Author Topic: anyone use NVME to sata adapters? [Updat]  (Read 6657 times)
« on: Sat, 08 February 2020, 08:47:41 »
Update::
Finally received, tuned it up.   NO GO,  overheats.  There's not enough clamping pressure on this design..
GDI, the hunt continues.
_______________________________________________________
OKokok.. After 3 weeks of deliberation.  Tp4 has finally decided to purchase this orico enclosure.
Decision base::
1.  Clamshell design, securing harness force in the Direction of the external casing. This is important, since it's far more difficult to ensure good thermal contact in slide-in type cases.
2.  Cable adapter type, instead of direct stick-type.  With these really long levers, mishap could break the adapter or the laptop port. Cable seems safer.
2.  It's $36 vs $Bajillion for the 40Gbps adapters.
3.  $Bajillion 40Gbps adapters seem ill-advised since pcie 4.0 future drive compatibility on such adapters is not a certainty as they're so new.
236772-0
236774-1
_______________________________________________________________
So, TP4 boughz 2 many Sn750s,  no where to put, gonna stuff in laptop sata slot
Has anyone used these mpcie to sata adapters, are they reliable ?
Offline absyrd
  • CPT HYPE PADAWAN
Re: anyone use NVME to sata adapters?
« Reply #1 on: Sat, 08 February 2020, 11:16:08 »
I just had a usb-c nvme enclosure that didn't work for ****. No clue about sata adapters.
Offline Almost
  • Zs Xe
« Reply #2 on: Sat, 08 February 2020, 11:29:04 »
Ya they're fine. Make sure you have room as nvme's are typically longer than an ssd enclosure when u factor in the adapter size, might not fit in a laptop bay slot.
You'll limit the nvme to < 600gb/s tho, probably not noticeable less u work with BIG files
Kbds: KOBO Red Carbon - Filco MJT2 Beige - Topre U23 - Cherry 3700 - Model F XT 5155
Sets: Dolch R1 - Red Alert - Hyperfuse R1 - Cherry WoB - Plum
« Reply #3 on: Sat, 08 February 2020, 13:45:19 »
Just chked,  it seems they don' even make Nvme to sata.
They make Nvme to U.2  only ??
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #4 on: Sat, 08 February 2020, 14:25:46 »
USB-C? Or is your computer old poop and you lie about your spex?
« Reply #5 on: Sat, 08 February 2020, 14:26:37 »
LOLOL, yea looking at the usb-c nao.  kinda steep for the high end one.. hrrrm...
There'a brand called Wan foc yu.. HAHAHAHAHAHA
235375-0
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #6 on: Sat, 08 February 2020, 14:35:11 »
I wan fuc yo, too, by burning up your fucing nvme.
« Reply #7 on: Sat, 08 February 2020, 14:41:38 »
hahahhaahahhahaahahhewjkekekekekekeek
« Reply #8 on: Sat, 08 February 2020, 14:43:23 »
seems like this is the cheapest one with Intel JHL6340 Thunderbolt 3 bridge for 40Gbps ?
https://www.amazon.com/WAVLINK-Thunderbolt-External-Enclosure-Included/dp/B082F376TK
« Reply #9 on: Mon, 02 March 2020, 19:01:33 »
Decision base::
236768-0
236770-1
Offline absyrd
  • CPT HYPE PADAWAN
Re: anyone use NVME to sata adapters? [Updat]
« Reply #10 on: Tue, 03 March 2020, 01:22:12 »
Just get the cheaper 3.0. I have 4.0 on my mobo, but the only "cheap" option for SSD for it is a 1tb sabrent at $200 (which is faster than what I have, but not peak speed claimed by 4.0).
« Reply #11 on: Wed, 04 March 2020, 05:47:04 »
Looks nice and shiny, doesn't have a possibly offensive logo - good choice assuming it works.  Looking forward to your inevitable performance analysis :thumb:
« Reply #12 on: Tue, 17 March 2020, 18:00:12 »
Offline Leslieann
« Reply #13 on: Tue, 17 March 2020, 19:30:35 »
We long since passed the point of diminishing returns, which seems to be somewhere around 600-800MB, WAYYYY below even what 3.0 drives can do.
Benchmarks are fine and good, but it's not always indicative of real world performance. Not to mention, just like NVME, most of the 4.0 drives are just 3.0 drives shown to be forward compatible with a higher price tacked on (slow ones at that). I have a 4.0 drive, it's slower than my 3.0 drive, which even while being one of the faster ones is not noticeably faster than my fastest sata ssd.
To really go faster we need an architecture change, not just in hardware but in software as well. A lot of things were done in the past to combat slow drives, now that we have fast drives those same tweaks are now hurting performance.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #14 on: Fri, 20 March 2020, 08:29:13 »
Ok, dis' one, works. FINALLY. sigh....
Peak temperature 45C passive cooling @ sustained 800MB/s transfer.
This Slug type case has a flat bed, to which a 1.5mm pad fits neatly beneath the ssd, and you can push on it, because there are no components to bend and snap off on a docking pcb.
This particular design is also nice because you get to conduct heat directly to both sides of the enclosure.
The top, I used a 1.25mm thermal pad,  between the ssd and bottom plate I used a 1.5mm pad. Very snug and because the bottom is FLAT, there's no pcb bending. BENDING is dangerous.
The included 1.5mm white top Thermal pad is the wrong height and will bend your ssd Pcb. It's also taped on and removing it destroys the pad, so you gotta have your own. (<.<)
Also have to supply a 1.5mm pad for between the ssd and bottom plate, this pad is crucial for increasing and evening the mounting pressure.
VS,  This other common type, where the docking pcb has stuff beneath along the whole length, Which will bend if pressured. Not a fan of this type of design.
238139-2
238143-3
« Reply #15 on: Fri, 20 March 2020, 16:19:52 »
That looks reassuringly hefty, what brand/model is it?
« Reply #16 on: Fri, 20 March 2020, 16:21:48 »
It's really heavy, lots of pocket sag, LOLOL,
Sabrent is the main importer of this model state side.
There's another generic under eluteng.  They sell refurb of the sabrent model on ebay for $20ish.
The eluteng is $32 on amazon. and the sabrent is $40
I also tried out an actively cooled one,  DON"T,  it turns on and off the fan dependent on the powerstate of the device, it's annoying as hell if you leave it plugged in for long.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #17 on: Fri, 20 March 2020, 16:37:43 »
I might grab one. Thanks for doing the heavy lifting.
« Reply #18 on: Fri, 20 March 2020, 16:52:04 »
You need the 1.5mm and 1.25mm thermal pads. for this model,  1.5 between the ssd and base, 1.25 between ssd and top plate  if you don't mind a slight protrusion on top, you can use 1.5 there as well.
they sell 1mm and .1 and .25mm thermal pads, you can get a pack of each and roll your own.
