Author Topic: Use -until Xplodez  (Read 2609 times)
Use -until Xplodez
« on: Mon, 03 September 2018, 07:36:04 »
Have been trying to xplodez my x220 laptop for years now, (in order to) justify purchasing a new laptop.
But it refuses to Die.. runs Smooth.. not skippn' a Beat
It also doesn't help that Tp4 Zinc plated the copper heatsink and used Liquid metal, so Tp4's x220 runs 15% c00ler than conventional x220 lappies.
At this rate, Tp4 will be using x220 well into 2025..
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Use -until Xplodez
« Reply #1 on: Mon, 03 September 2018, 11:02:22 »
Install Gentoo, that'll fix that laptops pesky habit of outliving the warranty.
« Reply #2 on: Mon, 03 September 2018, 13:27:44 »
I only remember win 10 cycling 100% cpu all the time,   still on win 7 on the lappie.
Offline Leslieann
« Reply #3 on: Mon, 03 September 2018, 20:03:23 »
Even without those mods, it's new enough to throttle if it gets too hot, and there is a pretty big buffer before you do serious damage to them due to heat. At any rate, why kill it, it's a fantastic machine for using when you want to try something new or before a major update on your main system.
If you need an excuse to upgrade, how about USB 3 or Type C, Sata3 or even better, NVME, HDMI, Display Port, Thunderbolt, 32GB of ram, MUCH better GPU, longer battery, better wifi, higher res screen with better color calibration... The X220 was an awesome laptop and had this been 3 years ago, fine, but now? It's getting long in the tooth. Really, really long. Honestly, my only concern with upgrading at this point would be the OS if you're using Windows.
Side note,
Win7 currently sits in the mid to high 30% range of Windows market share, once it drops below 30% expect hardware manufacturers to ignore it at exceedingly faster and faster rates even without MS pushing them to. I expect it to cross that mark 1st quarter of 2019 and that doesn't even take into account the holidays which always brings a surge of new systems. Lest you think Win8.1 is safe it's market share is already single digits, it's only saving grace is that it uses the same driver engine as Win10.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Kavik
« Reply #4 on: Tue, 04 September 2018, 17:29:55 »
Does the x220 have the same sound issue that the T420 does? The sound only works maybe 1 out of every 20 boots with a red X over the speaker icon because it can't even detect a sound chip and thus won't allow for driver un/re-installation because "no sound device detected". Even if it works, it will stop working if the computer hibernates or sleeps and is awoken. According to Google search, it's a common problem with no fix.
That's the only thing I don't like about this laptop. I got it like new refurbished for $200 2.5 years ago.
At least the x220 and T420 have good keyboards (with an actual nav cluster).
« Reply #5 on: Tue, 04 September 2018, 17:34:09 »
The x220 doesn't have that problem..
On the T420, my guess is that the motherboard has a flex somewhere which causes trace cracks..
But since it's a multilayer board, the only way to fix would be to look up the lenovo electrical diagrams..
This guy posted a fix here, says unsigned drivers in win 7, says to install xp drivers and works. ..
https://forums.lenovo.com/t5/ThinkPad-T400-T500-and-newer-T/T420-Windows-7-Pro-suddenly-no-audio-device-installed-Conexant/td-p/3333017
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #6 on: Wed, 05 September 2018, 14:23:01 »
I'll keep using Windows 8.1 until Windows 10 dies. I hate it with a passion.
