Author Topic: how can i make blues/greens louder?  (Read 3418 times)
« on: Wed, 13 November 2013, 20:09:40 »
without having to resort to putting these under the keycaps
Offline AKIMbO
  • HHKBro
Re: how can i make blues/greens louder?
« Reply #1 on: Wed, 13 November 2013, 20:13:07 »
Scream "click" when typing. Alternatively, switch to buckling springs. Put the board in an all metal case.
| KBD75 (box reds)
Offline Pacifist
  • on hiatus
« Reply #2 on: Wed, 13 November 2013, 20:14:55 »
« Reply #3 on: Wed, 13 November 2013, 20:15:15 »
i want that BS sound but in a cherry switch. that'd be my ultimate board.
« Reply #4 on: Wed, 13 November 2013, 20:15:34 »
Sound is "relative"..
You can make the keyboard sound louder,  by reducing the noise of your surroundings..
Because whatever you can do to the board itself, would only produce negligible increase in loudness..
.. reduce spring weight..
.. dampen bottom out noise..
Offline AKIMbO
  • HHKBro
« Reply #5 on: Wed, 13 November 2013, 20:15:43 »
You want the sound deeper or louder?
| KBD75 (box reds)
Offline Dubsgalore
« Reply #7 on: Wed, 13 November 2013, 20:17:40 »
i love snaps so much..............
Offline Pacifist
  • on hiatus
« Reply #8 on: Wed, 13 November 2013, 20:18:54 »
Is that drugs?
You've never seen drop pops before? fo. serious?
Oh I remember these. One halloween a while ago this one kid brought some and being the dumbass this kid was, he threw them into grass.
Keep in mind he for some reason sprayed his ****ty $45 airsoft gun at a bunch of kids. Luckily the ****ty gun couldn't hit anything
« Reply #9 on: Wed, 13 November 2013, 20:22:45 »
yup
Is that drugs?
what are you, 10?
Offline divito
« Reply #10 on: Wed, 13 November 2013, 20:32:25 »
Mic up your keyboard? Use metal caps? Use a plated-keyboard?
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
« Reply #11 on: Wed, 13 November 2013, 20:36:10 »
board will be plated and in an alu case
« Reply #12 on: Wed, 13 November 2013, 20:44:14 »
take the case off and ride it bareback
- D Trump 2026-10-24
Offline JPG
  • Model F is my new passion!
« Reply #13 on: Wed, 13 November 2013, 20:48:27 »
Just a theory, but if you managed to put some tiny metal plates between the 2 parts of the stem that "clicks" together, you would probably get some more clickyness, but I don't know how you could manage that. Also, putting it in a thin metal case with thin metal keycaps could increase the effect of the sound, but still all theory. It could also bring back the PING!
« Reply #14 on: Wed, 13 November 2013, 20:51:35 »
somebody needs to develop a way that i can plug earphones into my keyboard so that's all i hear
« Reply #15 on: Wed, 13 November 2013, 21:14:58 »
Titanium keycaps?
« Reply #16 on: Wed, 13 November 2013, 21:15:07 »
Do what some of the older keyboards did and install a speaker?
Offline kolonelkadat
  • Location: the vicinity of an area adjacent to a location
    • Force Project X
« Reply #17 on: Thu, 14 November 2013, 05:21:53 »
get a stethoscope, place it on desk behind keyboard. replace ear pieces with microphones. connect microphones to pc. connect headphones to pc. maximum the volume.
put on head phones, enjoy the clicky sounds. and probably also the pinging of the springs though.
"Obviously, windows are central to Windows. But what is a window?"
Offline RabRhee
« Reply #18 on: Thu, 14 November 2013, 05:31:57 »
All of this. Or change the sliding part of the stem to another material, now I want to make some metal sliders just to see how much louder they could get. Probably affect the feel of the switch a small amount (small? :P).
Just fit little cymbal shapes to the corners of all your keys and the spots they land near, so each key becomes a miniature version of the battery pink bunny rabbit with cymbals that crash every time you press a key.
-Life is good-          Crafting: |  Keychains |  More.   .Keychains | Crowdsource Key | Budget Keycap Board |
« Reply #19 on: Thu, 14 November 2013, 05:38:15 »
If you are using Windows, install ClicKey and increase the speaker volume to max.
Offline Oobly
« Reply #20 on: Thu, 14 November 2013, 07:04:05 »
Nitroglycerine oring mod...
Or what he said ^^ (Findecanor).
Or make a hole in the keyboard case at the front, like a guitar sound hole? Metal sliders and bottom case?
Or what he said ^^
How about this one: install fuel injectors and spark plugs in each key case...
Or what he said ^^
Buying more keycaps,
it really hacks my wallet,
but I must have them.
  • Live long and prosper
« Reply #21 on: Thu, 14 November 2013, 07:29:07 »
Modify the stems so they have a greater tactile bump.  Will cause the contact leaf to move further away from the contact point, and then when the slider drops after actuation the sound should (in theory) be louder.
Don't know if this is even probable or possible, but it's all I can come up with...
tp thread is tp thread
Offline kgrad5
« Reply #22 on: Thu, 14 November 2013, 07:30:50 »
Amazing. I am going to start doing this when people are in my office.
« Reply #23 on: Thu, 14 November 2013, 07:37:40 »
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #24 on: Thu, 14 November 2013, 07:57:47 »
I've always wanted to see this done. Instead of a "click" sound, sample... I dunno, Thor's hammer smashing something multiple times, and then randomly playing the sound with each keypress. Or assign a sound to each key, and set them up so that standard words ring out something that sounds pleasant. How difficult would that be -- an acoustically-enhanced keyboard?
EDIT: http://jinglekeys.com/jinglekeys/ -- thank you Ray!
Quote from: Samuel Adams
