Author Topic: mechanical keyboards are not worth the money.  (Read 22558 times)
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« on: Fri, 12 September 2014, 16:14:30 »
Thoughts?
Offline heedpantsnow
  • Old enough to know better
Re: mechanical keyboards are not worth the money.
« Reply #1 on: Fri, 12 September 2014, 16:16:37 »
Sure. For a lot of people. Just like anything other than a can of Nescafé is not worth the money. But if you care about having good coffee...
I'm back.
Offline dante
« Reply #2 on: Fri, 12 September 2014, 16:16:47 »
Depends.
« Reply #3 on: Fri, 12 September 2014, 16:18:31 »
Honestly...   I agree...
If all you only have light computer use....   Then it's totally NOT worth the money...
Ontop of that a typical mechanical keyboard to the typical user will provide NO tangible benefit in terms of ACTUAL performance..
The Ergodox is really the only relevant investment, but even then it's only for computer-addicts that can't get offline...
Offline Novus
  • Mondai nothing~
« Reply #4 on: Fri, 12 September 2014, 16:18:40 »
Actually I roast my own my coffee and you can buy em for pretty cheap actually.
So its not more expensive actually
« Reply #5 on: Fri, 12 September 2014, 16:24:39 »
I always draw the comparison with shoes.
Wal-Mart shoes are acceptable for almost anything, and, when you wear 'em out, just replace 'em!
- D Trump 2026-09-28
Offline Novus
  • Mondai nothing~
« Reply #6 on: Fri, 12 September 2014, 16:26:47 »
You do need to wear a formal pair for certain occassions though and for work.
« Reply #7 on: Fri, 12 September 2014, 16:27:12 »
I can understand the sentiment.
Mechanical keyboards are a luxury item for upwards of 90% of users. Cherry switches were designed to last for years of intense use, and don't even get me started on hall effect...
Offline esoomenona
  • Gnillort?
« Reply #8 on: Fri, 12 September 2014, 16:28:08 »
Why do people buy anything that costs more than other things? Why are things even made that are different than others? Why aren't we all issued standard equipment upon birth, and we never know anything else?
« Reply #9 on: Fri, 12 September 2014, 16:49:41 »
A Quickfire Rapid, SteelSeries 6GV2 or Func KB-460 costs about the same as a Logitech Illuminated or wireless Apple Aluminum keyboard and less like a monstrosity from Madcatz or in Logitech's G-series.
Keyboard choice is mostly about personal preference. It is also about quality. If you can get a keyboard that satisfies your preferences and quality at a good price, then that is always worth the money.
« Last Edit: Fri, 12 September 2014, 16:52:54 by Findecanor »
Offline oscillik
    • music podcasts
« Reply #10 on: Fri, 12 September 2014, 16:52:13 »
troll thread is trolling!
Keymacs A620N-Rev.A with Alps SKCM Salmon switches
« Reply #11 on: Fri, 12 September 2014, 17:05:12 »
this some commie **** bruh
Offline pbtforever
« Reply #12 on: Fri, 12 September 2014, 17:09:30 »
Don't feed the trolls
Offline IPT
  • Formerly projectD
« Reply #13 on: Fri, 12 September 2014, 17:10:52 »
yeah but most people don't buy those keyboards
they use the free one Dell/HP ships to them, or some $5.00 OEM keyboard.
Offline Grendel
« Reply #14 on: Fri, 12 September 2014, 17:26:59 »
You get what you pay for.
- I'm game !
Offline Hyde
  • White Tofu Extraordinaire
« Reply #15 on: Fri, 12 September 2014, 17:42:29 »
Depends on your reason for getting them.
If you're getting them because they last longer.  Well to be honest it's still cheaper to buy $10 keyboard and replace them as they break.  My cheapo Dell keyboard lasted me more than 10 years.  So cost wise rubber dome is still cheaper.
However if you buy them because they feel nicer, then it's definitely worth it.  Although like everything else in life there is a range.  Maybe between rubber dome and mechanical there is a huge difference, but say between a $150 mechanical and a $400 Korean customs I don't think the difference is that huge.  Like there is still a difference but doesn't warrant the 2X plus price tag.
I always compare it to cars, Lexus is definitely noticeably better than Toyota.  But the difference gets smaller between a Porsche and Lexus, and then again Porsche to Ferrari while the price difference just spikes.
So you have to decide where to draw the line.
« Reply #16 on: Fri, 12 September 2014, 18:59:18 »
My first mechanical I bought because I wanted something that would last longer.
All the rest because hype.
But I definitely think I've gotten my monies worth out of my daily driver.
Offline mikekey
« Reply #17 on: Fri, 12 September 2014, 19:00:15 »
I think mine was.
Offline PointyFox
« Reply #18 on: Fri, 12 September 2014, 19:05:26 »
Why do some people think mechanical >> rubber dome?  In some instances rubber dome > mechanical.
Offline oscillik
    • music podcasts
« Reply #19 on: Fri, 12 September 2014, 19:31:31 »
topper
« Reply #20 on: Fri, 12 September 2014, 19:34:17 »
Clacks are not worth the money.
I'm back.
Offline esoomenona
  • Gnillort?
« Reply #21 on: Fri, 12 September 2014, 19:39:53 »
SHEE-IT! Next you're going to tell me booze, prostitutes, and cocaine ain't worth the money.
Offline Altis
« Reply #22 on: Fri, 12 September 2014, 20:25:31 »
Lots of things aren't even remotely worth the money they charge for them. It only really becomes an issue when it's a necessity (such as food, utilities, water) that cost way too much.
I do think that mechanical keyboards could be cheaper, but then some of the are. It's really the ones that are higher quality and limited in production that cost a lot.
Some things are just clearly a rip-off though. The HHKB-S for $350 comes to mind...
Offline exitfire401
  • The Force is Re/\l
« Reply #23 on: Fri, 12 September 2014, 20:29:54 »
I agree for the most part. If you're a light user, then yes, it's probably not worth the money, and you probably wouldn't know typing on a piece of wood from typing on a model M. However, if you work on the computer for 8 or more hours a day, it really does make a difference. I've noticed a huge lack of fatigue since my switch to mechs, and my friends who I have converted have noticed the same during their long gaming sessions.
Offline jacobolus
« Reply #24 on: Fri, 12 September 2014, 21:24:17 »
Tools in general are way overrated. We should go back to living in caves in the forest, killing animals with rocks, and pulling off chunks of raw meat to eat with our teeth.
Offline midnightmare
« Reply #25 on: Fri, 12 September 2014, 21:45:12 »
Depends on how much you use a keyboard, for me it was an obvious decision since I'm typing all day for work.
« Reply #26 on: Fri, 12 September 2014, 23:44:48 »
If I didn't keyboard, I'd have more money for fountain pens
Offline ShawnMeg
« Reply #27 on: Fri, 12 September 2014, 23:51:19 »
For those who obtain vintage mechanical boards for cheap (discarded, in thrift shops, garage sales, estate sales, etc), these certainly bring a lot of bang for the buck in terms of quality and longevity.   Boards such as the Model M are practically bullet proof and will outlast many of the cheaper boards.
I'm not sure if I'd pay for some of the custom boards costing upwards of $200.  It's just not in my budget, and it's the law of diminishing returns.  For me, those boards are not worth it.
I found that I enjoy mechanical keyboards because of the nostalgia, typing experience (the tactile and aural enjoyment), and appreciation of the engineering that went into designing the keyboard.  It makes me want to type more.  The sound of the clicky switches is music to my ears.  I purchased my boards at what I felt was a reasonable price, and in fact sold a couple Model 's for a profit to buy the other boards.  The vast majority of the population will likely be happy with cheap rubber dome crap and not appreciate mechanical keyboards.
IBM Model F122 X 2 internal Soarer's || IBM Model M122 internal Soarer's || AEK II SKCM Salmon ALPS external adb_usb converter ||  AEK M0115 SKCM Orange ALPS click mod external adb_usb converter || AEK M0115 SKCM Salmon ALPS external adb_usb converter ||
Offline PointyFox
« Reply #28 on: Sat, 13 September 2014, 01:01:15 »
I still remember when new keyboards came out with keys that were easier to press and didn't make loud clicking sounds.
Offline thestage
« Reply #29 on: Sat, 13 September 2014, 04:07:12 »
true.
but I have five of them
Offline Grim Fandango
« Reply #30 on: Sat, 13 September 2014, 04:45:30 »
I think that could be true for a lot of people. There are a lot of things that factor into whether or not you should buy one. Time spend behind the pc for example is a factor. Another is whether you can afford to pay more for a keyboard than strictly necessary.
I use them because I like the way they feel when typing (technically I use topre so not mechanical). But that is really a subjective and personal thing. If someone tells me he thinks it is not worth it, I can see where he is coming from.
« Last Edit: Sat, 13 September 2014, 04:51:44 by Grim Fandango »
« Reply #31 on: Sat, 13 September 2014, 04:46:59 »
Offline Razor Lotus
« Reply #32 on: Sat, 13 September 2014, 06:09:48 »
Most things on a hobby level aren't worth the money.
If you want something that is good and will last, yes it's gonna be expensive. But once you go into the hobby and all that, your returns diminish rapidly
Offline Fragil1ty
  • Abre los ojos.
« Reply #33 on: Sat, 13 September 2014, 06:39:39 »
Thoughts?
Depends on the person and their level of use on their keyboards.
If you're a programmer, a web developer or a gamer, then yes they are most definitely worth the money, are they needed? nope, of course not.
Personally, I could never not have a mechanical board, think I'd rather kill myself than go back to using a membrane keyboard, lol.
你搞砸了
Offline oscillik
    • music podcasts
« Reply #34 on: Sat, 13 September 2014, 06:40:15 »
troll thread continues!
Offline johndavis33
« Reply #35 on: Sat, 13 September 2014, 09:44:24 »
I think most people don't care.
However, if you invest 1000+ into a computer, then you should really think about getting some nice peripherals.
HAVE AND WILL KEEP: HHKB - Printed white | Ducky Banana edition - Whites | Model M13 | Unidentified Goodwill keyboard - Simplified black ALPS
TOO BE SOLD: TG3 BL82 - Clears | Wheelwrite 5 - Buckling Springs typewriter
SOLD: Rosewill RK9000 - Blacks | QFR - Blues | Ducky G2 Pro - Greens |
IT WILL BE MINE: Northgate Omnikey - White ALPS
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #36 on: Sat, 13 September 2014, 09:54:34 »
I don't see how spending more on your PC correlates to having to spend more on peripherals. For me, I've budget-built 2 computers so I'd have extra money for keyboards. :p
Offline paicrai
  • mindblank
« Reply #37 on: Sat, 13 September 2014, 09:57:10 »
nice
THE FEMINIST ILLUMINATI
Offline oscillik
    • music podcasts
« Reply #38 on: Sat, 13 September 2014, 10:08:42 »
Corsair 9000DD computer case
Intel 230000X 74-Core CPU, with liquid kryptonite cooling system
386GB of DDR42 RAM
1PB of SSD split into 15x 64GB channels for multiplexed channel access of data RAID 46
penta monitor setup, 25600x2880 resolution
GTX Titan ZZTop 32GB 4-way SLI on-a-single-slot card
Dell rubberdome keyboard lol
Offline TopreFan333
« Reply #39 on: Sat, 13 September 2014, 18:44:45 »
I have been using "the keyboard that came with my Mac" (really a series of keyboards) for YEARS and really it's been fine for the most part.
BUT, I've recently bought a nice quality mechanical keyboard (Keyed Up Labs, Cherry brown switches) and it's just a whole different thing. The light, precise amount of touch that's required to press the keys makes me feel very much like I'm using a high quality instrument to interact with text on my computer. There's just a certain tactile pleasure in interacting with a well-made piece of machinery. Like iOS or not, you pick up an iPhone and it feels good in your hand. You climb into a nice car and shut the door and you hear and feel how precisely everything is fitting together. Same with this keyboard. I'm spending many many hours hitting these keys. Why not invest a comparatively small amount of money into making it feel nice?
All that said, I will admit that I'm actually still making a lot more typing errors because it's only been a week and my fingers are still adjusting to the key travel and slightly higher amount of effort required to press the keys. I'm also bouncing back and forth between this new keyboard and the one on my Macbook Air — which is not a terrible keyboard at all but is just very different.
« Last Edit: Sat, 13 September 2014, 18:48:34 by dchadwick »
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #40 on: Sat, 13 September 2014, 18:52:35 »
Gr8 b8 m8 8/8
Offline SpecTP
« Reply #41 on: Sat, 13 September 2014, 18:57:42 »
Thoughts?
By all means.. stick to your 'big mac' keyboard..  I'll opt for the 'top sirloin' mechanical keyboard.  Every time.. any time.
Offline ConscienceDrop
  • a-are these pbt?
« Reply #42 on: Sat, 13 September 2014, 19:45:09 »
I use my keyboard almost every day for work, for my creative endeavors and for a lot of entertainment.
I can't think of anything else that is a 'luxury' in my like that is more worth the money.
just because a mech is a 'luxury' as opposed to a more necessary item does not mean its 'not worth the money', and a good mech lasts you decades.
A carpenter is going to buy more quality tools that are a joy to use, and will also last him longer because it is his livelihood and also his vocation.
Having a career in computers, or writing or anything else is no different; and so the purchase of tools that make your work a joy is not irrational, its more rational than buying something that makes your work a chore instead of a joy.
Offline Hypersphere
« Reply #43 on: Sat, 13 September 2014, 19:55:09 »
IF you buy something and use it/enjoy it, then it was worth the money to you. I suppose mechanical keyboards might be regarded as a first-world luxury, but at one time, all the computer keyboards were mechanical. My first computer was an IBM XT, and thirty years hence, I started buying XT keyboards on eBay, refurbishing them and installing Soarer's Converter so that I could use them again via USB with my new Mac Pro. I use them in my work -- they are useful and a pleasure to use. Definitely worth the money both times.
Offline flaming_june
« Reply #44 on: Sat, 13 September 2014, 20:49:46 »
Most things in life seldom are.  But mek keyboards are certainly worth MY money.
Offline FrostyToast
  • Litshoard
« Reply #45 on: Sat, 13 September 2014, 21:39:07 »
I once though to myself, "I should buy a massive block of gold and marvel it every day"
And then I thought, "What if I could lustily caress something with the value of a block of gold with my soft and supple fingers for hours on end?"
That was the dream. But now all of my lusty and majestic prizes sit on my desk and make loud noises all day  :))
Quote from: elton5354
Offline EpicSNES
  • how do i keyboard
« Reply #46 on: Sun, 14 September 2014, 01:10:37 »
I type a lot, A LOT, at work and at home. Mechanical keyboards makes it much more enjoyable so I find the high price tag worth it.
Filco Tenkeyless mx blue
Offline Oobly
« Reply #47 on: Mon, 15 September 2014, 05:06:07 »
As with anything, if you do a thing a lot, it's worth getting high quality gear. I write code all day for a living, so a mechanical keyboard is worth it. At home it's more of a luxury, but since I use one all day at work it feels sucky to use anything less at home... so it's worth it there for me, too.
The value of an item to an individual can only be evaluated by that individual. I value the long term health of my hands, wrists and forearms far more than the cost of a mechanical keyboard, so....
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Macsmasher
« Reply #48 on: Mon, 15 September 2014, 15:33:28 »
For me, the decision to move to mechanical keyboards was primarily economic.
I was going through Logitech Wave keyboards every 5 - 6 months. The problem I have always had with membrane boards is that when they get some use, the keys start sticking on the posts. So, if you don't strike the key exactly in the center, the key would sometimes won't register. To compensate for this, you subconsciously start hammering the keys to make up for the keys that stick.
My first mech board was a Das Ultimate with MX Browns. I used that as my only keyboard for over three years. When I finally gave it to a buddy, the key switches still actuated like they did when they were new. (The only reason I gave it away is because I moved to Topre keyboards.)
So, if you add up three years of $50 membrane keyboards replaced every six months, I would have spent $300 over those three years. That $130 Das now looks pretty inexpensive.
Aside from the economic advantages to mechanical keyboards, there're other factors to consider...
Comfort - they're arguably easier on the fingers and joints since you're not hammering keys.
Options - you can select a switch weight as well as tactility (or lack thereof if you prefer a linear key switch) that suits your typing style and preference.
Productivity - I have fewer typing mistakes on a mechanical board. That's partly due to the fact that the keystroke registers approximately half way into actuation.
Enjoyment factor - I can honestly say I enjoy typing on a mechanical board far more than a membrane board.
The above reasons are subjective. Only you can decide if those reasons justify the additional cost of a mechanical keyboard.
However, the economic argument is quite objective for a heavy computer user. In fact, if you're a heavy computer user, it would be financially foolish to NOT to move to a mechanical keyboard.
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #49 on: Mon, 15 September 2014, 20:25:57 »
Eh, they kind of are worth the money, since I've switched to mechs nearly two years ago from membranes, like dells and alienware membranes, I've gotten faster, and really do enjoy typing on this shine. I'm more comfortable and feel like I can type forever
But there are some cheaper boards, cooler master comes to mind, give me a price range for "not worth the money"
Sub $100 boards are around, and I've seen plenty of membranes go upwards of $100 and such. It's also the mentality with most mech boards "I can kill a man with it and continue to type with it".
