Author Topic: [REVOTE!] Increase Maximum Avatar Size Poll  (Read 38978 times)
Offline baldgye
  • Will Smith Disciple
Re: [REVOTE!] Increase Maximum Avatar Size Poll
« Reply #150 on: Wed, 08 May 2013, 17:06:40 »
Are you trying to be ignorant or does it just come naturally?
Well ...I guess I'm done here.
Offline esoomenona
  • Gnillort?
« Reply #151 on: Wed, 08 May 2013, 17:10:38 »
Even bumping it up to 150x150 is a lot. Isn't it crazy that a small 50px increase in two planes more than doubles the content of a 100x100px image?
Offline Soarer
« Reply #152 on: Wed, 08 May 2013, 17:11:56 »
And again I ask (as I did with the signatures), if you don't like seeing people's avatars, and/or want to limit their size, WHY NOT JUST TURN THEM OFF?!?!
I think some people just like being contrarian.
Bollocks!
I happily turn off sigs, but NOT avatars, I like them and they don't break the reading flow.
I just don't want them any bigger.
Offline Glissant
« Reply #153 on: Wed, 08 May 2013, 17:12:04 »
esoomenona, yeah it's a huge difference really, but it's also the max amount I would go for if we got the option. If we don't get the option that really isn't a problem ;) .
Offline Soarer
« Reply #154 on: Wed, 08 May 2013, 17:15:11 »
I think any change should be a majority decision. Get 11350 'yes' votes and I'll STFU.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #155 on: Wed, 08 May 2013, 17:16:52 »
To be fair, it took like 3 to change sigs
Offline Soarer
« Reply #156 on: Wed, 08 May 2013, 17:19:13 »
Well, if 1 of those was an admin... democracy is out the window!
Offline Dubsgalore
« Reply #157 on: Wed, 08 May 2013, 17:22:31 »
Re-Vote for Dubs: 150
Offline Tarzan
  • formerly known as Greystoke
« Reply #158 on: Wed, 08 May 2013, 17:38:06 »
No.  I prefer the smaller avatar icons.
I'd also vote for the option to read posts with no icons or profile info, as an alternate view.  That way I can turn off the panel to the left and see posts as a list.
Offline E TwentyNine
    • Some of My Keyboards
« Reply #159 on: Wed, 08 May 2013, 17:48:34 »
As a workaround, hit the print button in the lower right corner...
Offline Tarzan
« Reply #160 on: Wed, 08 May 2013, 17:51:20 »
Yes, like that!  Except with the gray/orange color scheme...
Thanks for the tip!
Offline rknize
    • metaruss
« Reply #161 on: Wed, 08 May 2013, 18:02:03 »
To be fair, the sig rules were a little unclear.  The restrictions that we had in mind were not very effective, so I tried to fix it.
In case you haven't noticed I've been going around fixing bugs and adding features that were in our backlog. This was simply one of them.  Admittedly, it caused more drama than I expected.
Russ
Offline Soarer
« Reply #162 on: Wed, 08 May 2013, 18:09:11 »
Ach, you didn't get my drift... my aging memory recalls iMav saying that GH was "not a democracy" :D
(and nor should it be... expensive things, democracies!)
Offline rknize
    • metaruss
« Reply #163 on: Wed, 08 May 2013, 18:15:29 »
Heh...well that is true where iMav is concerned. :))
I meant to quote sir Klaxon there.
Russ
Offline SmallFry
« Reply #164 on: Wed, 08 May 2013, 18:25:32 »
So uh... /me grabs popcorn.
Offline Glissant
« Reply #165 on: Wed, 08 May 2013, 18:31:05 »
You're way too late for the show, SmallFry ;).
Offline rknize
    • metaruss
« Reply #166 on: Wed, 08 May 2013, 18:31:26 »
Let's get back to avatars...
Russ
« Reply #167 on: Wed, 08 May 2013, 18:47:37 »
TROLLS: demik,
LOL
topic is still stupid and will go nowhere.
« Reply #168 on: Wed, 08 May 2013, 18:52:26 »
TROLLS: demik,
LOL
You only wish you could make that avatar bigger! (Actually I think my avatar is the only pic I could find and it's no bigger really)
And I am sad, your avatar is cooler than mine. You're like Girlshark 2.0
« Reply #169 on: Wed, 08 May 2013, 18:54:53 »
impossible! nobody can be cooler than the original.
Offline Leslieann
« Reply #170 on: Wed, 08 May 2013, 19:07:03 »
Notice how it skews Halverson's post? It looks bad and makes it harder to read.
Now imagine it doing that, all the way down the page and it varies depending on their avatar.
This isn't an exaggeration, it's actually what you would get by simply upping max avatar size.
I scaled Halverson's avatar and pushed over the post how it will actually look. Yes, you can set the column to a single size, however it;s not as easy to do as you think, and changing that one table setting, can have REALLY strange repercussions if that same setting is used someplace else, which is what happens a lot when using stylesheets, which the forum does use.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
« Reply #171 on: Wed, 08 May 2013, 19:09:07 »
You have unnecessary padding... The padding is there for the words, not the avatar...
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
« Reply #172 on: Wed, 08 May 2013, 19:09:40 »
Leslieann has a good point. The only way it would work is if it was changed to a column size as wide as our avatars. Maybe someone who actually would be working on this, if it happens, chime in on this issue.
Offline Leslieann
« Reply #173 on: Wed, 08 May 2013, 19:15:19 »
You are severely over simplifying this.
If you reduce the padding so Halversons's doesn't push things over, you also reduce the padding on all of the others, possibly skewing the entire thing to the left, without actually accomplishing anything at all. Not only that, I haven't seen a padding tag for text. You can pad an image or table, but not JUST text... In which case ANYTHING that gets close to the table is going to push the cell over.
Again, stylesheets, you cannot just randomly change padding in one thing without fear of it changing padding on something else.
I have setup and themed almost half a dozen sites like this. It's not that easy. I;m not saying it can't be done, but that it's not as simple as to just go into a setting and change it.
Plus, every forum update, now has to have that change added to it manually.
Oh, and not everyone is reading from an HD screen...
« Last Edit: Wed, 08 May 2013, 19:17:23 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline The_Ed
« Reply #174 on: Wed, 08 May 2013, 19:21:08 »
When you change the maximum avatar size, it will change the left column size accordingly. Then it will all be uniform.
R.I.P.ster
Offline sth
  • 2 girls 1 cuprubber
« Reply #175 on: Wed, 08 May 2013, 20:04:15 »
Bollocks!
hear hear
you want to display art, take it somewhere appropriate.
« Reply #176 on: Wed, 08 May 2013, 20:04:29 »
Are you running Firefox or Chrome?  Hold down the CTRL key, mousewheel up until the avatars are as big as you like.  Problem solved.  :D
Offline The_Ed
« Reply #177 on: Wed, 08 May 2013, 20:09:11 »
Zooming in just makes ugly pixels...
R.I.P.ster
Offline rarar
  • moist booty seepage
« Reply #178 on: Wed, 08 May 2013, 20:27:56 »
pixelation
Ỏ̷͖͈̞̩͎̻̫̫̜͉̠̫͕̭̭̫̫̹̗̹͈̼̠̖͍͚̥͈̮̼͕̠̤̯̻̥̬̗̼̳̤̳̬̪̹͚̞̼̠͕̼̠̦͚̫͔̯̹͉͉̘͎͕̼̣̝͙̱̟̹̩̟̳̦̭͉̮̖̭̣̣̞̙̗̜̺̭̻̥͚͙̝̦̲̱͉͖͉̰̦͎̫̣̼͎͍̠̮͓̹̹͉̤̰̗̙͕͇͔̱͕̭͈̳̗̭͔̘̖̺̮̜̠͖̘͓̳͕̟̠̱̫̤͓͔̘̰̲͙͍͇̙͎̣̼̗̖͙̯͉̠̟͈͍͕̪͓̝̩̦̖̹̼̠̘̮͚̟͉̺̜͍͓̯̳̱̻͕̣̳͉̻̭̭̱͍̪̩̭̺͕̺̼̥̪͖̦̟͎̻̰_Ỏ̷͖͈̞̩͎̻̫̫̜͉̠̫͕̭̭̫̫̹̗̹͈̼̠̖͍͚̥͈̮̼͕̠̤̯̻̥̬̗̼̳̤̳̬̪̹͚̞̼̠͕̼̠̦͚̫͔̯̹͉͉̘͎͕̼̣̝͙̱̟̹̩̟̳̦̭͉̮̖̭̣̣̞̙̗̜̺̭̻̥͚͙̝̦̲̱͉͖͉̰̦͎̫̣̼͎͍̠̮͓̹̹͉̤̰̗̙͕͇͔̱͕̭͈̳̗̭͔̘̖̺̮̜̠͖̘͓̳͕̟̠̱̫̤͓͔̘̰̲͙͍͇̙͎̣̼̗̖͙̯͉̠̟͈͍͕̪͓̝̩̦̖̹̼̠̘̮͚̟͉̺̜͍͓̯̳̱̻͕̣̳͉̻̭̭̱͍̪̩̭̺͕̺̼̥̪͖̦̟͎̻̰ ด้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็_ด้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็
Offline Leslieann
« Reply #179 on: Wed, 08 May 2013, 21:09:33 »
No, it doesn't, column width is an independent setting and each post has it's own table, which is why you get that staggered look like I posted.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #180 on: Wed, 08 May 2013, 21:17:09 »
I don't see any problem with staggered.
Offline The_Ed
« Reply #181 on: Wed, 08 May 2013, 21:25:37 »
Perhaps I was unclear. When you choose the maximum size for avatars it will also change the size of the left column for all posts. Thus it will be uniform. The avatar wont be changing the size of an individual posts left column. The choice of maximum size will be what changes it for everything.
R.I.P.ster
Offline rknize
    • metaruss
« Reply #182 on: Wed, 08 May 2013, 22:31:56 »
That's not how style sheets work I'm afraid, at least with these templates.  The left margin object has a specific width to give the interface a consistent look.  It is not like an HTML table.  This is what a 200x200 avatar looks like on the dev site:
Also, I forgot about some of the other padding that comes from the nested style sheets.  The avatar itself currently has about 136 pixels.  That can be modified of course, but I just wanted to point out that the technical details behind this are not as simple as you think.
« Last Edit: Wed, 08 May 2013, 22:34:50 by rknize »
Russ
Offline The_Ed
« Reply #183 on: Wed, 08 May 2013, 22:57:19 »
The option to change the maximum avatar size would change that left margin object's specific width depending on your choice of size. So the left column will have a different size for each of the choices.
R.I.P.ster
Offline rknize
    • metaruss
« Reply #184 on: Wed, 08 May 2013, 22:58:20 »
Sounds fun.
Official poll is here:
http://geekhack.org/index.php?topic=43268.0
Russ
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #185 on: Wed, 08 May 2013, 22:58:56 »
It's literally like you aren't reading what he's saying at all.
Offline rknize
    • metaruss
« Reply #186 on: Wed, 08 May 2013, 23:03:19 »
I think what he wants is a user-configurable settings that will then scale avatars down to whatever size each user wants.  While it is technically possible, it is a feature that is unlikely to matter to a majority of people.  It would require quite a few site code changes, not to mention a database schema change.  I'll add it to the list, but it would be a very low priority given everything else that is there.
TL;DR: this probably won't happen any time soon.
In the meantime, lets vote on what the hard-limit should be:
Russ
Offline F u r u y á
« Reply #187 on: Wed, 08 May 2013, 23:09:29 »
I'm in favor of prioritizing content (replies and information) in detriment of meta-content (avatar, signature, etc). So my vote is No, regardless of the monitor technology! I think that in that regard Deskthority has a very good layout.
Filco 91 | Filco 87* | Filco 105 | PLU 87 | PLU 87 | Cherry 120 | Cherry 120
Offline tufty
« Reply #188 on: Thu, 09 May 2013, 06:15:34 »
I vote for leaving it alone, removing them entirely, or selecting them randomly.
Mainly for leaving them alone, though.
Offline Dubsgalore
« Reply #189 on: Thu, 09 May 2013, 08:21:52 »
Please change my vote to 150..
Offline rknize
    • metaruss
« Reply #190 on: Thu, 09 May 2013, 09:27:57 »
Official poll:
Russ
Offline SmallFry
« Reply #191 on: Thu, 09 May 2013, 09:29:28 »
Do we have polls back for good? :D
Offline rknize
    • metaruss
« Reply #192 on: Thu, 09 May 2013, 09:32:46 »
Yes, we have enabled them on a trial basis.  To keep the trolling in check, they are limited to admin and mods for now.
Russ
« Reply #193 on: Thu, 09 May 2013, 09:34:08 »
Rkinze, you've been on a real tear with the forum updates. Thank you ^__^
Fold and Multi-quote are soooo nice and I like the polls
Offline esoomenona
  • Gnillort?
« Reply #194 on: Thu, 09 May 2013, 09:35:09 »
So if we wished to have a poll, we would start a thread, PM a mod with the poll options we want, and they would put one up for us?
Offline SmallFry
« Reply #195 on: Thu, 09 May 2013, 09:35:50 »
Boo!
* SmallFry tries to create a poll to allow polls for other pollers. :P
Offline rknize
    • metaruss
« Reply #196 on: Thu, 09 May 2013, 10:01:01 »
Your welcome!  Sorry it has taken so long to starting getting momentum on this.  We spent a lot of time on the backend (especially iMav) and then everyone just took a break.  More front end changes are coming.
The main reason for bringing back polls was so that the community could vote on topics pertaining to the site in a more official way.  After the drama about signatures, it became apparent that such changes are better handled this way.
If you wish to start a poll, you can PM a mod.  We left them disabled when we relaunched because of the rampant trolling we had before.  To keep from peppering the site with a lot of obscure and tangential polls, we'd like to keep the subject matter focused on improving GeekHack for now.
Boo!
Thanks for making my point!  :)
Edit: I'd also like to point out that there is nothing stopping anyone from starting offsite polls about whatever they want.
« Last Edit: Thu, 09 May 2013, 10:02:58 by rknize »
Russ
Offline SmallFry
« Reply #197 on: Thu, 09 May 2013, 10:18:29 »
Heh. You don't think I'm the #1 keyboard expert in the world?
« Reply #198 on: Thu, 09 May 2013, 10:24:15 »
Vote in my new poll here.
Username not required! GOGOGO!
I fixed that, SmallChilliFry. ;)
« Last Edit: Thu, 09 May 2013, 10:33:43 by jdcarpe »
Offline SmallFry
« Reply #199 on: Thu, 09 May 2013, 10:30:02 »
