Author Topic: How much love stiff switches of GHs?  (Read 18574 times)
Offline linziyi
  • The one with many questions
Re: How much which love stiff switch of GH?
« Reply #50 on: Tue, 23 July 2013, 09:08:43 »
We should organize a group buy on super stiff springs!
Ducky DK9008G2 Pro
"Much to learn you still have" --Yoda
Offline Thimplum
  • Master of all Ponies
« Reply #51 on: Tue, 23 July 2013, 09:27:51 »
Is that a volunteer?
TP4 FOR ADMIN 2013
Offline linziyi
« Reply #52 on: Tue, 23 July 2013, 09:30:25 »
I had never organized a group buy before and don't know where to find appropriate manufacturer, but I will glad to help organizing one!
Ducky DK9008G2 Pro
Offline Thimplum
« Reply #53 on: Tue, 23 July 2013, 11:30:35 »
I was joking. I have absolutely no idea how to organize one.
TP4 FOR ADMIN 2013
Offline linziyi
« Reply #54 on: Tue, 23 July 2013, 17:39:43 »
Maybe we should start a interest check?
Ducky DK9008G2 Pro
Offline yasuo
  • spanengan puyeng newbie
« Reply #55 on: Wed, 24 July 2013, 00:53:03 »
it seems, will not be much interested
Logitech MK220 Colemak DH
Offline mapple
« Reply #56 on: Wed, 24 July 2013, 02:06:02 »
i love sitff switches reason for now using green cherry, sociecity (mean ppl around me at work doesn't appriacate sound of buckling spring but somehow they tolerate green ones...). blues are cool too but green just feels right;)
In God We Trust
« Reply #57 on: Wed, 31 July 2013, 14:05:10 »
I'm typing on Blacks/Reds with Clear springs in them (I call them Ghost Blacks/Reds) and have a keyboard with Blacks right next to it.  They feel heavier than the Blacks because even though the actuation force is a little lighter with the Clear spring, they have a heavier bottom out weight.  Since I've never been good at floating the keys, the Ghost Blacks/Reds feel heavier than normal Blacks.
better see this http://imgur.com/a/RJqM4
The Blacks and Clears have different numbers of coils.  And as someone who owns Blacks, Clears, Ergo Clears, and a keyboard with Blacks/Reds with Clear springs, I think I can say with authority that the Clear spring is heavier than Black.
Offline yasuo
« Reply #58 on: Thu, 01 August 2013, 05:28:43 »
Yes,they are almost near but Tactile heavier than Linear :rolleyes:
I have blacks and red but not for clear,unfortunately  :(
« Last Edit: Thu, 01 August 2013, 05:35:32 by yasuo »
Offline yasuo
« Reply #59 on: Thu, 01 August 2013, 05:29:56 »
Offline Grim Fandango
« Reply #60 on: Thu, 01 August 2013, 07:07:56 »
Personally I just can not deal with the heavy , stiff switches. They literally hurt my fingers. I am also a fairly light typer and I think that over the years, I am just starting to type lighter and lighter.
My first mechanical keyboard was the Steelseries 7G, and although I like how it felt, in the end it was just too stiff and rigid for me. After using almost exclusively 45g switches since then, it might feel even worse now. I remember that it felt especially bad for my pinkies whenever I spent a lot of time typing with few breaks.
« Last Edit: Thu, 01 August 2013, 07:09:40 by Grim Fandango »
Offline Lupizza
  • Kung av Sverige!
« Reply #61 on: Thu, 01 August 2013, 10:31:05 »
>implying grim fandango is a light-switch subhuman
Left geekhack 2013-08-24, because of rude and arbitrary moderators.
Offline yasuo
Re: How much love stiff switch of GH?
« Reply #62 on: Fri, 02 August 2013, 04:00:44 »
:p
« Reply #63 on: Fri, 02 August 2013, 05:38:07 »
main problem with stiff switch is that most keyboards are NOT stiff when we're growing up, so most people's typing technique is NOT adapted to stiff switches.
Fro stiff switches, you need Quick attack and release.  This way your fingers will not tire,  it's like typewriters and pianos.
for softer  switches you have lots of "mush-room" because you can just meander through the keys.
If you try to mush down a stiff switch without quick-attack, you will tire your fingers pretty quickly.
Offline yasuo
« Reply #64 on: Fri, 02 August 2013, 06:54:22 »
good quotes :thumb:
what you use also stiif switch?
« Reply #65 on: Fri, 02 August 2013, 08:32:11 »
good quotes :thumb:
for a while 4 months or so, ergo clears, because they were all the RAGE.
I've swapped back to stock clears :D
« Reply #66 on: Fri, 02 August 2013, 08:40:55 »
good quotes :thumb:
^^ see I always knew there was something good about you TP....stock clears FTW!!!
Offline Tarzan
  • formerly known as Greystoke
« Reply #67 on: Fri, 02 August 2013, 12:44:30 »
In order to train my fingers properly for the two Model M's I have incoming, I'm using a Ducky Pro with MX Greys at work.
30227-0
I also use a military surplus Marquardt keyboard, the weight keeps people from borrowing it off my desk.
30229-1
« Reply #68 on: Fri, 02 August 2013, 13:07:50 »
How are you liking the greys?
How would you rate them versus clears, besides one being linear and one tactile ?
Offline linziyi
« Reply #69 on: Fri, 02 August 2013, 13:57:56 »
How are greys compare to greens?
Ducky DK9008G2 Pro
Offline esoomenona
  • Gnillort?
« Reply #70 on: Fri, 02 August 2013, 13:58:52 »
One of them clicks.
Offline Tarzan
« Reply #71 on: Fri, 02 August 2013, 14:18:13 »
The MX Greys are nice, but some of that could certainly be because of the uber-thick dyesub caps on the DK9008G2.  These keyboards come with the thickest Cherry-compatible set I've ever tried, they don't have that "scratchy PBT feeling" at all.
I find the Greys even harder to bottom out than the MX Clears, the springs do feel stiffer.  But again, I haven't swapped keysets around to do a real blind test, I'm just alternating between the TG3-BL82 with Clears and the Ducky board for quick impressions.
I'm going to give the Grey board a try for a couple of weeks, get some mileage on it so I can properly gauge it versus the Clears.  I also got a DK9008G2 with Clears, but that's out on loan already.  That would be a better comparison board, as it has the identical keycaps.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #72 on: Fri, 02 August 2013, 14:22:15 »
I'm using Ghetto Greens and would definitely be up for stiffer springs, like 120g or something
Offline Photoelectric
« Reply #73 on: Fri, 02 August 2013, 14:25:32 »
How would you classify typing on Clears vs. typing on MX Blacks in terms of subjective effort?  I know they are very different, but I'm wondering if the effort is similar--mostly because it's easier to bottom out Blacks and not so easy to bottom out stock Clears.  I've only tried stock MX Blacks and 62g ergo-Clears, as I swapped Clear springs out right away.  So I never really got a good feel for stock Clears.  Just trying a couple of left-over switches on their own feels like they are not terribly heavy vs 62g Clears or stock Blacks.
For me, subjectively, 62g Clears are significantly tougher than stock Browns, but still easier than MX Blacks.
« Last Edit: Fri, 02 August 2013, 14:32:47 by Photoelectric »
Offline Tarzan
« Reply #74 on: Fri, 02 August 2013, 14:25:39 »
When I got my keyboard with MX Greens, I loved it.  Just felt right, the perfect step up from my first mechanical board, the Noppoo Choc Mini with MX Browns.
Now, after trying other key models, I think the Green board is far too loud.  It's not as "pingy" as the MX Blue board I tried, but it's definitely audible to my friends when I'm Skyping or gaming with a team.
I've given quite a bit of thought to my ideal switch type, for the ErgoDox kits I'm piecing together, and I suspect I'll settle on either MX Whites or MX Clears.  But for a full-size keyboard, it's going to be difficult to choose just one...   :-\
Offline yasuo
« Reply #75 on: Sat, 03 August 2013, 04:30:57 »
where to buy ducky mx grey? or you modded :rolleyes:
i not see selling ducky mx grey :eek: can post switch on board
sorry but thanks :cool:
« Last Edit: Sat, 03 August 2013, 04:36:57 by yasuo »
Offline Tarzan
« Reply #76 on: Sat, 03 August 2013, 06:02:45 »
It's actually a Ducky with MX Dark Greys, the linear version.  I got it from MK.com;
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=465
Offline Ekruceal
« Reply #77 on: Sat, 03 August 2013, 06:03:01 »
I'd like to try some of the stiffer switches in the future, and I do plan on eventually buying a MX Green board (because I like MX Blue so much).  So far I've only used MX Red, Brown, and Blue.
Offline Tarzan
« Reply #78 on: Sat, 03 August 2013, 06:05:28 »
If you like MX Blues, and want something with stronger switches, I think you'll really like the MX Greens.  I was really impressed by them when I tried them for the first time.
There are a couple of MX Green boards for sale in the Classifieds, last time I looked.  Cheap(er) way to try that switch type.
Offline ARod
« Reply #79 on: Sat, 03 August 2013, 19:09:06 »
I received my Pro2 with Clears on just yesterday and I love it.  Coupled with the amazing PBT keycaps, they truly are special, Ducky did a great job on them on thickness and feel.  I always felt the Browns could be a bit stiffer, to at least the 55g level the 60g of the Clears is perfect.  I think 80g would be a bit too much for my liking.
As someone else mentioned, fast and hard strokes are the way to go.  My fingers are quickly catching up to the additional 15g.
Offline yasuo
« Reply #80 on: Sun, 04 August 2013, 06:48:01 »
it's real :p
but i prefer grey tactile ^-^
« Reply #81 on: Wed, 04 December 2013, 12:30:48 »
tactile grey board coming soon....
Offline yasuo
« Reply #82 on: Wed, 04 December 2013, 12:51:46 »
yep,how do you know?
that's is syml board :p soon......:rolleyes:
« Reply #83 on: Wed, 04 December 2013, 12:57:13 »
I'm modding a board with tactile greys!! :D
Offline yasuo
« Reply #84 on: Wed, 04 December 2013, 22:13:37 »
Wow,you make also :p same :thumb:
post here if completed :)
« Last Edit: Wed, 04 December 2013, 22:20:47 by yasuo »
Offline berrymxblue
« Reply #85 on: Thu, 05 December 2013, 02:41:40 »
I think Clears are my favorite switch. I make the least amount of mistakes on it and the noise level is acceptable in most settings.
Offline yasuo
« Reply #86 on: Thu, 05 December 2013, 02:52:16 »
Sorry buddy,but clears not stiff ;)
Offline Azure Flash
« Reply #87 on: Fri, 06 December 2013, 04:47:56 »
I use car suspension springs under my keys. Also, they are buckling spring switches.
« Reply #88 on: Fri, 06 December 2013, 07:02:45 »
Nice! A fist typer!
Offline czarek
  • Keep the momentum going!
    • FalbaTech
« Reply #89 on: Fri, 06 December 2013, 07:44:30 »
I like BS and Vintage Blacks. Although I am using MX Blues on my daily driver currently.
Offline yasuo
« Reply #90 on: Fri, 06 December 2013, 07:47:26 »
BS enough stiff i think,vintage black not included :D
Offline ch_123
« Reply #91 on: Fri, 06 December 2013, 08:12:52 »
I hate 'em except for my model F.
Model F very stiffer in spacebar true or not?
You can mod the spacebar to decrease its stiffness.
« Reply #92 on: Fri, 06 December 2013, 17:25:27 »
What keycaps do you use?  Titanium?
Offline divito
« Reply #93 on: Fri, 06 December 2013, 22:51:14 »
I was hesitant on greens at first, because my trial of black switches was somewhat tiring. However, greens have been quite pleasant to not be pressed so easily as with blues, and without the annoyance of the black's linear nature.
The only fatigue happens with a lot of typing (on top of my zinc alphas), where switching back to my blues would be more beneficial. But for general usage and purposes, I prefer stiffer and tactile. I'll have a better viewpoint once I get around to trying whites and clears, and seeing where they fit in my preferences.
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
