Author Topic: fixed gear bicycles dying off?  (Read 3866 times)
Offline dante
« on: Sat, 29 June 2013, 20:51:18 »
I noticed a lot less activity at the fixed gear gallery.  Also some brands have been dropping their fixed gear versions.
Offline kenmai9
  • Unicornforce
  • Skrrr
Re: fixed gear bicycles dying off?
« Reply #1 on: Sat, 29 June 2013, 20:59:36 »
Hipsters will only bring it back.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #2 on: Sat, 29 June 2013, 21:00:32 »
They already have....
Offline dante
« Reply #3 on: Sat, 29 June 2013, 21:04:42 »
This style bike still has merits - especially with some of us who are lazy at maintenance.
« Reply #4 on: Sat, 29 June 2013, 21:05:47 »
as much as i hate hipsters.
my respect to fixed riders.
that **** is a work out.
also, brands havent been dropping fixed gear version.
they're called track bikes, and just about every major brand has a track bike.
« Last Edit: Sat, 29 June 2013, 23:08:26 by demik »
Offline alaricljs
  • I be WOT'ing all day...
« Reply #6 on: Sat, 29 June 2013, 21:54:30 »
it's different.  Basically no.
Filco w/ Imsto thick PBT
« Reply #7 on: Sat, 29 June 2013, 23:07:21 »
Read into it..
I understand if this was part of the race requirement for bike racing.. and the training part..
But the hipster part... it's like they invented the ergodox, and you're still typing on staggared qwerty model-m because you hope that other people will think you're kewl...  EVEN though you didn't even touch a model m as a child, so it's not nostalgia..
Offline metafour
« Reply #8 on: Sun, 30 June 2013, 13:46:46 »
The trouble I found with fixed gear riding is worrying about pedal smack when cornering. I've since switched over to single speed instead as it's much easier to corner. Now I understand this is less of an issue on a actual velodrome but I'm not riding any right now.
Offline iri
« Reply #9 on: Sun, 30 June 2013, 17:56:47 »
still track bikes market is a very narrow stripe.
-Ray Bradbury
Offline sth
  • 2 girls 1 cuprubber
« Reply #10 on: Sun, 30 June 2013, 18:03:35 »
what about bmx, arn't those fix gears?
nope... that sounds like a pain in the butt! they are single speed like fixed gears but they have some sort of ratcheting freewheel-type mechanism. most bmx bikes use cassette hubs in the back, which means that the driver and pawls fit into and engage the hub, rather than having a freewheel screwed on. i think there are still some racers who run freewheels but most people have switched to cassette. the other possibility with BMX, especially for flatland, is freecoaster hubs which allow the wheel to spin backwards without engaging the cranks.
« Last Edit: Sun, 30 June 2013, 18:05:57 by sth »
Offline jalaj
« Reply #11 on: Sun, 30 June 2013, 23:38:05 »
Shorter cranks can help avoid pedal stryking. I changed mine from 170mm to 165mm, it helped.
Or use small clipless pedals. I have a combo of both, but the cranks did the trick first.
Offline Rayne
  • For Science!
« Reply #12 on: Mon, 01 July 2013, 00:35:58 »
I didnt know there were so many people here that are into bikes! I actually work in a bike shop.
Offline Leslieann
« Reply #13 on: Mon, 01 July 2013, 15:10:37 »
Probably because they weren't ever meant for normal street use.
A freewheel system is a lot more practical in the real world (and a lot easier on your knees).
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline jalaj
« Reply #14 on: Mon, 01 July 2013, 21:37:10 »
Fixies are fine primarily for flat areas. Areas that are hilly make it less practical, unless youre up for a hell of a ride.
« Reply #15 on: Mon, 01 July 2013, 22:17:38 »
speaking of..
http://www.reddit.com/r/FixedGearBicycle/comments/1hflkf/the_mountain_is_your_friend/
http://www.strava.com/activities/63614102?ref=1MT1yaWRlX3NoYXJlOzI9dHdpdHRlcjs0PTM3MTA5NA%253D%253D
almost 4k feet of climbing fixed.
hell of a ride i'd say
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #16 on: Tue, 02 July 2013, 06:46:27 »
I used to get my work on a track bike! It helps a lot with BMX Racing!
Offline badcop
  • thorpe thocking master race
« Reply #17 on: Tue, 02 July 2013, 06:52:11 »
i had a brakeless fixed gear when i lived near NYC.
but i sold it when i moved into the mountains.   :(
Offline Leslieann
« Reply #18 on: Tue, 02 July 2013, 17:51:39 »
I'll stick to my hardtail 29'er.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
