Author Topic: Electricity, WHY!  (Read 2716 times)
Electricity, WHY!
« on: Thu, 10 July 2014, 05:50:16 »
swapped  1of 2  1600uf 6.3v cap (blown) with 1800uf 6.3v cap (united chemicon)
voltage drop across cpu by 0.04 v
what's up with that? ne xperts on this?
Offline Oobly
Re: Electricity, WHY!
« Reply #1 on: Thu, 10 July 2014, 08:04:58 »
It depends.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #2 on: Thu, 10 July 2014, 09:26:12 »
caps type?
kinda basic stuff - not sure if you know: some of then have polarity - and you should obey this polarity, then most probably you inverted your caps ...
« Reply #3 on: Thu, 10 July 2014, 09:33:20 »
caps type?
LOL, i'm not thattt n00b...
« Reply #4 on: Thu, 10 July 2014, 10:17:55 »
caps type?
I assume the blown cap was a normal aluminium electrolytic. The "united chemi-con" caps are all organic polymer electrolytic types.
What sort of voltage regulation is the MB supposed to have? failing caps can often play hell with that, as they present a different load.
« Reply #5 on: Thu, 10 July 2014, 10:29:18 »
caps type?
This seems to be the filter cap for a supplementary power input for the motherboard, they often did this before 8pin.
But I don't understand why the replacement cap is causing a voltage DROP?
« Reply #6 on: Thu, 10 July 2014, 10:36:40 »
caps type?
I'm no EE, but my guess is because the ESR is much lower on the new cap. Power supplies are very complex beasts with respect to their loading. A lower resistance load can cause output voltage to be higher or lower, heavily dependant on the PSU design.
I'm sure a real engineer will know more: My experience is mainly with linear regulated PSUs and not with fancy modern motherboard power management.
« Reply #7 on: Thu, 10 July 2014, 10:41:14 »
caps type?
why would lower resistance cause a voltage drop..
because this is input stage..   shouldn't i get More voltage due to the current flowing more smoothly through?
Offline Oobly
« Reply #8 on: Fri, 11 July 2014, 06:18:45 »
It could also be the cap is doing a better job of smoothing ripple and the sensors see the less noisy supply as being at a lower overall voltage.
Or that it has more reserve so it gives a more stable supply, lower at low loads, but higher at high loads and you're measuring it at low load....
There are too many factors in the design of the supply and sensors to be able to tell without getting a full circuit diagram and knowledge of how the sensing is being done.
If it's less stable at the same speeds than it used to be then it could really be a lower voltage, but if it is as stable or more with high loads on, then it's just doing a better job.
My advice: Ignore the actual voltage reading compared to the old one and perform OC'ing, temp measuring and stability testing the usual way. It's likely to be giving you more voltage stability and less ripple than the old cap.
« Reply #9 on: Fri, 11 July 2014, 06:36:51 »
How are you measuring?
Offline agodinhost
    • Dr Ian O Xaman
« Reply #10 on: Fri, 11 July 2014, 06:45:36 »
A "real" engineer would make you fall sleep after one hour of talk ...
« Last Edit: Sat, 12 July 2014, 14:57:09 by agodinhost »
« Reply #11 on: Fri, 11 July 2014, 07:13:47 »
I didn't measure..
I changed out the blown cap with the close replacement on hand,  and with the same motherboard settings,  I see a cpu voltage drop of 0.04v
I also find it weird that ONE cap could cause this..  and this cap is NOT a main filter..
