Author Topic: Reccomend me a new PC case  (Read 26820 times)
Offline Tym
Re: Reccomend me a new PC case
« Reply #50 on: Thu, 08 August 2013, 07:40:12 »
Happy so far, slight problem if anyone can help. With this case the fans are plugged into the case not the motherboard, this means every time I turn on the PC i get a message warning me there are no fans connected (Even though they are) and I have to press F1 to boot, this is only a minor pain in the arse, anyone know how I can turn this off/stop it popping up?
« Reply #51 on: Thu, 08 August 2013, 08:04:08 »
Can't you jumper the fan headers on the motherboard so it thinks there is a fan?
Or perhaps in the BIOS you can tell it to not check for fans.
« Reply #52 on: Thu, 08 August 2013, 08:09:56 »
I have a Corsair 500R and that **** looks dope in arctic white. Tons of cooling and room for even more fans if you want, easy access side panels, plus all the cords get tucked behind the left wall and keeps them out of the way. I would defiantly recommend it.
Offline Tym
« Reply #53 on: Thu, 08 August 2013, 08:24:49 »
Bit late, I've already bought and built it :D
Offline tgujay
« Reply #54 on: Thu, 08 August 2013, 08:30:34 »
Even the CPU fans?  That sounds like a bad idea to me.
Gotta collect them all
Offline Tym
« Reply #55 on: Thu, 08 August 2013, 08:31:26 »
Sorry all the case fans, CPU fan is into motherboard.
Offline tgujay
« Reply #56 on: Thu, 08 August 2013, 08:43:24 »
Weird, your machine has become self-aware, kill it now!
Offline Photoelectric
« Reply #57 on: Thu, 08 August 2013, 08:44:40 »
Is there an option in your bios to turn off the checking?  I don't have any fans plugged into the motherboard in my case--all connected to a Bitfenix Recon fan controller.  What motherboard are you using (brand / model)?
« Reply #58 on: Thu, 08 August 2013, 10:10:36 »
of course there is. LOL...
That is standard feature in OC boards...
Offline Tym
« Reply #59 on: Thu, 08 August 2013, 10:19:42 »
Just realised none of the case fans are actually running... No idea how to fix this now.
Offline tgujay
« Reply #60 on: Thu, 08 August 2013, 10:21:20 »
So the case has a fan controller?  If so it probably has a 4 pin molex connector somewhere that it uses to give power to the connected fans, my guess is that isn't plugged in.
« Reply #61 on: Thu, 08 August 2013, 10:22:27 »
Right, make sure that you've plugged the case fan controller into the PSU :)
Offline Tym
« Reply #62 on: Thu, 08 August 2013, 10:40:46 »
Just checked that, it is plugged in. Dropping by a friend with a voltmeter tomorrow. Otherwise it must be the switch, i hope not.
Offline Leslieann
« Reply #63 on: Thu, 08 August 2013, 17:04:25 »
Make sure the CPU fan is plugged into the proper spot, that should stop it from complaining. IF it monitors others and has a warning, then there will be a way to disable it, but not all boards can disable the cpu fan warning. I wouldn't jumper anything though, that could lead to a burnt board.
As to why the rest are not spinning, unplug them all and reconnect them. Temp fluctuations, corrosion and vibration can make them lose contact. Even if they look connected, unplug and replug them.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline skuko
« Reply #64 on: Thu, 08 August 2013, 23:47:28 »
here's my CM storm Stryker - lovin it :)
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #65 on: Fri, 09 August 2013, 06:27:25 »
Offline Tym
« Reply #66 on: Fri, 09 August 2013, 06:28:26 »
Thanks for your help everyone, I found out what it was, the Fan Controller wasn't connected :3
Can I just say, love this case to bits, It's bloody huge, if you have the space grab it with 2 hands!
First case I've had which allows for decent cable management!
Also (thanks again leslieann) I'm just going to purchase another fan at some point and hook that into the motherboard, but I don't mind pressing 1 button too much.
Offline Tym
« Reply #67 on: Fri, 09 August 2013, 06:29:11 »
Thanks for the input Microsoft Windows but I think you might be better suited to helping the guy trying to build a 90's style PC ?
« Reply #68 on: Fri, 09 August 2013, 07:09:27 »
You need to get those cables sleeved!!
And wow.....so much space....nice!
Offline Tym
« Reply #69 on: Fri, 09 August 2013, 07:12:16 »
What I would like to do in the future is upgrade my graphics card (currently a 6870) to something which is better (so vague I know) another 1tb hard drive, a reasonable SSD, and that's pretty much it.
Offline Morwrath
« Reply #70 on: Tue, 20 August 2013, 12:18:28 »
A SSD is 100% needed imo, makes everything so much faster.
Ducky Mini w/ white LEDs [Browns]
WTB SLUSHY RED CC/BROBOT!!
Got 3D and Hack Orange for trade, both MX.
Offline davkol
  •  Post Editing Timeout
« Reply #71 on: Wed, 21 August 2013, 05:16:29 »
Do you type faster on a computer with an SSD?
Offline Morwrath
« Reply #72 on: Wed, 21 August 2013, 14:12:09 »
No but it does enable you to get your programs that you write in to load a lot faster ;)
Offline davkol
« Reply #73 on: Wed, 21 August 2013, 17:05:22 »
OMFG, I save two minutes (that don't even matter because I'm making tea while my system boots) a day. That's totally worth €100+.
Offline Stevenator21
« Reply #74 on: Sat, 24 August 2013, 22:28:14 »
They don't just speed up your program but your whole machine. The OS is so much quicker on an SSD
« Last Edit: Sat, 24 August 2013, 22:30:32 by Stevenator21 »
Ducky Shine 3 TKL w/ Browns + White LEDs
« Reply #75 on: Sat, 24 August 2013, 22:42:08 »
Every application you start, starts faster.  Large document loads and saves are hugely faster.
Game level loads are much faster.
I'd like an SSD, but I still don't fully trust the technology, plus the pain to upgrade the HDD in a Mac mini is not worth it to do every year or two.
Offline fydo
  • Meow!
« Reply #76 on: Sat, 24 August 2013, 23:02:52 »
In terms of trust, I find SSDs to be far more trustworthy than spinning disks because SSDs have an interesting feature: When they eventually die due to the "limited writes" nature of SSDs, they will just go into read-only mode and all of your data is easily retrievable.
It reminds me of that Mitch Hedburg joke about escalators: they never go out of order, they just turn into stairs. :)
Also the failure rates of SSDs are lower than those of spinning disks by a factor of ten, especially if you're using an Intel SSD.
CoolerMaster Quickfire Rapid | Ducky Shine II (White LED)
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #77 on: Sun, 25 August 2013, 00:14:17 »
So true.  I have at least 8 SSD's and they are all working beautifully,  hence no need to worry about complete disintegration of the memory disk just yet.  Although I do have a two year old Sandforce still working.
But yes the Intel ones are real choice, due to regular firmware updates provided from the Mothership.
« Reply #78 on: Sun, 25 August 2013, 04:15:58 »
2 minutes a day over your whole life?
That's a lotta minutes.. divide that into $90 for a 128gb samsung 830
and it is likely well beyond 2 minutes
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #79 on: Thu, 29 August 2013, 15:25:15 »
The new Samsung 840 EVO  is a great SSD as well. They discontinued the 830 here in the US. You can still find
them, but they are usually overpriced if you do.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline TheeCOoon
« Reply #80 on: Thu, 29 August 2013, 23:38:33 »
NZXT Phantom =) the sickest case with amazing air cooling !!!! can mount dual radiation solution for the H100i ETC
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #81 on: Fri, 30 August 2013, 00:29:15 »
I have a black Fractal Design R4 with the window. I love it.
WTB/WTS/WTT ---->
Offline stancato9
« Reply #82 on: Fri, 30 August 2013, 05:39:54 »
Tell me this isn't a sexy case:
That looks amazing. That window is perfect. The only thing I don't like about the cube form factor is that they take up more horizontal space. Generally vertical space doesn't matter, so the cube actually will take up more space on a desk than the standard form factor.
If you are okay with that, I'd have to recommend this case OP.
Poker 2 - MX Red
Offline uzoc
« Reply #83 on: Fri, 30 August 2013, 18:52:17 »
My cooler Master HAF XB of course.
Best case if you want everything to be ergonomic.
Motherboard flat and on top (almost an open tech case if you leave it open).
I have it sideways (motherboard facing forward) so that I can place it in my desk.
Regular price $100 (did a search and Cooler Master has it for $50!):
http://www.cmstore-usa.com/cooler-master-haf-xb-lan-box-and-test-bench-computer-case-refurbished/
Offline stancato9
« Reply #84 on: Fri, 30 August 2013, 18:58:48 »
For $50 you can't go wrong. Unless you dislike the aesthetic of the case.
Poker 2 - MX Red
Offline Winther
« Reply #85 on: Tue, 03 September 2013, 14:56:44 »
Fractal Design Define R4..
If you want something that looks nice, which is silent and with great cooling, then you wont ever go wrong with that case, always one of my first recomendations..!
Offline concept73
« Reply #86 on: Fri, 13 September 2013, 04:25:21 »
Poker 2 with reds
Soon to be a JD40 with reds
Offline SnareSpectre
« Reply #87 on: Sun, 20 October 2013, 20:27:15 »
I'm a huge fan of this case that I bought for my recently built PC. Big enough for everything and good airflow. CM HAF 912.
http://www.amazon.com/Cooler-Master-HAF-912-Computer/dp/B00BCXF6O4/ref=sr_1_1?ie=UTF8&qid=1382318718&sr=8-1&keywords=haf
« Reply #88 on: Thu, 24 October 2013, 08:07:29 »
Offline zemp
  • FREE ITENS PLS
« Reply #89 on: Thu, 24 October 2013, 23:29:21 »
BITFENIX PHENOM
SWAG+POWER IN a tiny box.
Offline Oobly
« Reply #90 on: Fri, 25 October 2013, 01:43:27 »
Coolermaster HAF 9XX series is awesome.
Great cable management and airflow options. Lots of mount points for drives in places they get cooled by the airflow, etc.. And personally I really like the look of it, too.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline terran5992
  • One With The Cup Rubber
« Reply #91 on: Fri, 25 October 2013, 05:04:46 »
900D, Biggest and baddest case around
Offline zemp
  • FREE ITENS PLS
« Reply #92 on: Wed, 30 October 2013, 00:04:01 »
Caselabs makes one that are twice as big
But it will run you 600$
Offline Hak Foo
  • Make America Clicky Again!
« Reply #93 on: Wed, 30 October 2013, 00:32:23 »
They've had double-wide cases for a long time.  I bought one, missing a lot of bits and pieces, from a swap meet for $20 in like 2002.  It had eight 5.25" bays, a 3.5" cage with 4 bays or so, another with 2 bays for external devices, and terrible cooling.  There was loads of cooling on the drive side, but the only fan mount for exhaust near the motherboard was either 60 or 80mm; I eventually cut a 120mm blowhole in the top for that.
Overton130, Box Pale Blues.
Offline tormentor
« Reply #94 on: Sat, 09 November 2013, 00:00:17 »
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147053 I used this one for my rig. Huge with lots of airflow, goes on sale for $100 sometimes. Cool fins at the top make it look scaley (I just got some NZXT LED strips that I think will look gorgeous ran through the top) I definitely recommend.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146093 I used this one for my brother's rig. I like the style more but it may not have the amount of airflow you're seeking.
« Last Edit: Sat, 09 November 2013, 00:03:05 by tormentor »
