Author Topic: thoughts on laptops with forward keyboards?  (Read 3534 times)
Offline Danny356
« on: Sat, 11 May 2019, 02:58:23 »
https://www.asus.com/us/ROG-Republic-Of-Gamers/ROG-ZEPHYRUS-GX501/
ive never seen anything like this but it seems like this would be ideal if youre gaming with your laptop on a table.
seems more ergonomic and you dont have the trackpad in the middle of your keyboard like 99% of laptops get in the way. I imagine it also stays cooler more often than other laptops.
thoughts?
Offline Leslieann
Re: thoughts on laptops with forward keyboards?
« Reply #1 on: Sat, 11 May 2019, 05:46:21 »
There's been a few that way, Sony has done it a few times, just 2 years ago or so on the SVD convertible.
I personally hate it, I want my keyboard placed further from me than that.  I also prefer small laptops and that means there's not enough room on the side like there is on that monster.*
Yes, it's only a 15in screen, I prefer 11.6 or smaller.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #2 on: Sat, 11 May 2019, 09:52:57 »
A laptop with integrated wrist rest can very well be used in the lap when snuggled up in a settee or in bed.
One without can be comfortably used only on a desk IMHO.
The very first IBM ThinkPads back in the '90s had no wrist rest in front of the keyboard, and with only a TrackPoint for pointing, they were relatively narrow. There was even a compact one that had a keyboard wider than the computer.
I expect that the reason in this case was not for style or a new way of use, but for fitting a larger heat sink for the CPU and GPU. I find this form factor to be ridiculous: expensive components without small size nor upgrade path.
« Reply #3 on: Sat, 11 May 2019, 09:59:40 »
I've used one, they're alrite.  15/17 inch are both kind of small for long-term use,  this keeb orientation makes that even smaller.
Offline abrahamstechnology
« Reply #4 on: Sat, 11 May 2019, 11:00:01 »
What is even the point of a "slim" laptop that has such a huge footprint anyway?
The only thing that accomplishes is it dying in a few years due to board flex or the LCD breaking.
« Reply #5 on: Sat, 11 May 2019, 16:02:08 »
Thinness doesn't make the LCD less durable. Board flex is mainly bad case design/ lack of rigidity.
Laptop LCDs are really only good for 10000 hours anyway, so it's not that big a deal. If you use a laptop with any real frequency, 3-4 years you should change out the LCD for a Fresh one.
If you look at laptop parts LCD ratings , they're only rated for 5000 hours. before they dim significantly
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #6 on: Sat, 11 May 2019, 21:03:42 »
Trackpad on the side is better in most cases because due to my trackpad sensitivty being too high sometimes i misclick while typing.
thoughts?
Just my thoughts
