Author Topic: Ergo Clear vs Topre  (Read 56408 times)
Re: Ergo Clear vs Topre
« Reply #100 on: Fri, 03 May 2013, 03:35:05 »
right all i'm saying is the line between "scratchy" and "tactile" is that they're the SAME sensation , with the exception that scratchy is LESS pronounced enough to be Tactile.
Think of a perfect plastic piston head and a cylinder which becomes slightly narrow in the centre. Pushing and pulling the piston head would have very different properties in an oiled vs non-oiled arrangement. They would both fit the definition of tactile, but one would definitely be perceived as "scratchy" or "sticky".
ah.. you can't throw up a description like that without mspaint.. i can picture most of it but how is that tactile, are you pulling against vacuum?
Offline Trev
« Reply #101 on: Fri, 03 May 2013, 03:46:23 »
No perfect vacuum seals for this example. We're talking about keyboard mechanics :)
It's possible to have a very similar resistance profile, but still feel quite different with and without a lubricant. Something being "tactile" doesn't imply or inherently include "scratchyness" and stick-slip type properties, but doesn't exclude them either.
« Reply #102 on: Fri, 03 May 2013, 03:48:26 »
um.. i don't want to argue the word tactile with you.. LOL
I used tactile to mean, the BUMP feeling vs the scratchy feeling "non-tactile"
this is an oversight on my part, so I'll use bump from now on..
BUMP and Scratchy is the same sensation, with varying frequency.
Offline rknize
    • metaruss
« Reply #103 on: Fri, 03 May 2013, 10:58:22 »
The "scratchiness" of the tactile switches seems to mainly come from the stem guides.  You can feel it on linear switches too, especially those with lighter springs (reds).  The tactile bump feels the most scratchy because that is when the peak side-load on the guide occurs.  It doesn't seem to come from the friction between the bump on the stem and the leaf spring, which explains why lubing that spot seems to make no difference in the feel of the switch.  Lubing the stem guides helps the most.
So by smoothing out the action between the stem and the guide, the tactile bump itself seems to become more obvious.  In some ways it reminds me of this Topre.  ;)
Russ
« Reply #104 on: Fri, 03 May 2013, 13:04:54 »
this seems to happen on the bottom the most.. I've lubed the sides, but it doesn't help that much.. because after a while even high vis' lube just gets pushed to the middle, and you see a clear part where the contact is being made without any lube on the corners of the side channel..
this is why I've remained unconvinced of lubing switches.. maybe a hard lube.. pencil lead for example. but obviously not that cuz of the conductivity.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #105 on: Fri, 03 May 2013, 18:12:42 »
Who has a Quickfire Rapid, Poker, and/or scale?
SmallFry! <3
Offline daerid
    • Rossipedia
Ergo Clear vs Topre
« Reply #106 on: Fri, 03 May 2013, 21:01:40 »
Man I hate reading this forum on Tapatalk, cuz then I end up seeing TP's posts, and that makes me sad.
There's a common Internet idiom about trolls and feeding them. Probably a good idea to heed that one. Anybody who's been here for more than a few days has got him pegged, so just ignore him, and we'll all thank you for it :-)
Offline klxw
« Reply #107 on: Fri, 03 May 2013, 21:18:48 »
mechanical != scratchy
I mean mostly harsh bottoming out, and undamped upstroke.
Exactly what I thought when I tried some keyboards with Cherry MX switches. Everywhere on the internet everyone was talking about how awesome MX switches were, but no one mentioned the ultra harsh feeling when bottoming out? Weird.
Offline Trev
« Reply #108 on: Fri, 03 May 2013, 21:32:17 »
It feels like Cherry is too comfortable with their market position, there's been no innovation or progress in switch design for a very long time. The Cherry landing is simply plastic smashing against plastic, totally un-dampened. Surely they could start adding new models with some minor refinements and tighter tolerances?  It would be a clever move considering the growing enthusiast niche.
Offline rknize
    • metaruss
« Reply #109 on: Fri, 03 May 2013, 21:42:24 »
I'll drink to that.  Cherry's production volume seems to have been bought-out for some time thanks to these gaming and mainstream keyboards.  Don't get me wrong; it's great to see "normal" mechanical keyboards in places like NewEgg and even some brick-and-mortar stores.
I wonder if we'll see anything new on the "Alps" front, given Cherry's monopoly on that design and the current shortages.  Perhaps we'll see more come out of Matias and the like.
While I am not totally in love with Topre, I hope to see some interesting form factors come out going forward.  This new high-profile Topre switch is a sign that they are still doing a little R&D.
Russ
Offline 002
  • Topre Enthusiast
« Reply #110 on: Fri, 03 May 2013, 21:57:37 »
Offline Trev
« Reply #111 on: Fri, 03 May 2013, 21:59:33 »
I don't personally understand the HiPro thing at all. Seems like a product that almost nobody really needs or ever wanted. I've also heard that HiPro switches aren't great to type on.
It seems like Topre would see much better success in embracing Bluetooth as an option across their range, PBT spacebars, new designs in 60%ish form factors, lower profile "modern" keys that are still sculpted, etc. Topre is also guilty of being fairly complacent with their position and not really innovating (imo).
I'd love to see more companies going for minimal, lower-profile designs that still retain decent typing ergonomics. Most outsiders see our keyboards as "old fashioned" looking or "retro". I think chiclet keys are a terrible choice, but it couldn't hurt to build some leaner/meaner looking models.
« Reply #112 on: Fri, 03 May 2013, 22:33:29 »
mainstream japanese engineers are obsessed with uniformity/ perfection.. So thats why pbt spacebars are a no-no. they just can't make straight ones..
Offline Michael
  • Formerly Bro Caps
« Reply #113 on: Fri, 03 May 2013, 22:38:32 »
If imsto can make a straight PBT bar, so can the Japanese. Maybe they just don't see it as an important issue.
Offline Trev
« Reply #114 on: Fri, 03 May 2013, 22:44:34 »
I wish they'd address this. Having the fairly refined sounding <thock thock thock> Topre PBT's interrupted by the all too familiar (cheap sounding) ABS spacebar is a bit jarring :)
They should also consider improving the noisy space bar design and stabilizers while they're at it. Spacebar is the worst part of the Topre typing experience (imo).
Offline Michael
  • Formerly Bro Caps
« Reply #115 on: Fri, 03 May 2013, 22:51:05 »
The space bar issue isn't as bad on the Type-S. The only thing that bothers me about it, is how shiny it gets.
Offline Trev
« Reply #116 on: Fri, 03 May 2013, 22:55:00 »
Agreed, my Type-S space has far less rattle to it. They've also added those little landing pads on the HHKB spacebar. You'd need to slam it fairly hard to contact them, but it's a nice touch which isn't on the RF boards.
Part of the issue on the RF is that the stabilizer tabs don't lock in firmly enough. If you use something like the thick EK "mech lube" on these it temporarily resolves much of the spacebar noise.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #117 on: Fri, 03 May 2013, 22:55:24 »
I tend to not read long spam.
SmallFry! <3
Offline khaangaaroo
« Reply #118 on: Sat, 04 May 2013, 00:45:54 »
Okay. Has anyone weighed their Topre 10keyless or HHKB? What would their weight be comparing to something like a Quickfire Rapid or Poker?
Are Topre noticeably lighter or heavier then a Cherry keyboard.
Realforce 86u with stock PBT key caps, without cable: 2lbs 7.4oz (1,120 grams)
Quickfire Rapid with thin ABS doubleshots: 1lb 15.8oz (900 grams)
Offline davkol
  •  Post Editing Timeout
« Reply #119 on: Sat, 04 May 2013, 01:34:12 »
Maybe that's why so many people are obsessed with not bottoming out. It is mentioned from time to time, but I don't think it's a bug—rather a feature. It's the same with generic ALPS clones and most vintage switches. Solutions such as dampened Matias ALPS are sometimes considered mushy.
« Reply #120 on: Sat, 04 May 2013, 01:37:07 »
bottom-out is such a none issue on any switch type given that you can oring the keycaps.
Offline Trev
« Reply #121 on: Sat, 04 May 2013, 01:44:26 »
It's a bug :)
I finally scored an AEKII w/ALPS in good condition and was pretty disappointed with the switch feel. Heavy and mushy. I remembered them being so much better. :)
Maybe they were never that great to begin with? There doesn't appear to be anything wrong with the switches themselves, they're not gunked up or anything like that. It seems hardly used aside from case yellowing.
Back the RF spacebar issue; I've just finished putting mine back together. Some very thin rubber landing pads + generous krytox 205 on the stabilisers has it feeling way better. I'm not sure how long it'll last, but right now it's all <thock> with no rattle or clack. There's also no mushyness from the 205 once it worked in.
Offline Aranair
  • Software Engineer @ PocketMath
    • Tech blog
Ergo Clear vs Topre
« Reply #122 on: Sat, 04 May 2013, 02:15:52 »
Just to chip in... Although I'm pretty happy with a HHKB at work (just bought another to use at home), I honestly can't say that it's that much better than MX switches..
I've used a filco blue for awhile, then brown poker for about a year before switching to a hhkb. (I've also had a hhkb for 1 month during the 1year with the poker, but sold it.)
And I'm now buying blue mx switches to change my poker. Generally though, I'll say I am rather undecided between topre and mx brown/blues and am not convinced either is better than the other. (And I love the 60% size so RF isn't really an option lol)
Present  : HHKB Pro 2 Type-S White | HHKB Pro 2 White Blank | Ergodox EZ
Past      :  Poker 2 Brown | Black Widow Ultimate Blue | Filco TKL Brown
Offline davkol
« Reply #123 on: Sat, 04 May 2013, 02:51:30 »
It's a bug :)
From the ergonomic point of view, it's not really that much of an issue, because you don't have to (and shouldn't) bottom out. I think the optimal solution would be increasing force required to bottom out. Something like Fujitsu Peerless or Cherry MY, or Cherry MX Blue w/ soft-landing pads work for me this way. MLs and clears are close to that, but need longer key travel IMO.
For the upstroke, thick keycaps appear to be at least some workaround.
« Reply #124 on: Sat, 04 May 2013, 03:17:38 »
Personally the feel between the Topre I tried, albeit rather briefly but right next to a rubber dome Logitech board, felt too similar to justify the cost. Now as I charge my flame shield I will only say that I'm a Cherry man because  1)Cherry switches feel drastically different than the crappy boards I've typed on my whole life  2)They come in many flavors so you can always switch it up and get completely different feels Cherry to Cherry  3)They are just hands down easier to mod and tinker with and I am a big fan of that customization component. I wouldn't buy a Topre without trying one first to make absolutely sure your $300 is going where you want it to. If you try it and love it, more power to you.
« Reply #125 on: Sat, 04 May 2013, 03:25:13 »
:D
Flame shield indeed required..
but yea. i felt the same way when I first got my 87u... underwhelming...
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #126 on: Sat, 04 May 2013, 06:37:21 »
Hmmm. Looks like I have new reading material for today :)
Offline MJ45
  • HHKB Pro
« Reply #127 on: Sat, 04 May 2013, 07:25:13 »
Let me start by saying I'm a keyboard enthusiast and anyone who is a GH member is also. That being said I have owned and tried my fair share of keyboards. Topre switch keyboards seem to generate a lot of opinions, pros and cons. But only one that is important to me and anyone considering one is their own, by using one and seeing if it is right you. I purchased a HHKB Pro 2 and found that I prefer the Topre based switches the most. I felt that the HHKB would be easy to sell if I didn't like it, but I do so much that I got a Reaforce 87u 55g. Between the the two is what I use 95% of the time, the 87u for desktop use and HHKB for my laptop. I still prefer the Cherry MX based keyboards for gaming use. In my opinion any enthusiast owes it to themselves to find out. In my case I would have saved a bunch of money if had earlier in my quest for my perfect keyboard(s). But I have no regrets, some love them and some don't but you don't have much lose to find out in my opinion.
Offline daerid
    • Rossipedia
« Reply #128 on: Sat, 04 May 2013, 14:03:47 »
+1
Offline TheQsanity
  • SmallFry Lovin'
« Reply #129 on: Sat, 04 May 2013, 14:12:38 »
What's the difference from the HHKB and the Realforce? Does it have something to do with how heavy it is? What makes some of them cost 400 500 bucks?
SmallFry! <3
Offline eth0s
  • Peace & Love
« Reply #130 on: Sat, 04 May 2013, 14:13:05 »
Yes, I agree, you have to buy multiple keyboards to figure out what you like.
HHKB Pro and RealForce cost around $270 at this time, due to Yen/Dollar exchange rate.
$400 HHKB Pro is the Type-S, which is the silent version.  Also Silent RealForce is more expensive as well.
I dunno why, I guess the silent switches cost more to manufacture.
« Last Edit: Sat, 04 May 2013, 14:16:19 by eth0s »
« Reply #131 on: Sat, 04 May 2013, 14:36:08 »
LOLOL, HAHAHAHAHA, calling me a hater when you don't even know the topre basics
« Reply #132 on: Sat, 04 May 2013, 14:42:02 »
Great now after reading this thread through I not only want to try ergo clears but now I want to try a topre board!
« Reply #133 on: Sat, 04 May 2013, 16:51:29 »
The topre 660 groupbuy is definitly worth it.. good price/ form factor.. the ugly 87s on the other hand.. blechhhhh.... why did they put that lip on top...
cheapest way to get ergo clear now, is to get an ergo dox.
Offline Macsmasher
« Reply #134 on: Sat, 04 May 2013, 21:00:10 »
Key switches on the HHKB are PCB mounted. The Realforce are plate mounted. Personally, I prefer plate mounted.
Offline 002
  • Topre Enthusiast
« Reply #135 on: Sat, 04 May 2013, 22:09:12 »
Switches on the HHKB aren't PCB mounted, rather the upper housing of the switch is all moulded as one piece.
I know what you mean though, and I prefer the metal plate in the Realforce too :)
Offline Macsmasher
« Reply #136 on: Sat, 04 May 2013, 22:42:25 »
I had heard they were PCB mounted. Thanks for the correction.
Offline daerid
    • Rossipedia
« Reply #137 on: Sun, 05 May 2013, 00:26:33 »
"Case-mounted" would be the most accurate term.
Offline MJ45
  • HHKB Pro
« Reply #138 on: Sun, 05 May 2013, 08:39:57 »
The HHKB's design with its low weight and small size is why I got it, for on the go use with laptops nothing comes close. I agree that plate mounted is better, for desktop use where size and weight doesn't matter the 87u 55g is my choice.
Offline 002
  • Topre Enthusiast
« Reply #139 on: Sun, 05 May 2013, 16:05:33 »
Makes sense to me; I've always said that you should buy an HHKB for it's portability and layout. The Topre switches are just a bonus  ;)
Offline kelske
  • The North Borders
« Reply #140 on: Sun, 05 May 2013, 18:37:48 »
This thread has been a great read.
My take away is: try them all until you find which one you like most.. A Shine II with Clears in the mail and dibs on Boost's 660C GB I'm planning to do just that ;D
Yay keyboard party! Yay justification on buying more boards!
Edit: Here's said Group Buy for the 660C if anyone's interested: http://geekhack.org/index.php?topic=43134.0
« Last Edit: Sun, 05 May 2013, 18:56:34 by kelske »
« Reply #141 on: Sun, 05 May 2013, 21:30:51 »
Isn't it the general(keyword) consensus that ergo clears are the best MX switch?
Offline daerid
    • Rossipedia
« Reply #142 on: Sun, 05 May 2013, 21:39:52 »
I'm pretty sure there is no general consensus. Lots of people like lots of switches.
« Reply #143 on: Sun, 05 May 2013, 23:12:09 »
M.... as far as "tactile" cherry mx goes, people usually settle on MX clears because it maintains the high level of tactility like that of MX blue, without the "sharp" click sound.
mx brown doesn't really feel like tactile..  unlubed it feels like a grain of sand stuck in a cherry mx-red switch..
once you lube the brown, it feels like a smoothed out grain of sand, so kind of like "a slow spot" of resistance near the actuation point,
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #144 on: Sun, 05 May 2013, 23:14:38 »
Couldn't agree with this post more. I'll know what lubed browns will feel very soon before I turn it into an ergo-clear. I will have to see which one I prefer between the Clears and erg-clears and sell the least favorite.
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
Re: Re: Ergo Clear vs Topre
« Reply #145 on: Sun, 05 May 2013, 23:49:31 »
lolno.  A lot of people love them, but there's nothing even close to a consensus.  Arguing about switch preference is the raison d'etre of the forum. ;D
All these switch threads come down to a few objective descriptions of weight, tactile vs linear, etc., a lot of arguing and assertions about preference, and tp4tissue trolling Topre people.
Ultimately you gotta catch em all to know what's best for you.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #146 on: Sun, 05 May 2013, 23:52:19 »
Lol! I only have a full keyboard of Ergo-clears and a Topre to own/try out... Ergo-clear in the progress and I'm too hobo for Topre just yet.
Offline Jocelyn
  • 조셀린
« Reply #147 on: Sun, 05 May 2013, 23:53:47 »
If you don't get one by the time I get to Orlando, I'll buy one and let you borrow it for a week :P
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #148 on: Sun, 05 May 2013, 23:55:27 »
That 660C??? I know how much you love those 60%/like 60% layout :P I'm so tempted to rob my neighborhood and buy one of those :P
« Reply #149 on: Sun, 05 May 2013, 23:59:44 »
I don't troll Topre people.. I keep them in line....   >:D
