Author Topic: Ur most used SSD  (Read 3964 times)
Ur most used SSD
« on: Tue, 12 March 2019, 09:40:26 »
@ 1.5 years on dis' one
only 58.5 Terabyte written.
214979-0
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Ur most used SSD
« Reply #1 on: Tue, 12 March 2019, 11:05:09 »
Sir, yes sir!
3754 hrs
« Reply #2 on: Tue, 12 March 2019, 11:09:28 »
Sir, yes sir!
3754 hrs
Buh, how many Jiggabites written ?. ?
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #3 on: Tue, 12 March 2019, 11:47:25 »
Sir, yes sir!
3754 hrs
Sectors (512) written: 5012069568 which I think maths to ~2.4TB.  My guest OS's, ISO builds, and downloads are managed via spinning rust.  Though the SSD does handle swap/page cache, etc.
I'm like 4-5 Debian ISO builds deep right now without sleep--brain is kinda mushy atm
Offline SBJ
  • Tactile pls
« Reply #4 on: Tue, 12 March 2019, 12:43:43 »
Most used SSD has 16,5TB written. 20k on hours.
That's... really not a lot.
« Reply #5 on: Tue, 12 March 2019, 12:56:15 »
and people love to argue about SSDs wearing out.. as if..
Offline FreeCopy
« Reply #6 on: Tue, 12 March 2019, 13:30:38 »
12989 GB
25081 Hours
Keyboards
Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104 |  Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
Offline Leslieann
« Reply #7 on: Tue, 12 March 2019, 23:10:04 »
Second oldest (8 years)
36,192 hours
154 TB written
My newest... 8 months old
3346hours - 21TB written
Looking at your responses, I write a lot of data.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #8 on: Wed, 13 March 2019, 12:46:15 »
I've had my SSD since August, 9 2018.  Most of my writes were YT videos, swap space, system updates, occasional software compiling, and Firefox.
« Reply #9 on: Wed, 13 March 2019, 12:51:40 »
Doesn't show writes but another software showed around 41TB
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #10 on: Wed, 13 March 2019, 13:01:33 »
Oh no :(
« Reply #11 on: Wed, 13 March 2019, 13:10:06 »
Oh no :(
41 TB on a 240gb MLC drive should be fine. Maybe overheat or sumtn'
Offline The_Boom_Boy
« Reply #12 on: Fri, 15 March 2019, 08:51:27 »
Around 4 years of consistant daily use. Main boot/everything disk. Really amazing. I would have never known. Guess I am not that hard core...   :(
« Reply #13 on: Fri, 15 March 2019, 09:33:05 »
/Headscratch
I wonder how samsung meters their endurance,  the spec sheet says 140TB on the 500gb drive, so. how can 33TB write not put Any dent in that at all ?
Offline Leslieann
« Reply #14 on: Fri, 15 March 2019, 20:24:47 »
It's going to say good because even at 33% used, it still has tons and tons of life left.
Most data just sits there is only moved around for wear leveling.
At current wear rates it has 6-8 years of life left before it's expected to even start compensating for wear. Why warn you about it now?
If they did it would just cause you to become concerned, buy another and complain about how it started to wear out before you expected it to.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Leslieann
« Reply #15 on: Fri, 15 March 2019, 20:42:44 »
36,192 hours
154 TB written
I've been looking at these numbers and I'm pretty sure it's wrong.
This would put this drive pretty much at the end of it's lifespan, which is certainly possible, however the amount of data it would need to write in order to make it to this point seems impossible.
« Last Edit: Fri, 15 March 2019, 20:51:56 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline fanpeople
« Reply #16 on: Fri, 15 March 2019, 21:37:14 »
215368-0
I bought this brand new start of 2014 IIRC.
« Reply #17 on: Fri, 15 March 2019, 21:53:41 »
Mine is rated for 220TB, and having written 59TB, my lvl is 87%,  assuming it wasn't full cycles, that at least make sense.
To put it at 100% is a bit misleading.
Offline Leslieann
« Reply #18 on: Sat, 16 March 2019, 00:42:06 »
It's probably a buffer, where as long as it's above a certain amount it reads 100%, this keeps people from freaking out and thinking something is wrong when there isn't. BMW had to do to their temp gauges when people started buying for the name rather than performance. The would freak out if the needle went above the mid point even though it was perfectly within normal operating temps.
To a degree, it makes sense, like I said, you wouldn't want someone seeing 80% and thinking they needed to run out and replace it even if it had years of perfectly normal life left.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #19 on: Sat, 16 March 2019, 03:03:08 »
/Headscratch
It is interesting how writing all that data hasn't resulted in any drop in health on the chart.
