Author Topic: Anyone try out a Statial mouse?  (Read 5799 times)
Offline P3TC0CK
« on: Fri, 18 July 2014, 07:51:06 »
Found out about this while going on a youtube suggested video adventure. Seems pretty interesting, although the base mouse isn't very appealing for me.
Link here for the page.
petcock
[pet-kok]
noun
1. a small valve or faucet, as for draining off excess or waste material from the cylinder of a steam engine or an internal-combustion engine.
Re: Anyone try out a Statial mouse?
« Reply #1 on: Fri, 18 July 2014, 09:20:55 »
Looks like a god awful 3D printed monstrosity.  The concept is cool, but it looks fragile and unwieldy.
Offline cribbit
« Reply #2 on: Fri, 18 July 2014, 10:47:22 »
Make it out of aluminum and I might try one. Unless you fidget a crapload, there's no need for that level of customizeability.
I typed this post on my Slanck. I also developed a stronger, cleaner, easier handwiring method.
Offline P3TC0CK
« Reply #3 on: Fri, 18 July 2014, 11:10:17 »
I think you're able to, the model is available on shapeways. Bit expensive though if you decide to go all metal.
petcock
[pet-kok]
noun
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #4 on: Fri, 18 July 2014, 11:11:16 »
Really... $70? Not a chance.
Offline Zekromtor
    • My Setup
« Reply #5 on: Fri, 18 July 2014, 16:31:50 »
Looks pretty cool to me. It's a good idea to build off of in any case to use a particular mouse with a good sensor that you're not fond of the shape of.
Offline SonOfSonOfSpock
« Reply #6 on: Fri, 18 July 2014, 16:59:16 »
It might help if you had a large hand and every mouse ever made was too small. I'd never want to use this.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #7 on: Fri, 18 July 2014, 19:00:17 »
Unless you're the pickiest person in the entire world, you'll probably be able to find a mouse that suits you, and isn't such a hideous monstrosity.
Offline blackbox
« Reply #8 on: Fri, 18 July 2014, 19:06:28 »
Its cool. I am a bit sceptical about how robust it is. Nothing I would have bought anyway.
The LAN table!
Offline jacobolus
« Reply #9 on: Fri, 18 July 2014, 20:44:09 »
3d printing doesn’t seem like a great way to make a part like this: expensive, flimsy, awful surface finish.
(But on the flip side, this is an interesting idea. If it could be a $10–20 part, made out of something a bit sturdier, I could see this being pretty popular. It’s definitely easier to customize an off-the-shelf mouse than completely design a new one from scratch to fit your hand.)
« Last Edit: Fri, 18 July 2014, 21:14:08 by jacobolus »
Offline combataran
« Reply #10 on: Fri, 18 July 2014, 20:51:38 »
Ugliest piece of sh*t ever.
Cherry G80-1000HFD | CM Storm Spawn | Keypuller.com - Key Caps News & Database
Offline Enigma
« Reply #11 on: Sat, 19 July 2014, 05:36:26 »
It's a pretty cool concept, but I think I would be too afraid to use it as I use my current mouse. It looks like it's going to fall apart.
Offline P3TC0CK
« Reply #12 on: Sat, 19 July 2014, 10:58:59 »
I actually loved the look of the mouse, surprised it got so much hate. It's too bad it's on a technically weak mouse, would have loved it to be on a better base.
petcock
[pet-kok]
noun
Offline PointyFox
« Reply #13 on: Sat, 19 July 2014, 11:30:59 »
That looks terrible.  Probably flexes way too much as well.
Offline davkol
  •  Post Editing Timeout
« Reply #14 on: Sat, 19 July 2014, 13:01:27 »
...unless you're left-handed.
I'm aware of exactly *ONE* left-handed mouse with a decent sensor, but it's Razer. Everything else is either ambidextrous (and mostly nearly flat), or you're paying premium for the shape and even more for the fact that it's a niche product.
Offline Input Nirvana
« Reply #15 on: Sat, 19 July 2014, 14:27:46 »
Practicality aside, excellent direction and though processes.
Food for thought.
Thanks for link.
« Reply #16 on: Sat, 19 July 2014, 15:08:23 »
i think verticle mouse + g400 would be good enough for me..  I'd buy that in a heartbeat..
Offline lkong
« Reply #17 on: Tue, 22 July 2014, 12:29:50 »
Awesome top piece and design
also a really good practice of 3d printing.
but over a $10 dollar mouse? oh please.
« Last Edit: Tue, 22 July 2014, 14:00:38 by lkong »
Offline P3TC0CK
« Reply #18 on: Tue, 22 July 2014, 17:26:20 »
It's too bad he didn't release the files for the model. The hardest work is probably just designing the locking system, everything else just has to be matched up to another mouse.
petcock
[pet-kok]
noun
