Author Topic: Is my idea dumb or it is hard to do?  (Read 2053 times)
Offline oppz197
  • Hai there
« on: Fri, 30 August 2013, 22:25:29 »
I like the idea that qfr with red switches has a red plate, why are there not that many people spraying their plates?
Offline gnubag
Re: Is my idea dumb or it is hard to do?
« Reply #1 on: Fri, 30 August 2013, 22:26:07 »
you would have to desolder all the switches to paint the plate properly.
Offline dreamingftw
« Reply #2 on: Sat, 31 August 2013, 00:03:48 »
It would just take a lot of time and work...
Offline oppz197
  • Hai there
« Reply #3 on: Sat, 31 August 2013, 00:11:06 »
what if you just sticker all the switch ( like you just press it down and find a square sticker)
As long as you dont mind the black part of the switch getin paint, it should work
Cant see the paint when the caps are on
« Reply #4 on: Sat, 31 August 2013, 00:15:06 »
Sounds like this might be the only way I'd be able to get a yellow plate.
« Reply #5 on: Sat, 31 August 2013, 00:18:30 »
If you ever build a board like a phantom or GH60 for example, painting the plate is just an extra easy step :)
Modding a board that's made, it'll take some time....but the end result may be worth it to you.
« Reply #6 on: Sat, 31 August 2013, 01:10:06 »
2 much work..... If you can pick up an extra shift at work or something, it has a way higher payoff then putting labor into your purchases.
Offline oppz197
  • Hai there
« Reply #7 on: Sat, 31 August 2013, 11:30:17 »
But who will do it ? 1 Shift is like 5~6 hours * 10 =50?
Offline Hak Foo
  • Make America Clicky Again!
« Reply #8 on: Sat, 31 August 2013, 13:36:39 »
The Rosewill 9000 has a red plate by default... which is garish and silly when you have blue switches.
Overton130, Box Pale Blues.
