Author Topic: How should I fix this problem  (Read 5197 times)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« on: Sun, 10 November 2013, 04:16:34 »
Alright I goofed up and didn't show full ATD (attention to detail) and the Filco I ordered for my wife from Amazon has the wrong switch.  I checked my order and it was a goof on my end not theirs.  I ordered one with black switches and she wanted reds.
Would you guys desolder and just swap out the springs or get in touch of amazon and try and get it swapped?  I have never returned anything to any e-retailer to date so I'm not sure on the proper protocols here.
Which one do you guys think would be cheaper?
« Last Edit: Sun, 10 November 2013, 04:43:36 by Melvang »
Offline terran5992
  • One With The Cup Rubber
Re: How should I fix this problem
« Reply #1 on: Sun, 10 November 2013, 04:34:13 »
Hmm , reds and blacks are about the same. Prehaps you could try to get used to blacks?
Offline Melvang
« Reply #2 on: Sun, 10 November 2013, 04:42:53 »
It isn't for me.  It is for my wife and she was very adament about reds and not blacks.
Offline Neal
  • Skype: iNewbcake
« Reply #3 on: Sun, 10 November 2013, 05:24:15 »
I do not know how this works in other countries, but I assume you can just contact them and return it for the one with reds.
As long as its an unused product it should be easy, hell even easier if the box has not been opened.
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
« Reply #4 on: Sun, 10 November 2013, 05:25:43 »
I would email the seller and ask what they would charge for it. Also how comforatble are you soldering? If you are used to it and you got some spare time, would I buy some springs on originative and maybe resell the black springs or keep them :)
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #5 on: Sun, 10 November 2013, 05:25:51 »
This. Especially if unused, amazon (keyboardco?) will take it back for sure.
Offline itzmeluigi
  • ПБТ
« Reply #6 on: Sun, 10 November 2013, 05:35:34 »
I would certainly return it to Amazon, no point in using/buying more switches for something that can be replaced for less.
« Reply #7 on: Sun, 10 November 2013, 06:03:23 »
the labor to do this is almost 3/4 the cost of the board... @ minimum wage..
material
risk
Offline Larken
« Reply #8 on: Sun, 10 November 2013, 06:16:30 »
definitely check with the vendor if you could do an exchange. Most are quite good about things like that, as long as the item returned hasn't been damaged in any way, though you'd might be out a little on shipping.
if you were going to open the board up and perform mods (lube and everything else) anyway, the spring swap would be a feasible choice. Would take more than a good half of a day to finish up though. Just desoldering to only swap springs is honestly not worth the effort.
| Ergodox #1 | Ergodox #2 |
Offline PointyFox
« Reply #9 on: Sun, 10 November 2013, 06:19:06 »
Blacks are only 30% heavier than reds..
« Reply #10 on: Sun, 10 November 2013, 06:19:28 »
lube totally not worth it...  and especially on the stock plate...  you're gonna have to do it all again... soonish, because that stuff rolls right off...
there's no cavity design such that the parts are re-dipped...  the lighter oils just mostly pools at the bottom after a while... barely getting any where you originally put it..
Offline Melvang
« Reply #11 on: Sun, 10 November 2013, 06:59:20 »
I think I will just swap the springs.  She doesn't like the feel of lubed reds anyway.  Plus with doing the spring swap I have spare springs for ghetto greens or panda clears.
« Reply #12 on: Sun, 10 November 2013, 07:06:44 »
bro....  don't be shy... it was their mistake... call the CC if you have to...
Offline Signature
  • master of puppers
  • snoozing
« Reply #13 on: Sun, 10 November 2013, 08:20:40 »
It was his fault tho :-X
Offline Dreamre
    • kbdlife
« Reply #14 on: Sun, 10 November 2013, 09:04:51 »
Desoldering the switches and changing the springs will take you a whole day to do...is it worth the time for you?
Offline Neal
  • Skype: iNewbcake
« Reply #15 on: Sun, 10 November 2013, 09:05:35 »
I do not understand your decision, as a quick email/call to amazon will fix this.
But I wish you good luck.
« Reply #16 on: Sun, 10 November 2013, 09:32:11 »
oh.. i misread the op..
Well... then pay them the restocking fee..  which would still be significantly "cheaper" than doing the labor himself.
« Reply #17 on: Sun, 10 November 2013, 13:55:35 »
Return to Amazon would be easiest, but probably incur restocking fee.
Or sell if here at minimal loss (it is practically new), buy one with reds.
Depends which option will cost more.
Replacing switches is a lot of effort and you will need to buy red switches and then sell black switches, not to mention what if something goes wrong.
« Reply #18 on: Sun, 10 November 2013, 14:10:25 »
Keep in mind you will have to desolder to do this.
I would call amazon and see what they say. They might even take it back with no fee.
« Reply #19 on: Sun, 10 November 2013, 14:18:50 »
Amazon is by far the easiest etailer to do returns with.
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
« Reply #20 on: Sun, 10 November 2013, 14:21:55 »
Amazon will usually charge a fee to ship it back if you put the reason as "mis-ordered" or something like that, but still, much cheaper than buying a whole new board, or a bunch of switches/springs
« Reply #21 on: Sun, 10 November 2013, 14:24:52 »
If cost is a concern, as I mentioned earlier find out what it will cost to return it, find out what you can sell it for here (vs. the original cost), and work out which is less.
Offline MKULTRA
  • telling it how it is
« Reply #22 on: Sun, 10 November 2013, 14:25:43 »
You should have called Amazon before posting here.  Maybe they'll understand and let you return.
Offline Photoelectric
« Reply #23 on: Sun, 10 November 2013, 14:36:22 »
I would exchange.  Desoldering switches from a Filco is an annoying process--I've disordered 2 Filco TKLs to replace plates to universal ones.  There are copper through-hole inserts, and solder goes all the way through the PCB.  Desoldering my LZ-GH was a relative breeze by comparison.  Unless you love soldering, I'd just exchange.
Filco boxes aren't sealed.  You should have no problem returning as new and exchanging for Reds.
Offline Linkbane
« Reply #24 on: Sun, 10 November 2013, 16:09:40 »
Reds and blacks are completely night and day. There's like the soft loveliness of red and then the forceful resistance of blacks.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline Melvang
« Reply #25 on: Mon, 11 November 2013, 06:09:50 »
So as far as desoldering factory boards I was going to desolder my costar built das and lube, and or mess around with different springs/stems.  I have stock browns in it now.  Have had it for a few years now so the switches are well broke in.  How would you guys compare desoldering a Das vs desoldering a Filco?  I have desoldered a Phantom.  I did lift a couple pads but I think most of that was from attempting to flush cut bad soldered joints that had very long leads sticking out of the joint and ended up pulling the pad up with the cutters due to the cutters not being full flush cut.
Offline Oobly
« Reply #26 on: Mon, 11 November 2013, 06:45:47 »
IF you keep the board and desolder the switches, consider modding the plate so you can open the switches again later without desoldering. That will make the whole operation more worthwhile as instead of just making it into a board with reds it will be an "easy to mod" board with reds.
You could also buy red switches and replace them instead of swapping springs, use the black switches for something else. Less work.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline ZeodoHokill
« Reply #27 on: Mon, 11 November 2013, 06:54:45 »
I think you better talk to the seller ASAP before it is too late
Offline Melvang
« Reply #28 on: Mon, 11 November 2013, 08:24:56 »
Guys this is not my first board modification.  Have you all forgot about my HD LED mod I did to my Das?  I am going to desolder my Das to at least lube the switches.  Depending on how that endeavor goes I may or may not call up amazon.
Edit:  Desoldered all the switches in my Das as a touch of practice with my generic soldapult.  Good news in I got all the switches out with no casualties.  Only bad thing I can say is that solder is HELL on tips.  Full of crap and loads up my tip with black stuff.
« Last Edit: Mon, 11 November 2013, 11:02:15 by Melvang »
