Author Topic: Q : What are the different 10 keyless with no space between Esc F-keys 123qwe  (Read 2179 times)
Offline tns
Hey!
///* /!\ another question : do they all use PBT keys?
edit : my bad i meant cherry mx
Thx ;)
« Last Edit: Mon, 24 December 2012, 18:06:34 by tns »
Offline Leslieann
Most, if not all backlit are ABS.
Keycool, Noppoo and KBT all make smaller tkl keyboards like you want.
Noppoo, I believe uses PBT. KBT uses ABS keycaps, and I would imagine Keycool does as well, as both are backlit.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline tns
my bad i mean Cherry*
Offline IvanIvanovich
  • Mr. Silk Underwear
All the boards Leslieann listed use Cherry MX switch. The KBT Race have non backlight version with PBT available, and the Noppoo Choc mini use PBT but only on the white version, the dark version use POM.
If you mean Cherry literally, only 'white' color models in the G84 with ML switch and G86 with rubberdomes lines would meet that description. Cherry never made any such board with MX besides the G80-5000 that even comes close.
« Last Edit: Mon, 24 December 2012, 17:23:48 by lysol »
Offline tns
uh what is Leslieann ?
EDIT : oops sorry
(I meant Cherry MX ^^ thx u all!)
So there might only be
KBT Race (those with Fkeys)
Noppoo Choc mini
DECK
Keycool 84
then :o ok thx u!
if any other one please tell me :D
« Last Edit: Tue, 25 December 2012, 08:08:51 by tns »
Offline Hyde
  • White Tofu Extraordinaire
Uh you mean a 75% board like Vortex KBT Race or Noppoo Choc Mini?
On some of the models yes they do have PBT keycaps.  Like These
OR
Deck 82 - Ice
http://www.deckkeyboards.com/product_info.php?products_id=30
However I think Deck keyboards are kind of ugly but that's just my opinion :P
« Last Edit: Mon, 24 December 2012, 18:31:17 by Hyde »
I always forget about deck... I even owned a TG3 once. Yes, they also have pbt key, but I did not like them at all or the board for that matter. If you like it though I would reccomend to look for TG3 Data911 model instead. It's the same thing but has better font and can often be had used on ebay for $30 or less sometimes.
Offline tns
OR
Deck 82 - Ice
what is 75% ;o ?
OR
Deck 82 - Ice
what is 75% ;o ?
smaller keyboards.
Just buy the Quick Fire Rapid in whatever switch you want. and a separate PBT keycap set from geek feng on ebay, or from Qtan's vandio store.
That is literally the BEST choice for beginners..
There are NO better options.. There's no more research you need to do.
Offline MissMurd3r84
  • In IRC wondering why Kmiller8 is yelling.
The username of the person that replied to your post...  :confused:
KBC Poker - Red switches. Noppoo Choc Mini - Black switches. Leopold FC700R (White) - Blue switches. Ducky YOTD - Brown switches. Razer BW - Blue switches and rusted.
