Author Topic: Logitech G305 mouse USB receiver hard to pull out of receptacle or just me?  (Read 21855 times)
Offline Scoox
Just got a G305 wireless mouse, so far I'm extremely satisfied with it. The only odd thing I've noticed, considering how beautifully designed and built it is, is that the USB nano-receiver is kinda hard to pull out from its storage slot because it doesn't have a flange around the top, and there isn't enough room for me to get a good grip on it even with my non-sausage fingers. Just wondering if other people have noticed this or is it just my mouse? If it's normal I'll just stick some tape on it to function as a pull-out tab.
« Last Edit: Sat, 18 January 2020, 02:19:52 by Scoox »
Offline Leslieann
At least it has a slot for it, the Anywhere 2 mouse doesn't.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
just drill some holes and stick it in the bottom.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
Smh just hammer it
Just my thoughts
Offline Scoox
The sticky tape did the trick. Still, it's a pretty stupid design. The mouse is OK overall but the various design flaws start to show after a while, this is just the first one I noticed.
Offline chale_moore
Wireless USB always create issue.
Offline Leslieann
No, they do not.
Stop buying garbage mice and stop spreading this BS, lag and stability really hasn't been an issue on Logitech (and a few others) for a VERY long time.
Dongle placement is the most common problem people have. Range claims are line of sight, it really should be as close as possible (I recommend less than 2 feet) and certainly not the back of the case or monitor since those are purposely designed to block radio signals.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Natalia259
I am using Logitech but it's not good for regular work.
HP or Dell is far better.
Offline Leslieann
The lowest end Logitech stuff is pretty much always white label Chinese garbage, I don't even need to look that up to know it's most definitely very low end Logitech.
And no Dell is not better or better or worse, everything bottom end is this way, the Dell and HP you are comparing to is not bottom of the barrel. I've seen HP and Dell that are every bit as horrible as that Logitech.
Low end stuff is almost always white label because it's cheap and allows then to use the same parts on multiple keyboards, they just change the shell a bit and screen a different name on them. 10 minutes on Ebay and amazon I bet you could find 4 other keyboards with that exact basic shape and curve across the bottom keys, pretty sure I've used the HP (or Emachines) version of that (and yes, it sucked).
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Cough.. it's been a while, no one's said it yet though, so..
// That's what She-Said //
Offline absyrd
  • CPT HYPE PADAWAN
Re: Logitech G305 mouse USB receiver hard to pull out of receptacle or just me?
« Reply #10 on: Sat, 22 February 2020, 02:00:52 »
I had this same problem. Haha.
Like the mouse so far, though. Thanks, tp. Although, I find myself accidentally right clicking once in a while... perhaps my last mouse just had a harder click.
