Author Topic: Rear ports.  (Read 4168 times)
Rear ports.
« on: Sun, 09 August 2020, 21:06:30 »
So.... u know dat' dell laptop Tp4 got,  well the Rear USB port is right above the main heatpipes.
Was copying files to a usb-thumb drive, and it began to thermal throttle.  Didn't know this could happen to thumb drives.
Tested on different ports away from the heatpipes, it copied at full speed.  anything with a cable also ran fine.  The port's hot to the touch.. Bad design.
Offline jamster
Re: Rear ports.
« Reply #1 on: Sun, 09 August 2020, 21:19:48 »
Laptops have USB ports on the back? That strikes me as some pretty bad design regardless of whether it's affected by heat.
Offline Leslieann
Re: Rear ports.
« Reply #2 on: Sun, 09 August 2020, 21:45:33 »
They can very much temp throttle.
The plastic housing hides how hot they can get, I have metal USB sticks that reach about 70c/158f on the housing. I have one that got over 80c/176f.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Re: Rear ports.
« Reply #3 on: Sun, 09 August 2020, 22:28:56 »
Yea, apparently it's all the rage with these g4m3r laptops.
Offline Leslieann
Re: Rear ports.
« Reply #4 on: Mon, 10 August 2020, 00:18:03 »
Rear ports are bad anyhow, tilt the screen and oops you just crushed a stick or port.
About the only thing I don't mind coming out the back is the network cable. Anything else gets damaged or damages the mainboard when it gets hit.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline jamster
Re: Rear ports.
« Reply #5 on: Mon, 10 August 2020, 00:43:54 »
Well, there's the problem right there. Cramming too much heat producing stuff into too small a space, and you end up with all sorts of compromises and bad design decisions.
Offline Leslieann
Re: Rear ports.
« Reply #6 on: Mon, 10 August 2020, 22:54:56 »
That describes pretty much every gaming laptop.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline jamster
Re: Rear ports.
« Reply #7 on: Mon, 10 August 2020, 23:13:54 »
Uh, that's pretty much what I was saying :)
Personally, I buy laptops for longer term manufacturer support, and the ability to easily upgrade parts by myself. Pretty much the complete opposite of what gaming laptops have to offer.
Any aspirations to performance are reserved for desktop cases.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
Re: Rear ports.
« Reply #8 on: Tue, 11 August 2020, 21:44:26 »
they be like WHRRRRRRRRR when you first start them up.... holy it gets loud during a simple game of arsenal.. like chile dell designers
Just my thoughts
