Author Topic: Cheap o rings, any first hand experience?  (Read 6467 times)
Offline synerr
« on: Sun, 02 February 2014, 11:12:14 »
Saw those and it seems a lot have been sold.
http://www.ebay.co.uk/itm/150pcs-White-Keycap-Rubber-O-Ring-Switch-Dampeners-For-Cherry-MX-Replace-Part-/141094361977
Any first hand experience on quality, properties and suitability of those rings?
Press any key to continue, any other key to quit.
Offline Photoelectric
Re: Cheap o rings, any first hand experience?
« Reply #1 on: Sun, 02 February 2014, 16:21:33 »
I got these from a different seller for a worse price :
http://www.ebay.com/itm/261265487004?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
And I did not like them with OEM keycaps.  They seemed too thick, so travel distance was reduced significantly.  These are supposedly good for keycaps that have transparent legends for backlit keycaps, but I've not yet tried them with those.  I would ask Infiniti--he got those for his Ducky Shine.  As with all o-rings, results vary depending on which keycaps you use them with: profiles and internal structure varies from set to set, and some caps have no internal support cross-bar things.
Offline Zeal
    • Zeal Generation Inc.
« Reply #2 on: Sun, 02 February 2014, 16:35:36 »
I've personally gotten a set of 150 clear orings from another seller @ $3.72, and when I asked about the hardness, the seller replied with 40A orings. After using them for a while, they do feel pretty soft with some sound dampening.
I've used them on Thin Ducky PBT keycaps and Thick Cherry PBT keycaps and I personally don't find them too thick. Each person has different preferences when it comes to switch feels however.
Offline synerr
« Reply #3 on: Sun, 02 February 2014, 16:52:12 »
Ordered a set.  I'll skip breakfast tomorrow and I'm budget neutral.
Offline do_Og@n
« Reply #4 on: Sun, 02 February 2014, 18:59:56 »
I've actually made my own O-Rings by cutting up the rubber mat used in RD keyboards. They work well enough but it's hard to keep them all the same thickness.
Offline Zeal
« Reply #5 on: Sun, 02 February 2014, 19:11:23 »
Be prepared to wait 30+days for it to arrive in a tiny, square, plastic envelope. :p
« Reply #7 on: Sun, 02 February 2014, 20:11:53 »
20a - 30a is much better for dampening.
Cool! Where do you get such super-soft ones?
- D Trump 2026-10-24
Offline synerr
« Reply #8 on: Mon, 03 February 2014, 04:01:37 »
I often do small random purchases just to forget about it and get a surprise in the post :D
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #9 on: Mon, 03 February 2014, 05:24:25 »
Yep, I bought from this vendor too.  These are better for backlight keycaps since light will shine through the o-ring.
Look at the letter O.  Take notice of the bottom part of the letter O.  There's a slight shadow with the black o-ring.
With a black o-ring:
With a clear/translucent white o-ring:
clear/translucent white o-ring and 50A black o-ring:
The black one is stiffer than the clear/translucent white o-ring.
« Reply #10 on: Mon, 03 February 2014, 06:52:56 »
So, will silicone prove to be durable in the long-term?
I like them small and soft.
Offline synerr
« Reply #11 on: Thu, 13 February 2014, 08:52:29 »
OK ... so it took 10 days for them to arrive.  Not bad.  They definitely change the keypress feel and not yet sure what I prefer.  Will have to try it out for a few weeks.
Offline ihateregister
  • I like cookies. Yum!
« Reply #12 on: Fri, 14 February 2014, 15:48:07 »
After paying something like $25 for a oring set from wasd, $5.50 w/ free shipping sounds like a cheap deal to try something new, even if I do have to replace them once in awhile... :P
Offline Pacifist
  • on hiatus
« Reply #13 on: Fri, 14 February 2014, 16:18:55 »
I ordered some of the clear ones and they arrived today. 150 O rings. They feel slightly thinner and softer than WASD red O rings.
Offline soloz2
« Reply #14 on: Mon, 10 March 2014, 05:16:45 »
Are you guys ordering from the first or second link?
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #15 on: Mon, 10 March 2014, 05:51:46 »
I bought from the second link (i.e.  seller is "newdaystart").
However, I got the pack of 240 pcs for US$10 (http://www.ebay.com/itm/240pcs-Keycap-Rubber-O-Ring-Switch-Dampeners-White-CHERRY-MX-Free-Shipping-/261269381932)
Offline morpheus
Offline Zeal
« Reply #17 on: Mon, 10 March 2014, 10:15:16 »
I ordered these red ones recently.
http://www.ebay.com/itm/150pcs-Keycap-Rubber-O-Ring-Switch-Dampeners-RED-For-CHERRY-MX-Replace-Part-/251342922824?pt=LH_DefaultDomain_0&hash=item3a8534a448
What do you know about these ones?
Looks like IMSTO's thin red silica orings. Some reviewers mention that they're barely noticeable, but I don't have any first hand experience with thin ones. (only have the super thick type)
