Author Topic: ErgoDox: travel case (?)  (Read 7651 times)
Offline davkol
  •  Post Editing Timeout
« on: Sat, 09 November 2013, 17:27:04 »
I've been carrying my ergodox to school and conferences for a while, because it's sooo great, isn't it? I don't want to damage neither the keyboard, nor my backpack though, and bubble doesn't last forever and looks ugly. Therefore, I've been looking for a case.
So far, I've only found out that the Beyerdynamic DT-bag has perfect size (26×23×12 cm) to fit the ergodox w/ classic case, a trackball and an AC adapter for my thinkpad. It just needs a different padding, but it's a bit too expensive for that.
Any other ideas? I'd try to update the OP eventually.
Re: ErgoDox: travel case (?)
« Reply #1 on: Sat, 09 November 2013, 17:34:02 »
Just a heads up.. the TRRS sockets that was part of the group buy don't seem to be very high quality.
I have 2 doxes, and out of 4 sockets, 2 broke over time..  and I've only unplugged it a few times.
So... consider *NOT unplugging too much..
The usb is going strong.
Offline daerid
    • Rossipedia
« Reply #2 on: Sun, 10 November 2013, 00:17:41 »
I haven't had a problem with either of mine. I've swapped them several times, traveled with my classic case, and the TRRS's are still going strong. (knock on wood)
« Reply #3 on: Sun, 10 November 2013, 06:40:33 »
i think my trrs connection was more on the DOA side rather than wear/tear... the plate strips inside must not have been crimped well, and so after a while, it catches on the cable and bent..
Offline davkol
« Reply #4 on: Thu, 14 November 2013, 07:06:27 »
I guess I'm gonna try a cheap shoe travel case ($13 @ eBay) first.
Offline Ch0nG
« Reply #5 on: Sun, 24 November 2013, 01:10:21 »
Any suggestions on this topic? The DT-Bag looks like a great idea.
Would it work to cut some foam to the size of the bag then cut a smaller layer between the Ergodox halves? (Like this:)
----Ergodox----
----Ergodox----
I can see cabling being an issue with that since it doesn't have any pockets.
Here's what the inside looks like:
Das Ultimate - Blues - Converted to removable USB (Mimic-Cables) - 40 A-L WASD ORings
ErgoDox - ErgoClears ErgoDox - 65g Blues
Offline terran5992
  • One With The Cup Rubber
« Reply #6 on: Sun, 24 November 2013, 04:51:04 »
----Ergodox----
----Ergodox----
0.o interesting
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #7 on: Sun, 24 November 2013, 06:25:22 »
Offline davkol
« Reply #8 on: Mon, 03 November 2014, 13:28:18 »
A small update: I've recently bought a brand new neoprene 15.6" laptop "case" for €2 locally. The two ErgoDox halves just fit inside next to each other, and the case can be folded then.
Offline Data
« Reply #9 on: Mon, 03 November 2014, 20:38:21 »
Get yourself a nice Pelican case. You can feel like you're unloading expensive military gear every time you open it.  :D
Offline FrostyToast
  • Litshoard
« Reply #10 on: Mon, 03 November 2014, 21:04:24 »
Currently, these cases aren't available, but they should be eventually
Quote from: elton5354
« Reply #11 on: Mon, 03 November 2014, 21:20:06 »
They are amazing.  Keep your eye out for updates - http://www.keychatter.com/store/keyboard-carrying-cases/ergodox-carrying-cases/
