in the Switch detection, and Ive been involved in numerous secret raids on r/mk, and I have over 300 diffrent confirmed switches . I am trained in keyboard science and Im the top member in the entire reddit armed forces. You are nothing to me but just another pleb. I will wipe you the **** out with precision the likes of which has never been seen before on this Earth (aka Kalih speed silver), mark my ****ing words. You think you can get away with saying that **** about switches over the Internet? Think again, ****er. As we speak I am contacting my secret network of spies across the USA and your IP is being traced right now so you better prepare for the storm, maggot. The storm that wipes out the pathetic little thing you call your "keyboard". Its ****ing dead, kid. I can be anywhere, anytime, and I can unplug you in over seven hundred ways, and thats just with my bare hands. Not only am I extensively trained in unarmed unpluggery, but I have access to the entire arsenal of the Top Clack Marine Corps and I will use it to its full extent to wipe your miserable ass off the face of the continent, you little ****. If only you could have known what unholy retribution your little clever comment was about to bring down upon you, maybe you would have held your ****ing tongue. But you couldnt, you didnt, and now youre paying the price, you goddamn idiot. I will **** fury all over you and you will drown in it. Youre ****ing dead, kiddo.
Offline pixelpusher
« Reply #15 on: Fri, 24 August 2018, 09:20:41 »
Kailh speed bronze are pretty light and very clicky.  Also there are Kailh box whites (same design in a box style with a bit more travel).  You could probably put a lighter spring in an MX blue or a modded switch with aristotle stems.
Offline pixelpusher
« Reply #16 on: Fri, 24 August 2018, 09:21:46 »
Cherry Brown Stock
Cherry Black Stock
Gateron Black Stock
Kailh Speed Silver
Kailh Speed Copper
Kailh Pro Purple *
Kailh BOX Brown
Kailh Hako True *
Kailh Halo True
Cherry Clear - 62g
Zealios R2 65g
GOTEM! Dude, do you play overwatch?  I swear you were on my team yesterday   :p
BTW I can only play Overwatch for about 20 min a day b/c this is how everyone talks in chat.  It gives you AIDS
Offline Glod
    • YouTube Channel
« Reply #17 on: Fri, 24 August 2018, 09:32:34 »
I spit out my drink when I saw this.  Haha
Offline chyros
  • a.k.a. Thomas
« Reply #18 on: Fri, 24 August 2018, 09:37:53 »
Cherry Brown Stock
Cherry Black Stock
Gateron Black Stock
Kailh Speed Silver
Kailh Speed Copper
Kailh Pro Purple *
Kailh BOX Brown
Kailh Hako True *
Kailh Halo True
Cherry Clear - 62g
Zealios R2 65g
Is this a quote I don't know of? xD
Offline Signature
  • master of puppers
  • snoozing
« Reply #19 on: Fri, 24 August 2018, 09:55:10 »
Cherry Brown Stock
Cherry Black Stock
Gateron Black Stock
Kailh Speed Silver
Kailh Speed Copper
Kailh Pro Purple *
Kailh BOX Brown
Kailh Hako True *
Kailh Halo True
Cherry Clear - 62g
Zealios R2 65g
no I don't play overwatch sadly :(
Offline Signature
  • master of puppers
  • snoozing
« Reply #20 on: Fri, 24 August 2018, 09:55:44 »
Cherry Brown Stock
Cherry Black Stock
Gateron Black Stock
Kailh Speed Silver
Kailh Speed Copper
Kailh Pro Purple *
Kailh BOX Brown
Kailh Hako True *
Kailh Halo True
Cherry Clear - 62g
Zealios R2 65g
It's my interpretation of the navy seals copypasta ;)
Offline Glod
    • YouTube Channel
« Reply #21 on: Fri, 24 August 2018, 10:11:20 »
Cherry Brown Stock
Cherry Black Stock
Gateron Black Stock
Kailh Speed Silver
Kailh Speed Copper
Kailh Pro Purple *
Kailh BOX Brown
Kailh Hako True *
Kailh Halo True
Cherry Clear - 62g
Zealios R2 65g
lol
being serious for a moment
I like to think of it as something like a treble and bass. Tactile Level and Weight.
Offline 9999hp
« Reply #22 on: Fri, 24 August 2018, 12:21:30 »
I don't really switch to often; more so just acquire a bunch of switches then wait til I have something to put them on; then switch entire boards.
Narrowing my preferences to tactile and linear currently. Have a ton of vint blacks I need a board for, but I think I might just replace the navy box blues on my ALFx2 with those (ever since we found out it was cracking stems I haven't used it.). Looking for the right end-game board for some HPs. It's pretty fund trying new switches; really changes up the typing experience for me.
« Reply #23 on: Sat, 25 August 2018, 11:15:31 »
whereas i pretty much just use the same keyboard for years on end
different strokes i guess
Offline duckboi
« Reply #24 on: Sat, 25 August 2018, 11:29:42 »
While I have switched between a bunch of different switches/boards, I think I've found my favorite being 55g Topre in a Realforce. I'm really satisfied with this.
Happily thocking on that with a Norbauer case!  :D :D
The m0ar empty you feel,  the m0ar space for Keycaps..
Offline Jae-3soteric
  • https://www.youtube.com/channel/UCAIHiFKJt69HNad6r
    • Jae | Top Clack
« Reply #25 on: Sat, 25 August 2018, 11:39:29 »
I don't stick to the same board for more than a week at a time usually - most of them are in rotation over the course of a year or so. The only board that seems to get more playtime than the others is my PC Singa with C3 tangerines in. I actually have them in three boards, but the other two barely seem to get selected. I've also got a soft touch for anything tactile from plain Zealios, to Pandelios, and even the new Outemu Sky switches.
This isn't a bad thing - part of the beauty of the Hobby is being able to change and try different things.
