Author Topic: how you handle less than TKL ?  (Read 6469 times)
Offline mapple
« on: Mon, 18 March 2019, 14:55:48 »
hey guys as in topic........
I did bought matias tactile pro - even though I'm windows user -> just for sound....... nevertheless constantly hitting fn + ins/del for pg up/down is driving me crazy. Now I've been struggling with idea how you guys are working anything less than this ???????? seriously no arrow keys f1/12..... what you do for living ? Even if you doing dev jobs -> vi can't be everything.... right ???????? hhkb/pok3r/anne and so many others........
Not programmer myself but doing a lot of OS scripting and really struggle to understand - can you please enlighten me a bit to remove that itchy thing from my head please ?
« Last Edit: Mon, 18 March 2019, 15:33:10 by mapple »
In God We Trust
Offline Tactile
Re: how you handle less than TKL ?
« Reply #1 on: Mon, 18 March 2019, 15:19:26 »
This comes up all the time and it's not worth covering again. Some people don't like 60% boards and some do. Really no surprise there. Here's Bjarne Stroustrup, the guy who invented C++ - check out those two (!) HHKB he's sitting in front of.
215594-0
REΛLFORCE
Offline mapple
« Reply #2 on: Mon, 18 March 2019, 15:28:45 »
yah got that - but this is literally question about how you manage life without all those missing keys ? (*not if you are pro/against such a layout) my opinion doesn't matter in this case
In God We Trust
Offline Sup
« Reply #3 on: Mon, 18 March 2019, 17:21:12 »
The thing is we dont miss the keys. We got Them on a second layer. It's better less arm movements.
current
Coming soon
Offline Leslieann
« Reply #4 on: Mon, 18 March 2019, 18:07:26 »
How I handle it is I put my GH60 in a box back in a deep dark corner of the basement and pull out a TKL.
It may be less arm movement but it may not be as fast or efficient depending on how many keys/layers you need. With enough time, sure, I can see it being faster, but to what degree and how much time and brain power I'd need to get there isn't worth it for most people. I want to get on a compter and do what i want, not memorize what key and layer I hid the tilde key or print screen.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Hypersphere
« Reply #5 on: Mon, 18 March 2019, 18:20:36 »
@mapple: Anything more than 60% is a waste of space!
Seriously, though, I resisted going 60% for a long time, depite many recommendations for the HHKB. I finally took the plunge, and after a surprisingly short time, I adapted to the 60% form factor and the layout.
BTW, I do a great deal of writing and some coding in my work, which also involves molecular modeling.
Most of the time, I use an HHKB, but I like variety and vintage boards, so I use some TKLs and some full-size keyboards. However, I remap all of them to something as close as I can get to the HHKB layout.
It's all about what you value and getting accustomed to new things. I especially like the symmetry of a 60% board, enabling it to be centered under my computer monitor and not having to reach as far for the mouse.
Offline HPE1000
  • Keycap Paparazzo
« Reply #6 on: Mon, 18 March 2019, 19:34:31 »
The 60% layout is perfectly fine as far as I am concerned. Anything less is when you actually start running into problems with usability imo.
Offline mkkeyboardvigilante
  • Location: Atlanta, GA, thocking, clicking, and clacking away depending on my mood
« Reply #7 on: Mon, 18 March 2019, 20:44:45 »
HHKB took me a bit to get used to, but now I'm able to seamlessly go from that board to my other ones whenever I want. It's one I like to switch back to every so often, and one where once I replace those black keycaps, I'll be using a whole lot more too. I even got used to accessing the arrow keys with FN on there too, so I don't think I was missing out on too much. I already used Karabiner Elements to program some other stuff onto all my boards, so I'm covered there.
Current driver: HHKB Pro 2 (BKE Ultra Lights), Wooting One w/ Flaretech Red switches and HyperX PBT keycaps.
Other keyboards I own and like: Realforce 87U Variable Weight, Realforce 87U 55g, Niz Plum, Magicforce 108 Gateron Reds w/ O-Rings.
Other keyboards I have: Magicforce 68 Cherry MX Brown, Havit Low-Profile Kailh Blue, Logitech K740,
Yeah, it's a loooooooooooot of keyboards. :P
Offline Lanrefni
« Reply #8 on: Tue, 19 March 2019, 09:33:29 »
I don't handle it,that's why I have a BFO-9000,104 key split ortho FTW.
Offline Polymer
« Reply #9 on: Tue, 19 March 2019, 09:37:27 »
You just have to get used to the second layer.  Once you get used to it or figure out what works for you,  it becomes very easy to go smaller.
If you do find a huge reliance on those other buttons, it could just be that your workflow doesn't allow you to leverage a second layer very well...
I do think though that the biggest gain in space is moving to TKL...while you gain the same amount of space it going to 60% from TKL, it is more just empty space for me...
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #10 on: Tue, 19 March 2019, 10:39:53 »
I ****ing hate layer keys. I don't even like TKLs, they're too limited for me.
Offline Telstar
« Reply #11 on: Tue, 19 March 2019, 11:55:35 »
I think nobody standardized the best layout for current PC era. A few functions are needed (F1 or F2 to enter bios, F5 to refresh), then keep arrows, printscreen, home and del and optionally some media keys. Rest is basically useless nowadays. The numpad is another matter and could well be taken separately and used during i.e. spreadsheet work.
So currently I prefer TKL and use some functions as either macros or media keys and keep ignoring half of the extra keys up right.
Offline mapple
« Reply #12 on: Tue, 19 March 2019, 16:33:06 »
thank you guys for all the input ! still admire the ones able to work like that. Love the community here !
In God We Trust
Offline F0xdude
« Reply #13 on: Tue, 19 March 2019, 18:43:53 »
Like many others have said, using layers is key. Specifically, I like to use tap functions so that I can have layers anywhere that I want. My favourite usage of this is making the colon key a layer when held, and then assigning arrow functions to ijkl. It's really nice, and makes correcting typing mistakes very fast!
hope this helps
« Reply #14 on: Tue, 19 March 2019, 20:51:11 »
It entirely depends on how often you use those missing keys..
For example, you don't see pr0 starcraft peeps playing on HHKB..
Coding is not a keyboard intensive task.  You spend the majority of time thinking.
Chatting with your friends has higher keyboard utility rate than coding.
C++ inventor using HHKB is demonstrative of that very fact.
Offline thearctican
« Reply #15 on: Tue, 19 March 2019, 23:19:32 »
If I did more numerical data entry I'd probably be in the same camp.
Offline no, the other guy
  • actually, this guy
« Reply #16 on: Thu, 21 March 2019, 03:04:12 »
I usually just buy a large container, take the less than TKL, gently put it inside and slowly walk away from the scene.
« Last Edit: Thu, 21 March 2019, 03:25:26 by no, the other guy »
<armin> i have the impression the only reason the mx red switch was invented was drunk people
Unicomp PC122 (review) * IBM Model F XT * Dell AT101W
Offline chyros
  • a.k.a. Thomas
« Reply #17 on: Thu, 21 March 2019, 03:24:02 »
Tbh even at home I prefer a fullsize, even though I do nothing work-related there.
Jesus, it's worth having the numpad JUST for the Enter key IMO!
Offline appaboy
« Reply #18 on: Thu, 21 March 2019, 08:20:01 »
Yeah that key is so comfortable but I myself use tkl with left side numpad and I mapped a button on my mouse to enter key but it's less satisfying as smacking that numpad enter
PC Singa, MIR80, TX84se, g80-3314, g80-0427, g80-5000 + 5700, G80-3700, g81-3000 HBU (og wob)
HASRO keycaps
OG POM keycaps
SAI OG Italian dyesubs
Scarface Fn blank
Offline Leslieann
« Reply #19 on: Thu, 21 March 2019, 18:59:51 »
I admit, I miss this.
Soooo satisfying.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline phinix
« Reply #20 on: Fri, 22 March 2019, 06:20:51 »
I also have problems using less than TKL boards. I so much want to like them, like for example I just got Varmilo 69keys version, but I keep hitting wrong keys just because arrows cluster is moved to the left just a bit, then it totally breaks my brain, when trying to use End key, which is missing on that board. I cannot use keyboard without End key apparently! I need it to fix mistakes in lines I write, jump back to words in a sentence, then jump back to end of line. I noticed I've been doing it for ever, then now, when using 65% board, I hate using second layer...:(
For me, perfect solution would be "Function row-less" keyboard - Simply TKL with cut off F row.
Offline Telstar
« Reply #21 on: Fri, 22 March 2019, 07:54:18 »
Half the function keys are very important, i use a lot F2 (to edit a filename and to enter bios), F5 (browser refresh, less now that i bound that to center mouse button too) and F11 (browser fullscreen). So are half of the other extra keys on a TKL (begin, end, and prtscr).
I have started to make my custom layout for these reasons.
Offline phinix
« Reply #22 on: Fri, 22 March 2019, 09:24:44 »
Custom layout, interesting. Can you your ideas?
Offline Telstar
« Reply #23 on: Fri, 22 March 2019, 12:05:16 »
Yup. I was planning to do a dedicated thread, but u can see it here:
https://i.postimg.cc/qMmg4Hd6/t1.jpg
Offline phinix
« Reply #24 on: Fri, 22 March 2019, 17:50:00 »
Damn, this is too messed up for me:)
Offline thearctican
« Reply #25 on: Fri, 22 March 2019, 17:57:45 »
Ah it's not that bad. But I don't see how that's different functionality wise from something like a 96key or Scarlet Bandana, S65+, or JER Mini. The last 3 just put their macros to the left.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #26 on: Fri, 22 March 2019, 19:32:47 »
I use a 60% slim folio membrane keyboard. I can handle anything except 30% because it doesn't have the things that i need.
Just my thoughts
Offline Telstar
« Reply #27 on: Fri, 22 March 2019, 23:36:10 »
Scarlet Bandana and Jer mini - have no numpad nor the 6 functions I need (but macros can be remapped). They are not similar at all.
I'd rather have more keys than less.
96-kees gets close. The main difference is in the spacing, the placement of DEL and a few more nuances. I consider my layout an improvement of that with better spacing and some more useless keys removed, like the numpad always active. I could probably adapt one of those PCBs, though.
Edit: googling 96 keys i found the Leopold FC980M which has proper spacing of the arrow keys. So that is the closest thing to my ideal layout. I could as well get one and customize the case since I would have to resolder the switches anyway.
« Last Edit: Sat, 23 March 2019, 10:59:40 by Telstar »
