Author Topic: which vaccine y'allget'n've'got'n  (Read 30396 times)
« on: Tue, 11 May 2021, 14:47:37 »
Fizer
Modna
Jj
Which vaccine top gud ??
Offline Sniping
Re: which vaccine y'allget'n've'got'n
« Reply #1 on: Tue, 11 May 2021, 16:01:34 »
think they're all pretty good choices. it seems like in the real world the efficacy rates are a little lower than in the testing so it seems that pfizer and moderna provide even more thorough protection. we're pretty lucky to have a choice of top tier vaccines though. i ended up getting a moderna
Offline Faceman76
« Reply #2 on: Tue, 11 May 2021, 16:57:27 »
Moderna.  Otherwise than the second shot kicking my butt, no complaints.
My job is a petri dish and ever since the vaccine was offered, the percent of ill staff went from 10% to almost zero.
Sent from my SM-G975U using Tapatalk
1800s and heavy springs
« Reply #4 on: Tue, 11 May 2021, 17:23:53 »
I got Pfizer and was pleased with it. I had no ill effect from the first one, and a bit of discomfort from the second one. I would describe it as the equivalent of a cold or mild hangover for a couple of days. The arm was a bit sore when touched for a few days.
- D Trump 2026-10-24
Offline F eq ma
« Reply #5 on: Tue, 11 May 2021, 17:50:28 »
Pfizer here.   No side effects thankfully.   The way I see it, there may be a risk of still getting covid, but hopefully it is super mild due to the vaccine knocking it down.  I know people who have dealt with full on covid.   It is not nice.   Don't wish that crap on anyone, even my enemies.
Offline phinix
« Reply #6 on: Tue, 11 May 2021, 17:53:21 »
Astra Zeneca - had first one over two months ago and was fine, no side effects.
I'm having second shot in two days, will se how it goes.
« Reply #7 on: Tue, 11 May 2021, 18:05:12 »
If the second shot gives you a bigger reaction, isn't it an indication that the first shot worked correctly ?
Offline Faceman76
« Reply #8 on: Tue, 11 May 2021, 18:48:20 »
If the second shot gives you a bigger reaction, isn't an indication that the first shot worked correctly ?
Not exactly.
I know several people who came down with COVID between their first and second shots.
Offline Leslieann
« Reply #9 on: Tue, 11 May 2021, 20:29:12 »
Most people don't get much of a choice and honestly, get what you can as soon as you can.
Despite the efficacy rates, which are highly flawed, all are better than nothing and all probably work pretty equally well.
Typically...
First shot is a mild, unless you've had Covid, then it will feel like a second shot does to most people.
Second shot will be worse.
For anyone thinking screw the second shot because the first sucked, however bad the first one was, Covid is worse. Imagine that for 1-2 weeks, and hopefully without any lingering effects, which is almost guaranteed (just not talked about). The shot sucks, Covid is worse, get the shot.
Also, something they aren't telling people is the milder symptoms and how long they can last.
Weird dreams, started with Covid and lasted 6 months, got the shot, they came back, lasted week and a half
Weird random aches and pains or itching - Lasted a few weeks, came back after the first and second shot.
Unable to sleep, sleep pattern wrecked - Lasted a few weeks, came back after the first and second shot.
Queazy stomach, started just after Covid and lasted 5 months, came back a few days after shot, went away days before second shot. Returned for second shot.
And this was in multiple mild cases of people I know, including myself and a nurse, who herself wasn't even aware of this until we started talking about it.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #10 on: Tue, 11 May 2021, 20:32:01 »
Was I not supposed to fill a syringe with bleach?
« Reply #11 on: Tue, 11 May 2021, 21:51:39 »
Yes, of course, but did you follow it up with a UV light up your butt?
« Reply #12 on: Wed, 12 May 2021, 06:39:36 »
Gettn' chipped 2day.  /Maximum Nervous.
Vaccine should come with free 3 months of netflix
« Reply #13 on: Wed, 12 May 2021, 07:59:59 »
Installed.  Just waiting the 15 minutes now. Half expect to explode in a bloody mist.
« Reply #14 on: Wed, 12 May 2021, 08:12:36 »
That's what happened to me. Now all that's left is my bot posting on Geekhack.
« Reply #15 on: Wed, 12 May 2021, 08:50:32 »
Back @base,
no sensation whatsoever, YET.
BUT WHAT IF,  the pharmacists are sneaking out the viles to be sold on the black market, and all Tp4 got was saline ?   It's not like walgreens pays /treats employees well.
Offline yui
« Reply #16 on: Wed, 12 May 2021, 08:56:13 »
not gonna lie, 1st one i can get for me, although in theory not until mid June... still hoping to get a leftover dose before that though.
Offline Darthbaggins
  • PC Cannibal
« Reply #17 on: Wed, 12 May 2021, 09:17:00 »
I'm either going w/ Pfizer or J&J, would prefer J&J since I want to be one and done - but over-all the Pfizer appears to be the good as well (even with a dual stage shot).   But I will be waiting to get it so I can see how the initial test subjects faired with the shots.
« Reply #18 on: Wed, 12 May 2021, 10:14:40 »
Gettn' some arm soreness @ injection site.
« Reply #19 on: Wed, 12 May 2021, 10:36:41 »
Getn' supr sore shoulder now,  Could the tech have injected the wrong spot ?  IS THERE a wrong spot ?
Offline Faceman76
« Reply #20 on: Wed, 12 May 2021, 10:46:22 »
Completely normal.
« Reply #21 on: Wed, 12 May 2021, 10:48:37 »
They could have injected it into a nerve and the entire bolus is making its way through your nervous system straight into your brain.
Offline Leslieann
« Reply #22 on: Wed, 12 May 2021, 11:17:10 »
It's normal, it will be sore for a day or two, doesn't matter how well the injection was made it messes with the muscle there.
Be prepared to do pretty much nothing tonight and tomorrow.
Also get something for fever and pain, you may get lucky and not need it this time but you more than likely will for round 2.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #23 on: Wed, 12 May 2021, 11:36:27 »
This is it guys, This is how Tp Dies.
« Reply #24 on: Wed, 12 May 2021, 11:37:48 »
can't even piano,  tried play some dat quak3, lost to cpu 9/10 hardcore.
« Reply #25 on: Wed, 12 May 2021, 14:05:23 »
I had a fever over 100, tired, headache, cold symptoms on the 3rd and 4th day after my 2nd shot. Day 4 I was ill all day, actual sickness. Woke up on the 5th day after shot and felt amazing. So be aware you could be fine right after, then days later get quite sick.
1st shot I just got a sore arm
Offline glibber
« Reply #26 on: Wed, 12 May 2021, 14:10:17 »
I got Biontech last Friday and don't think I've died yet. I didn't feel anything actually, so maybe I did in fact die.
« Reply #27 on: Wed, 12 May 2021, 14:31:08 »
no soreness either?
Offline glibber
« Reply #28 on: Wed, 12 May 2021, 16:01:24 »
no soreness either?
No, I had absolutely no effects actually. The doctor told me to go a bit slower that same day, which I did, but I did quite a lot the next day actually and had no problems. Maybe a placebo ;D
Edit: typo
« Last Edit: Wed, 12 May 2021, 16:03:59 by glibber »
Offline Sniping
« Reply #29 on: Wed, 12 May 2021, 16:44:39 »
i was super sore too. it goes away quicker than soreness from working out. time to get a good pump on the other shoulder to even it out
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #30 on: Wed, 12 May 2021, 17:01:51 »
i read sometimes people accidentally inject into the fat instead of the muscle, and that ends up hurting more.
but the pain seems pretty normal. got my 2nd last week. my arm hurt for three days, and i felt like poop overall for the first two.
all better now.
« Reply #31 on: Wed, 12 May 2021, 18:07:04 »
all better now.
Not gettn' sick feelings on this first shot, but like sniping said, it's like a really bad workout soreness.
That said, does anyone understand if them t-cells gon' destroy deltoid muscles cuz they is using them to manufacture the spike protein ? (unless Tp4 is not understanding the diagram.. )
« Reply #32 on: Wed, 12 May 2021, 19:53:52 »
not feeling dying o' nothing, buhhhh this is extremely annoying, should've gotten it on Left arm..
So, lesson for y'all ,  Get it on your NON-mousing arm.
Do they need to go in the same arm for second shot?
Offline Leslieann
« Reply #33 on: Wed, 12 May 2021, 23:03:27 »
It's up to you.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #34 on: Wed, 12 May 2021, 23:16:52 »
I got Moderna. Zero side effects either time except a sore arm for 12 hours. Kinda was hoping for a little more immune response to show it was working, but I guess I shouldn't complain.
Offline Herman
  • college student
« Reply #35 on: Thu, 13 May 2021, 04:07:34 »
pfizer baby
moderna aint too bad but something about j&j susses me out heavy
one and done >:(
« Reply #36 on: Thu, 13 May 2021, 06:35:06 »
22hrs from installation now, Tp4 arm still @ sore, but it hasn't exceeded max tolerance. Pain lvl @ steady state. Quak3 scores still down.
It's up to you.
Is it m0ar effective if it's the same arm, because them mrna already once hijacked dat muscle cells to spawn spike proteins ?
pfizer baby
one and done >:(
Yea, it seems a gud' idea to double chk this one, even though, in theory, they're all one and done.
Offline Leslieann
« Reply #37 on: Thu, 13 May 2021, 06:53:37 »
According to the nurse, it doesn't matter.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
  • PC Cannibal
« Reply #38 on: Thu, 13 May 2021, 07:58:46 »
I would prefer to alternate shoulders so the other gets to enjoy the pain as well.
« Reply #39 on: Thu, 13 May 2021, 10:32:45 »
no soreness either?
Internet says Fizer /astra 66% vaccine recipients reported arm pain,  ~25% reported side-effects outside of arm.
78% arm pain moderna
Offline phinix
« Reply #40 on: Thu, 13 May 2021, 11:19:12 »
I had my second dose 3 hours ago and now I feel very weak, tired as hell, arm numb, nothing else.
« Reply #41 on: Thu, 13 May 2021, 11:39:30 »
/gasp,  make sure to get massage against clots.
« Reply #42 on: Thu, 13 May 2021, 19:54:42 »
24 hours post injection Shoulder-pain was @ 7/10.
36hrs pain now reduced to 5/10
« Reply #43 on: Fri, 14 May 2021, 00:44:38 »
I was told specifically to NOT massage the shot area by the doc who pricked me, but to raise your arm and shake it to distribute the vaxx
Offline phinix
« Reply #44 on: Fri, 14 May 2021, 01:31:50 »
Yes, that is correct.
« Reply #45 on: Fri, 14 May 2021, 06:41:51 »
@48 hours,  Pain is reduced, 1/10,  Only noticeable with intentionally strong deltoid contractions, such as arm over head.
« Reply #46 on: Fri, 14 May 2021, 11:06:15 »
Virtually pain free now. Shoulder only sore if intentionally squeezed.
« Reply #47 on: Fri, 14 May 2021, 11:48:29 »
The entire human race can now breathe a sigh of relief.
« Reply #48 on: Fri, 14 May 2021, 11:54:49 »
It's only a matter of time before Concentrated animal feeding operations (CAFO farming) breed the NEXT pandemic.
All major pandemics are zoonotic in origin (comes from animal interactions)
« Reply #49 on: Fri, 14 May 2021, 11:55:45 »
268354-0
