Author Topic: Old Peanut butter..  (Read 10477 times)
Old Peanut butter..
« on: Sat, 17 November 2018, 00:41:26 »
Xpired, 2010,
Unopened, Stored, back of fridge behind the tall sake.
-- name brand (jiffy)
-- smells fine
-- no discoloration/ separation
Wish me Luck..
Re: Old Peanut butter..
« Reply #1 on: Sat, 17 November 2018, 00:49:51 »
Hrrrrm... tastes alrite..
A bit, waxy and slightly tongue numbing..
hrrrm...
Offline HotRoderX
« Reply #2 on: Sat, 17 November 2018, 00:58:53 »
Seen a video on a forum.. guy ate peanut butter from a ww2 MRE.. Don't think he died.
« Reply #3 on: Sat, 17 November 2018, 01:09:02 »
mmm... Stomach making a noisse..
Nothing xplode yet..
« Reply #4 on: Sat, 17 November 2018, 03:56:02 »
guarantee it is rancid as pb goes bad in about a year, but people taste buds are different so you may not even notice.since it was sealed it wasn't exposed to oxygen which is what the cause of comtam always is, but the process will be vastly accelerated once it's open. it won't make you sick, maybe just a tummy ache.
« Reply #5 on: Sat, 17 November 2018, 09:26:25 »
Woke up..  superficially, Alive..
Trial 2 later this evening.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #6 on: Sat, 17 November 2018, 14:26:16 »
Eating rancid **** isn't the path to your 6 pack abs, tp
« Reply #7 on: Sat, 17 November 2018, 14:37:44 »
Noisyturtle said, I wouldn't be able to tell if it was rancid.. Is this true.. ?
« Reply #8 on: Sat, 17 November 2018, 19:50:22 »
Trial 2, administered..
Observations so far..   Has not xploded into a bloody mist..
« Reply #9 on: Sat, 17 November 2018, 20:03:59 »
if you see any black dots in there toss that ****
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #10 on: Sun, 18 November 2018, 09:10:57 »
Ew, why do you keep your peanut butter in the fridge?
Offline YoungMichael88
  • HHKB Wannabe
« Reply #11 on: Sun, 18 November 2018, 11:27:39 »
Placing peanut butter in the fridge is grounds for execution.
RIP torn bread
Sent from my iPhone using Tapatalk Pro
« Reply #12 on: Sun, 18 November 2018, 12:06:44 »
RIP torn bread
  • HHKB Wannabe
« Reply #13 on: Sun, 18 November 2018, 12:09:28 »
RIP torn bread
I can’t kill Tp4!
*YM uses revive serum on Tp4
But seriously, PB in the fridge is a bread killer. SPREAD the word!
« Reply #14 on: Sun, 18 November 2018, 12:11:35 »
I can’t kill Tp4!
This "Revive Serum"
Is it also Peanut Butter based.. ??
  • HHKB Wannabe
« Reply #15 on: Sun, 18 November 2018, 12:13:40 »
I can’t kill Tp4!
This "Revive Serum"
It’s raspberry jam, of course!
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #16 on: Sun, 18 November 2018, 12:23:54 »
No seriously, what is the point of keeping peanut butter in the fridge? Even when I bought farm fresh peanut butter I'd store it outside the fridge.
Do people store their peanut butter in the fridge? Is that actually a thing or are you just 'pulling my leg'?
  • HHKB Wannabe
« Reply #17 on: Sun, 18 November 2018, 12:27:54 »
I have seen peanut butter in the fridge before on many occasions. I’m not sure if it was ever an intentional choice but having said that, I have accidentally stored the PB jar in the fridge on occasion only to find it stiff as a board and un-spreadable until it comes back up to room temperature.
« Reply #18 on: Sun, 18 November 2018, 13:14:17 »
Tp4 just eats straight peanut butter.. soooo.. don't need 2 spread..
  • HHKB Wannabe
« Reply #19 on: Sun, 18 November 2018, 13:16:08 »
I want peanut butter ice cream now :) that’s the only time I really ever consume peanut butter that’s not served on some sort of bread product
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #20 on: Sun, 18 November 2018, 13:23:51 »
Alright. I guess there are times when I toss pb in my smoothies and it really doesn't matter if the pb is cold or room temp.
  • HHKB Wannabe
« Reply #21 on: Sun, 18 November 2018, 13:29:53 »
Yes, but the chilling of peanut butter adds no value when used in the majority of applications including a smoothie. It’s a spreadable product at its core and unless you intend to never use the product in a spreadable application, then the only reason to put it in the fridge is if you enjoy the colder temperature and mouth feel when consuming it on its own by the spoonful. I think peanut butter on its own would actually taste/feel better when chilled. So the only solution to this problem would be 2 jars of peanut butter! One chilled and one not! More peanut butter is always the answer! Now I want to heat peanut butter and dip a banana in it as a sauce!
« Reply #22 on: Sun, 18 November 2018, 13:30:55 »
But day tol' us bout dat BAKETERIA..
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #23 on: Sun, 18 November 2018, 13:51:58 »
*mertx now understands*
  • HHKB Wannabe
« Reply #24 on: Sun, 18 November 2018, 13:53:30 »
Low risk/high reward!
« Reply #25 on: Sun, 18 November 2018, 20:22:59 »
I keep all my condiments in the fridge. Just a matter of cleanliness and principle, plus they last longer. Why risk contamination over soft pb?
Knew someone who kept cheese OJ butter and condiments on his counter. ****ing disgusting.
« Reply #26 on: Sun, 18 November 2018, 21:01:06 »
There was this crazy Van-Life person I saw on youtube, she kept eggs unrefrigerated..
INSANE>.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #27 on: Mon, 19 November 2018, 06:25:19 »
If the package says to keep refrigerated after opening I comply. Otherwise, it goes in a cupboard. I might disagree with someone that chooses to place peanut butter in the refrigerator, but I support their resolve to forever double dip. That's a tough choice--and once it's made one can never go back to unrefrigerated peanut butter.
Offline invariance
  • ...here with all the other boson's
« Reply #28 on: Mon, 19 November 2018, 08:05:39 »
Tp, are you ded yet?
I’m sure some things have the ‘refrigerate once opened’ to cover their arse for the imbecile that will leave it out for months on end, then go back to it and fall ill.  For example, peanut butter is perfectly reasonable to not refrigerate provided it is consumed in a sensible period, about a month (ymmv).
Another example would be Vegemite, but I don’t think that **** ever goes off
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
« Reply #29 on: Mon, 19 November 2018, 11:21:43 »
I = Alive..
If vegemite tasted off,  would one be able to tell..
Also, what if it WAS OFF,  but then one only ate little enough such that it did not make him sick.
Theoretically they could completely consume the entire tub of OFF vegemite ..
This type of logic across all consumables often keeps me up at night..
« Reply #30 on: Mon, 19 November 2018, 19:56:34 »
I = Alive..
You would generally not consume an entire tub (or jar) of Vegemite in one sitting.
Offline Kavik
« Reply #31 on: Tue, 20 November 2018, 01:23:00 »
INSANE>.
My understanding is that only people in the USA refrigerate eggs because the protective coating is washed off during processing here. In other countries, the protective coating is left intact so it doesn't spoil.
Offline invariance
« Reply #32 on: Tue, 20 November 2018, 07:40:42 »
I = Alive..
That definitely would kill you
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
Offline invariance
« Reply #33 on: Tue, 20 November 2018, 07:44:29 »
INSANE>.
I didn’t know eggs have a protective coating, other than the shell
Besides, keeping them in the fridge helps them to keep longer.
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #34 on: Tue, 20 November 2018, 08:09:34 »
I love where this thread is going. Best thread :thumb:
  • HHKB Wannabe
« Reply #35 on: Tue, 20 November 2018, 08:22:52 »
INSANE>.
Fresh eggs have a protective layer called cuticle on the shell after laying which seals the shells porous surface from bacteria. These fresh eggs, if never washed, can last at least two weeks on your counter unrefrigerated. BUT, once refrigerated, eggs must remain refrigerated.
Source: Google/In-laws have 6 chickens at the cottage.
« Reply #36 on: Tue, 20 November 2018, 10:40:52 »
Eggs.. come out of chicken butt..
NOT SAFE to eat unwashed eggs..
Heck it's really not super safe to eat eggs at all.. ebola/salmonella/ avian flu
The whole process is frightening..  True carnivores have <1 ph stomach acid.. humans got only 3-4, strong, but not nearly the same killing power..
  • Live long and prosper
« Reply #37 on: Tue, 20 November 2018, 11:03:12 »
eggs are delicious
best fresh out of the chicken's butt
just clean the **** off before you crack the shell
tp thread is tp thread
« Reply #38 on: Tue, 20 November 2018, 11:21:49 »
eggs are delicious
Microbzz..
« Reply #39 on: Tue, 20 November 2018, 11:25:11 »
eggs are delicious
Microbzz..
cook egg, kill microbes
  • HHKB Wannabe
« Reply #40 on: Tue, 20 November 2018, 11:26:15 »
Indeed. Of course in the case of fresh eggs from a chicken you would wash the egg before consuming.
« Reply #41 on: Tue, 20 November 2018, 11:27:26 »
there are endotoxins not destroyed by cooking.. !!
« Reply #42 on: Tue, 20 November 2018, 11:33:23 »
you're just paranoid
« Reply #43 on: Tue, 20 November 2018, 16:03:04 »
a cloaca is probably the dirtiest hole on the planet, nothing that hasn't been sterilized is going near my dang mouth!
« Reply #44 on: Tue, 20 November 2018, 16:32:53 »
The problem is , alot is being assssumed at this stage.
Offline invariance
« Reply #45 on: Tue, 20 November 2018, 17:36:19 »
Haha, I see what you did there.
I’m sure there has been worse near noiseyturtle’s mouth
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
« Reply #46 on: Tue, 20 November 2018, 17:49:27 »
Oh he's done some Stufff.. that's for sure..
« Reply #47 on: Tue, 20 November 2018, 19:54:14 »
INSANE>.
Reminds me of those lines from HHGTTG:
What do eggs come out of?
Chickens?
Yes, but what do they come out of the chickens in?
Egg shells?
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #48 on: Tue, 20 November 2018, 20:07:21 »
INSANE>.
Chickens?
Egg shells?
Probably also relavent:
When you have been in marketing as long as I have, you’ll know that before any new product can be developed, it has to be properly researched. I mean yes, yes we’ve got to find out what people want from fire, I mean how do they relate to it, the image -"
"Oh, stick it up your nose."
"Yes which is precisely the sort of thing we need to know, I mean do people want fire that can be fitted nasally."
Offline comdata55
« Reply #49 on: Tue, 20 November 2018, 21:02:25 »
An ode to TP4
What is this Jiff?
Open and take a whiff...
Smells not offensive,
Makes me quite pensive.
Should i partake?
will my bowels start to quake?!
Creamy goodness -
from the butt -
of a nut.
I SHALL dig in...
paired with Sake, not Gin,
for it's all that I've got,
Hope my stom-ache won't rot!
