Author Topic: New Year's Resolution  (Read 5364 times)
Offline 9999hp
« on: Sun, 16 December 2018, 09:15:48 »
Does anyone participate? If so, what are you going to accomplish in 2019?
 I don't usually choose a hard resolution, but just general idea; like this upcoming year I am going to make more time to draw.
Offline ArchDill
Re: New Year's Resolution
« Reply #1 on: Sun, 16 December 2018, 10:06:30 »
I have already started on mine. I am trying to be more productive with my time. I uninstalled all of my games and am not planning on starting any new series. As my "hobby" I am trying to learn webdev.
Offline no, the other guy
  • actually, this guy
« Reply #2 on: Sun, 16 December 2018, 11:03:15 »
I want to finish at least one of my four started or even "only planned" development projects, including one that uses an Arduino. I never did anything with those, but I surely want to see whether my related idea is realistically doable.
<armin> i have the impression the only reason the mx red switch was invented was drunk people
Unicomp PC122 (review) * IBM Model F XT * Dell AT101W
  • Live long and prosper
« Reply #3 on: Sun, 16 December 2018, 13:09:40 »
2019 goals:
Get at least one major IT certification
Start exercising
Start dating
tp thread is tp thread
Offline 9999hp
« Reply #4 on: Sun, 16 December 2018, 13:39:08 »
Sounds like 2019 is going to be productive for ya'll; I could probably do with less wasted time; hence the drawing hopefully using up quite abit of that time; how do you guys usually do with your goals?
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #5 on: Sun, 16 December 2018, 14:22:24 »
Mostly just a bunch of things I started this year:
- Build a keyboard (build anything really)
- Raise daily calorie limit to 2200 from 1800 once ~180lbs goal is reached (started @230lbs 20 weeks ago, now @212lbs)
- Learn a multi-platform scripting language
- Break out the webserver/local cloud in to its own box
- Create at least one small program in C
- Dip into my dl'd texture files (30GB atm--all legit to use) and see what happens
I should draw more too :-[
« Reply #6 on: Sun, 16 December 2018, 14:23:55 »
You could combine them.  :cool:
« Reply #7 on: Sun, 16 December 2018, 14:31:00 »
Don't worry.. The only thing Tp4 will be doing is m0ar Calibrate, m0ar CRT. !!
Start dating
« Reply #8 on: Sun, 16 December 2018, 14:34:10 »
No point,  I won't do them anyways.
« Reply #9 on: Sun, 16 December 2018, 14:35:23 »
SpamRay, All Veggie 2019
« Reply #10 on: Sun, 16 December 2018, 14:37:24 »
Probably should it's probably gonna be no more gallbladder :(
« Reply #11 on: Sun, 16 December 2018, 14:38:41 »
If your weight is mathing out that nicely, great job..
« Reply #12 on: Sun, 16 December 2018, 14:40:21 »
I read that those importante ?
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #13 on: Sun, 16 December 2018, 15:15:36 »
If math, then 32+ weeks to reach my goal. Of course 2200 is my best estimate. I'll have to apply a 2-4 week test to see if 2200 is my equilibrium. And thanks btw  :)
weird flex screenshot madness
edit - also, defrost timer tested positive continuity for all cycles woot :)
« Last Edit: Sun, 16 December 2018, 15:17:46 by csmertx »
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #14 on: Sun, 16 December 2018, 15:21:09 »
I'd like to focus on my career ;D
Offline Starston3
« Reply #15 on: Sun, 16 December 2018, 15:40:07 »
While shopping for a white elephant gift... I happened to buy 3 new ties. I don’t have a dress up job so I am going to try to be more social as I have recently-ish moved across country.
So this includes going to more functions, the theater, opera, charity events and so on.
« Reply #16 on: Sun, 16 December 2018, 17:51:17 »
I just want a job. That's it. Any job that doesn't pay near minimum wage. Why did I go to college? What have I been working for the past 5 years? It is legitimately absurd how I don't have a job by now, cannot even understand it anymore.  :confused:
« Reply #17 on: Sun, 16 December 2018, 20:05:28 »
I made a new year's resolution many years ago to not make any more new year's resolutions.
I've been keeping to it ever since.
Offline 9999hp
« Reply #18 on: Mon, 17 December 2018, 08:36:00 »
I'm just trying to at least do some kind of coherent sketch per day; maybe it'll form into a habit
[/quote]
youtube channel when? "What's up CRT fam!?"
Start dating
Good luck! Definitely put yourself out there!
[/quote]
Yup; exactly why I try to avoid rigidness
What do you do?
You forgot meetups :)
Are you trying to stay in your area?
If I could keep a decade+ long resolution I'd be king of the world
Offline equalunique
« Reply #19 on: Tue, 18 December 2018, 07:35:03 »
Mine has been to loose weight. Already lost 12lbs since november on a keto diet, so I think I'll meet the goal of dropping a pants size.
Sent from my LG-H918 using Tapatalk
« Reply #20 on: Tue, 18 December 2018, 07:42:58 »
Offline appaboy
« Reply #21 on: Tue, 18 December 2018, 07:45:43 »
Buy less gmk kits I'll never use  (I have about 4 or 5 sets in a drawer but only 2 custom boards to put em on)
PC Singa, MIR80, TX84se, g80-3314, g80-0427, g80-5000 + 5700, G80-3700, g81-3000 HBU (og wob)
HASRO keycaps
OG POM keycaps
SAI OG Italian dyesubs
Scarface Fn blank
Offline funderburker
« Reply #22 on: Tue, 18 December 2018, 09:08:44 »
Mmm, I usually don't make NY resolution lists but I need to rank up post count somehow (oh lol, just noticed this is Off Topic).
  • Register a company so I can run keyboard GBs on my own
  • Run at least two keyboard GBs in 2019
  • Finish Spring semester in university without any course credit point debts
  • Loose weight (~10kg) and stick with the new weight for a while
  • Start working out at least once a week (I'm at zero for the moment)
Keyboard design by Skepur
« Reply #23 on: Tue, 18 December 2018, 19:48:05 »
Or ... buy moar boards!!!1!
Offline rarar
  • moist booty seepage
« Reply #24 on: Fri, 21 December 2018, 19:45:14 »
New years resolution is to work on my memory, and learning to build it up manually with mind palace techniques! And my personal goal is to go the whole year without smoking! I've been sober for a month and a half now. Dopamine is one hellofa chemical.
« Last Edit: Fri, 21 December 2018, 20:10:41 by rarar »
Ỏ̷͖͈̞̩͎̻̫̫̜͉̠̫͕̭̭̫̫̹̗̹͈̼̠̖͍͚̥͈̮̼͕̠̤̯̻̥̬̗̼̳̤̳̬̪̹͚̞̼̠͕̼̠̦͚̫͔̯̹͉͉̘͎͕̼̣̝͙̱̟̹̩̟̳̦̭͉̮̖̭̣̣̞̙̗̜̺̭̻̥͚͙̝̦̲̱͉͖͉̰̦͎̫̣̼͎͍̠̮͓̹̹͉̤̰̗̙͕͇͔̱͕̭͈̳̗̭͔̘̖̺̮̜̠͖̘͓̳͕̟̠̱̫̤͓͔̘̰̲͙͍͇̙͎̣̼̗̖͙̯͉̠̟͈͍͕̪͓̝̩̦̖̹̼̠̘̮͚̟͉̺̜͍͓̯̳̱̻͕̣̳͉̻̭̭̱͍̪̩̭̺͕̺̼̥̪͖̦̟͎̻̰_Ỏ̷͖͈̞̩͎̻̫̫̜͉̠̫͕̭̭̫̫̹̗̹͈̼̠̖͍͚̥͈̮̼͕̠̤̯̻̥̬̗̼̳̤̳̬̪̹͚̞̼̠͕̼̠̦͚̫͔̯̹͉͉̘͎͕̼̣̝͙̱̟̹̩̟̳̦̭͉̮̖̭̣̣̞̙̗̜̺̭̻̥͚͙̝̦̲̱͉͖͉̰̦͎̫̣̼͎͍̠̮͓̹̹͉̤̰̗̙͕͇͔̱͕̭͈̳̗̭͔̘̖̺̮̜̠͖̘͓̳͕̟̠̱̫̤͓͔̘̰̲͙͍͇̙͎̣̼̗̖͙̯͉̠̟͈͍͕̪͓̝̩̦̖̹̼̠̘̮͚̟͉̺̜͍͓̯̳̱̻͕̣̳͉̻̭̭̱͍̪̩̭̺͕̺̼̥̪͖̦̟͎̻̰ ด้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็_ด้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็
