Author Topic: Levitating Mouse  (Read 5685 times)
Offline jmchargue
Levitating Mouse
« on: Sun, 08 December 2013, 15:29:31 »
Sure is cool from an aesthetic standpoint, but how could this possibly alleviate carpal tunnel? Furthermore, I'd like to see magnets take the full weight and movement of my hand.
http://www.kibardindesign.com/en/collection/collection-17/levitating-wireless-computer-mouse-bat.aspx
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
Re: Levitating Mouse
« Reply #1 on: Mon, 09 December 2013, 16:51:18 »
would not be easier to use the Leap Motion?
« Reply #2 on: Mon, 09 December 2013, 19:37:45 »
how is this possible..
You would have to lift the person's whole forearm..
if the person has to lift his own forearm/ shoulder...
The mouse would become quite tedious to use..
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #4 on: Mon, 09 December 2013, 20:41:52 »
If I had it - couldn't resist forcing the mouse down onto it's base to hear it break/crack when 2 opposing magnets are forced together (guessing how it might work).
« Reply #5 on: Mon, 09 December 2013, 22:54:46 »
or you know.. a touch pad?
Ehh, touchpads are not in any way ergonomic though.  Some of the 3D mice, roller ball mice, and so on are much more ergonomic.
Offline Lastpilot
  • Power stance
« Reply #6 on: Mon, 09 December 2013, 23:22:53 »
Definitely wouldn't be able to set my phone near my mouse if I got that lol
« Reply #7 on: Mon, 09 December 2013, 23:32:30 »
You'd need some serious magnets to support 1 Kg at 10mm! I have a metal desk: as cool as this is, I can't use it!
Offline Oobly
« Reply #8 on: Thu, 12 December 2013, 09:03:39 »
I think this thing is pretty useless. Just a design exercise, really.
How exactly does the movement sensing work? And cursor repositioning (like lifting a normal mouse)?
I really don't see how it's supposed to help with RSI, except by reducing how much you actually use the device I guess.
I'd rather have a well-designed "normal" mouse, thanks.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline JPG
  • Model F is my new passion!
« Reply #9 on: Thu, 12 December 2013, 09:15:46 »
Even if it could support a certain amount of weight/force, you still could lot lay a lot of weight on it probably and need to force with your shoulder to keep you hand in the air. For casual use it could be ok, but for a lot of use you could end up with a different problem.
I am pretty sure that a good position of your chair, desk, mouse is much more useful.
Offline Linkbane
« Reply #10 on: Thu, 12 December 2013, 09:17:22 »
Perhaps they would use a magnetic trackball inside the base that would move when the mouse is tilted or moved in different directions, and then the base could calculate from the tangential velocity of the ball how fast to track. Would seem pretty cool to me, and I might buy one if the price isn't exorbitant, which it will be.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline Wildcard
  • When caffeine isn't enough
« Reply #11 on: Sat, 21 December 2013, 16:07:21 »
I could only imagine what would happen to metal getting close to magnets strong enough to hold your arm up.
Also, make sure not to put this next to your computer tower if you have any spinning platter drives :p
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #12 on: Sat, 21 December 2013, 21:24:28 »
I don't even ...
Offline ideus
  • Björkö.
« Reply #13 on: Sat, 21 December 2013, 22:10:57 »
This may be only an invention, but not an innovation by any means.
The invention may be even patentable, but the innovation adds actual value beyond of what it is in the market now, solves a problem and improves the quality of life.
Offline CalmB4tehPwn
  • Demon of the Fall
« Reply #14 on: Mon, 23 December 2013, 18:13:18 »
10mm is not far enough that you have to hold your entire arm off the desk. Lift your mouse off your desk by the thickness of your pinky, that's how high it would be suspended (assuming you don't have more or less weight in your hand/forearm than 1000g)
Now, that's low enough to the pad that you wouldn't be able to use tilt sensing technologies, just not enough room, so it probably tracks like more standard mouse, in lateral movement.
I think it's neat. Maybe not groundbreaking, but I think if nothing else it will help get mouse designers thinking outside of "roundish thing with a couple buttons and a laser that you push around a flat surface" It's inventions like this that -lead- to innovation from others.
I'd love to try it, play around with it. There isn't much room to actually move, so maybe it's closer to the little nub pointer in the middle of laptop keyboards? Similar to the tilt idea, but you just move the whole mouse to the right, and hold it right as the pointer moves.
I find that system to be exceptionally clumsy, but as I said, I can appreciate the attempt at moving into new areas.
"I seek a great warrior" - Luke Skywalker
"Great Warrior, Hmm? War does not make one great." - Master Jedi Yoda
« Reply #15 on: Mon, 23 December 2013, 18:20:33 »
whoaaaaaaaaaaa... thats pretty rad !!!!!!
Offline cinnamoncider
  • Thorpies are snappy
  • No clack; no life.
« Reply #16 on: Mon, 23 December 2013, 20:13:39 »
It flooooooaaaats!
Offline terran5992
  • One With The Cup Rubber
« Reply #17 on: Wed, 25 December 2013, 08:04:25 »
BLASPHEMY I SAY
