Author Topic: Quiet mouse?  (Read 11111 times)
Offline hoggy
  • * Ergonomics Moderator
Quiet mouse?
« on: Thu, 18 October 2018, 02:53:15 »
I'm looking for a mouse that has a quiet/silent click for a colleague.  They use the mouse a lot, so it needs to have switches rather a touch surface.
Does anyone have any ...pointers?  (Sorry)
Offline Leslieann
Re: Quiet mouse?
« Reply #1 on: Thu, 18 October 2018, 03:16:17 »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline t8c
Re: Quiet mouse?
« Reply #2 on: Thu, 18 October 2018, 03:45:23 »
Re: Quiet mouse?
« Reply #3 on: Thu, 18 October 2018, 11:05:28 »
Hahahaha.. Yea basically,  anything that Isn't a d2fc clone will be silent..
The entire d2f line and its clones are designed specifically to have that chirp chirp  sound..
Offline hjnap
Re: Quiet mouse?
« Reply #5 on: Fri, 28 December 2018, 23:12:44 »
The Weeaboo Jpn omron d2f-01f  are less bright sounding than the d2fc (china).
Maybe give those a try as well.  They're stick clicky, but it's a dull click
Offline Cavemann6
Re: Quiet mouse?
« Reply #6 on: Sun, 06 January 2019, 12:07:29 »
I use these with my g403.
https://www.ebay.com/itm/6-pcs-Brand-New-Kailh-quiet-slient-mute-Micro-Switch-Microswitch-for-mouse-mice-/351111803766
Woah, didn't know these exist, will have to try this someday on my mouse. Could you use these on any logitech mouse? (I'm using g703)
