Author Topic: What router do you current use?  (Read 102240 times)
Offline watduzhkstand4
« on: Sat, 01 August 2009, 12:33:12 »
I am in need of a new router. The one I currently have is just a piece of sh*t, the Netgear WNDR3300N. I even flashed into DD-WRT v24 micro and it crashes everytime I start a task in my torrent client. So I was wondering what everyone has here and what you guys recommend me. It would be great if there is one that can flash into DD-WRT. I have in mind the WRT54-GL AND WRT54G-TM. Got any other recommendations?
KEYBOARDS
Cherry Blue *Filco Tenkeyless w/ blank keys* w/ red ESC key thanks to Megarat
Cherry Red Noppoo Choc Mini
IBM Model M 1391401 12/15/88
Siig Minitouch w/ White Alps
SOLD
HHKB Pro 2 white w/ blank keys red ESC key and blank WASD keys
HHKB L-2
Cherry Brown Compaq mx11800
Dell AT101W
Cherry Red Leopold 104-key Otaku FC500RR/ABN
Offline bigpook
« Reply #1 on: Sat, 01 August 2009, 12:43:17 »
I built a small pc from parts I got at newegg. The firewall software is IPCop.
Offline huha
« Reply #2 on: Sat, 01 August 2009, 12:55:54 »
I'm using a WRT54GL at the moment. If you want to connect another antenna, it's a bit of a pain, though. Adapters are quite expensive, so I bought a SMA connector and had it soldered to the PCB instead of one of the TNC connectors--lots of PCB abuse going on there, as the SMA connector is notably smaller than the TNC.
I also installed an SD card reader, but haven't actually gotten around to experimenting with it yet.
As a firmware, I use DD-WRT, but I actually don't like it. Tomato didn't really work for me (I'm absolutely clueless why), as did OpenWRT--problems with wireless connectivity with these two for no reason at all. DD-WRT works fine, though.
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline ch_123
« Reply #3 on: Sat, 01 August 2009, 15:02:40 »
I have a D-Link DIR-655, it's really good. Expensive compared with Linksys ones though.
Offline Rajagra
« Reply #4 on: Sat, 01 August 2009, 15:25:04 »
I've been using a US Robotics 8054 for years now. I had to replace the PSU once, other than that it has chugged along doing its job quietly.
I also use two USR 5450s as a wireless bridge. Again, they just do their job transparently, and I had to replace one PSU.
Bear in mind they have been on 24/7 for years.
Offline CX23882
« Reply #5 on: Sat, 01 August 2009, 15:37:52 »
Netgear DG834G V2. Had it a few years now and touch wood it's still going strong. I had to roll back to the last but one firmware because the newest firmware was practically unusable.
Before that, I had the USR8054 and was having some problems with dropped connections. I bought the Netgear because my ISP insisted that the problem was with my equipment. It turned out that the line was at fault, but since I had already opened the Netgear I decided to keep it and sold the USR on eBay.
« Last Edit: Sat, 01 August 2009, 15:39:56 by CX23882 »
Offline CX23882
« Reply #6 on: Sat, 01 August 2009, 15:43:45 »
Before that, I had a USRobotics USR8054, and it worked fine. After a couple of years I began to experience dropped connections and bought the Netgear. It turned out that the line was at fault, and I still got dropped connections. The Netgear could resync much quicker though, so I kept that and sold the USR8054 on eBay.
My line has since been fixed, and even though the chipset in the Netgear supposedly has issues with ADSLMax-enabled lines, I have no problems syncing at decent speeds for my line (I was told I could expect a maximum of 512kbps, based on being >6km from the exchange, but in reality I sync at around 2000kbps, so I can't complain).
Offline cb951303
« Reply #7 on: Sat, 01 August 2009, 16:54:51 »
here is an idea. if you have a home server with 2 empty PCI slots, you can get these and make your own router. It's a little bit more expensive than a regular router but it would be really powerful.
http://www.edimax.com/en/produce_detail.php?pd_id=225&pl1_id=1&pl2_id=44
http://www.sangoma.com/products_and_solutions/hardware/data_networking/s519.html
Filco Zero FKBN87Z/EB
Kensington Orbit K72337US
Offline zwmalone
« Reply #8 on: Sat, 01 August 2009, 17:29:34 »
NetGear WGR614v9 running the default firmware...
Can't get enough of them ALPS
Offline bitflipper
« Reply #9 on: Sun, 02 August 2009, 02:06:07 »
Linksys WRT300N
Offline BucklingSpring
« Reply #10 on: Sun, 02 August 2009, 09:28:12 »
Once again on the Exotic side...
Edge-Core VR200 Powered by Accton
CPU :    Intel IXP425-533
DRAM :    64M
Flash :    16M
The Edge-Core VR-200 is a 16-port Multi-WAN VPN Router which contains 2 WAN ports and 2 configurable WAN/LAN ports, 11 dedicated Ethernet 10/100 LAN ports and 1 dedicated DMZ port and mainly supports small and medium size enterprise business networks with a high security VPN. Through the 2 configurable WAN/LAN ports, the VR-200 can provide up to 4 WAN ports (11 LAN, 4 WAN and 1 DMZ ports) or up to 13 LAN ports (13 LAN, 2 WAN and 1 DMZ ports). It brings high-speed network security to enterprise businesses, remote users, service providers, and data centers. Its design combines firewall, VPN support, NAT, and powerful traffic management with Fast Ethernet connections to provide consistent network infrastructure security. The unique configurable WAN/LAN ports allow users to configure as WAN port or LAN port for providing tremendous flexibility. In addition, with multi-WAN ports, the device can have backup WAN interfaces.
Boards I own, click ->
Offline iMav
  • geekhack creator/founder
« Reply #11 on: Sun, 02 August 2009, 19:38:20 »
McAfee UTM Firewall for my home network.
McAfee Firewall Enterprise for my home office/lab.
Offline timw4mail
    • https://timshomepage.net
« Reply #12 on: Sun, 02 August 2009, 21:35:54 »
Linksys WRT54G
Although I have the one with the gimped memory capacity, so I have to use the mini version of DD-WRT...and I can't use Tomato...
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline iMav
« Reply #13 on: Mon, 03 August 2009, 00:29:58 »
Quote from: timw4mail;106304
Linksys WRT54G
I use Tomato on a Linksys as a wireless bridge.
Offline talis
« Reply #14 on: Mon, 03 August 2009, 11:03:48 »
Quote from: ch_123;106084
I have the same one, and am currently in the market for a replacement.  Under any sort of medium to high concurrent connection load it starts to fail.  With only a single torrent running web pages take 8-10x longer to load (tho when I can hit a speed test site the single connection shows close to 20Mb of bandwidth still available).
I'm considering either picking up an old juniper or cisco on ebay, or just building one out of an old linux box.
« Reply #15 on: Tue, 04 August 2009, 21:51:21 »
Thanks for all the inputs everyone! I just got my WRT54GL today and it's running 12548 mini @ 233mhz OC. Everything is great as of now.
Stuff coming in:
- 2x 9dbi Omnidirectional antenna
- Copper and aluminum heat/ramsinks ready to get it to 250mhz stable and maybe even 275!
KEYBOARDS
SOLD
HHKB L-2
Dell AT101W
Offline huha
« Reply #16 on: Tue, 04 August 2009, 22:34:07 »
Do you really need omnidirectional antennas? 9 dBi omnidirectional antennas should perform better when you're on the same level as the router, but much worse when there are height differences. There's only so much power to use when transmitting, so the antenna gain merely describes how much stronger the signal will be compared to an ideal isotropic radiator. How much that'll be depends largely on antenna geometry and therefore area the antenna can serve. So if you just need to give wireless access to rooms in one direction around you, an area antenna could be the better choice--they offer even more gain. Really depends on your setup, though--maybe your bottleneck is somewhere entirely different.
Remember to adjust transmission power for new antennas--you'll have to calculate (there are websites on how to do that, so no big deal) the new transmission power so you'll stay within EIRP limits (basically, transmission power per angle, based on an ideal isotropic radiator).
-huha
Offline InSanCen
« Reply #17 on: Fri, 07 August 2009, 04:51:58 »
Quote from: huha;107051
I spit on EIRP limits...
WRT 54GS, DD-WRT Micro, Dual-Biquads on a Elliptical dish. 24dBi.
I am going through bricks with a very high Iron content though, attenuates your signal to hell and back, hence the need.
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
Offline DrunkenDonut
« Reply #18 on: Fri, 07 August 2009, 15:01:58 »
Hrm. I see that custom firmware for WRT is accounted for but not much else. How about either full PCs or embedded hardware with wireless, running pfSense?
I used to run a full PC with pfSense installed (old PCs laying about, may as well put them to use, right?) but then switched to an ALIX.2C3 with an atheros-based(I think) wireless miniPCI card. No moving parts, low power consumption, etc. but most importantly still running pfSense. I have a high power wireless card as well, but haven't used it yet.
The beauty of pfSense is features and customization. You can basically make it do what you want. Want a router/firewall? Done. Want a filtered bridge? Done. Packages are also available so you can add some popular 3rd party software for more monitoring, filtering options, etc. All around cool stuff, and it's FreeBSD/NanoBSD based, so it has good hardware compatibility.
*Hang on to your wallet!*
BTC E5X5R5BTC-5339R-0 (\'90), MS Natural Keyboard Pro (\'99), Sun Type 5c, 2x 1391401, DASK3ULT (\'08), ABS M1, Dell AT101W, M4-1
FKBN87M/EB (\'09), FKBN87ML/EB (\'09), FKBN87Z/EB (\'09), FKBN87MC/NPEC (\'09), G80-3000LQCDE-2 (\'11)
« Reply #19 on: Fri, 07 August 2009, 15:04:11 »
So yea... I got really bored =D
KEYBOARDS
SOLD
HHKB L-2
Dell AT101W
Offline bigpook
« Reply #20 on: Fri, 07 August 2009, 16:39:19 »
Quote from: DrunkenDonut;108000
The alix hardware looks interesting. I am currently using ipcop on a micro-atx form factor which is still way too big. I may need to give that a try. It looks like it would be pretty slick.
« Reply #21 on: Sat, 08 August 2009, 00:25:46 »
I like 'em. I was considering a Soekris before I found the ALIX boards. They've updated them in the past year or two. The new one fixed some issues with high power miniPCI cards and some other things that I can't recall right now. The D series is now current.
Offline iMav
« Reply #22 on: Sat, 08 August 2009, 04:33:52 »
I've got a couple of routers I built with WRAP boards and currently have m0n0wall on them.
Offline bigpook
« Reply #23 on: Sat, 08 August 2009, 06:36:31 »
Quote from: iMav;108142
It looks like they are EOL and the alixXXX replaces them.
I take it the 9 pin serial  connector is for a serial console. Were you satisfied with their performance?
Offline bhtooefr
    • bhtooefr.org
« Reply #24 on: Sat, 08 August 2009, 07:26:07 »
I've got a WRT54G... I think it's v7.1? Whatever it is, it's gimped. I'm running DD-WRT v24sp1 micro. (Yes, I've changed my firewall rules to fix the exploit.)
Anyway, I'm thinking of getting an Asus WL-520gU, and putting OpenWRT on it, and hacking the crap out of it. See, it's got a USB host port, so you can have all sorts of fun with that. (And it's not gimped like the WRT54G is now.)
Offline bigpook
« Reply #25 on: Sat, 08 August 2009, 09:06:23 »
Quote from: bhtooefr;108159
wow. the pricing on the Asus is pretty good. Out of the box it looks to support a virtual DMZ but seems to only support VPN pass through..
I need to read up on DD-WRT and Tomato and see if it would work with the Asus. Ideally, the virtual DMZ would be supported and VPN endpoint would be supported. OpenVPN would be ideal if possible.
Offline bhtooefr
    • bhtooefr.org
« Reply #26 on: Sat, 08 August 2009, 09:13:37 »
I know DD-WRT is supported on the Asus...
Also, there's a cheaper version of that Asus without USB. I forget the model number, but it's literally the same device with the USB components missing (and even a list on the PCB of the parts that need to be added to make it into a USB version.)
« Reply #27 on: Sat, 08 August 2009, 09:26:21 »
My friend got an Asus but I don't think he's liking it too much because all the settings he saved goes back to default for no reason in DD-WRT.
KEYBOARDS
SOLD
HHKB L-2
Dell AT101W
Offline bigpook
« Reply #28 on: Sat, 08 August 2009, 09:33:42 »
yeah, but at 44 dollars its still a pretty good deal. I will order it straightaway once I confirm it will act as a VPN endpoint, and support virtual DMZ.
Offline Xuan
« Reply #29 on: Sun, 09 August 2009, 00:37:48 »
Hi, I'll do this noob question; What would I need to make a Wireless router with a PC?
I'm currently ip-masquerading with mi server and hooked a cheap wireless router setted up as a bridge to serve wlan pcs. But I'm thinking of replaceing it because it doesn't work well, so may I expand the server somehow or just get another Wlan router (preferably supporting some dd-wrt like firmware)?.
Offline iMav
« Reply #30 on: Sun, 09 August 2009, 01:10:59 »
Quote from: bigpook;108149
I built them a few years ago.  Never had a problem with performance.
Offline majestouch
  • * Commercial Vendor
    • http:///elitekeyboards.com
« Reply #31 on: Sun, 09 August 2009, 02:48:01 »
I like the Buffalo WHR-HP-G54..even though it looks like you picked up one of the linksys boxen. The Buffalo has a smaller footprint and better stock firmware than the linksys/cisco. Additionally, it becomes rock solid when you put DD-WRT on it.
http://www.amazon.com/Buffalo-Technology-WHR-HP-G54-Wireless-G-Performance/dp/B000AOKTJ8/ref=sr_1_1?ie=UTF8&s=electronics&qid=1249803723&sr=1-1
Offline bigpook
« Reply #32 on: Mon, 10 August 2009, 16:40:23 »
the netgate site has an alix 3 port with pfsense already installed package available. a little pricey, sort of, but would work. It supports openvpn as an endpoint and has 3 ethernet ports.
I still need to read more on the tomato and WRT firmware to make sure what their limitations are.
Offline Hofy
  • Voids Warranties
« Reply #33 on: Thu, 20 August 2009, 07:53:09 »
Buffalo WHR-HP-G54 here with Tomato firmware.
Rock solid stable for 2 years now.  Bonus is having complete control of the band with and connections of the PCs connected to it.
Poker II Cherry MX Blue
Filco TenKeyless Zero Fukka
Cherry ML4100
IBM Model M 1391401 Buckle Spring Luvin
Offline Cake_Eater
« Reply #34 on: Sun, 30 August 2009, 23:24:11 »
WRT54GL with Tomato, but really anything that you can put Tomato on will suit nearly any non-N purposes. I'm still hoping that Tomato will be re-written for the WRT160NL, that happens and the GL gets relegated to wireless extender duty.
Offline D-EJ915
« Reply #35 on: Sun, 30 August 2009, 23:32:46 »
Quote from: majestouch;108366
I have that and a WRT connected via WDS to bridge my up and downstairs
Offline NathanA
« Reply #36 on: Mon, 31 August 2009, 20:31:16 »
I'm running MikroTik RouterOS on one of their RouterBoards.  Great stuff, their software, and the hardware isn't bad either.  You can also run RouterOS on an x86 box and "roll your own."
-- Nathan
Offline timofonic
Re: What router do you current use?
« Reply #37 on: Thu, 17 March 2016, 23:16:39 »
Necroposting...
What do you use these days? I would like to know it from the original forum posters too, to know how they evolved :D
What do you think about Alpine Linux?
Offline alexjd99
  • oozing through the cells of one's own construction
« Reply #38 on: Thu, 17 March 2016, 23:24:16 »
Nighthawk X4
I don't have any complaints. I get around 120 down and 20 up. Not sure if it's because I have a pretty great wireless adapter, this, or both of them, but I've had great results with it.
it also looks pretty rad
Offline Leslieann
« Reply #39 on: Fri, 18 March 2016, 01:37:10 »
Currently I use an Asus Rt-N66U, it's WRT compatible, very fast, hard to bog down. It's probably a year and a half old, and it's been great. I run the stock firmware, but I always buy routers I can change firmware after some bad experiences.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #40 on: Fri, 18 March 2016, 02:15:52 »
I haven't upgraded since the N66u..  The only AC gear in the house are fones, and that's kinda a waste of time to go AC..
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #41 on: Fri, 18 March 2016, 12:24:22 »
Holy necro!
It's all about pfSense these days, running it on a little embedded platform, you can get the APU hardware for around $200 straight from pcengines (designer) or minibox (us distro)
Offline dgneo
  • Supervillain
« Reply #42 on: Fri, 18 March 2016, 12:26:15 »
Holy necro!
This is my game plan, DIY Routers FTW.
Currently using an RT-N66U with Merlin's ASUSWRT running on it, solid as a rock.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #43 on: Fri, 18 March 2016, 12:32:35 »
Offline jwaz
  • * based mod
« Reply #44 on: Fri, 18 March 2016, 12:35:21 »
My BLT drive just went AWOL  ???
« Reply #45 on: Fri, 18 March 2016, 14:16:09 »
I've got this big project due tomorrow for Mr. Kawasaki, and if i dont get it in he's gonna ask me to commit hari kari. You know these Japanese management techniques.
Offline N3RDLY
    • G33k.works
« Reply #46 on: Fri, 18 March 2016, 14:17:34 »
I love my Ubiquiti 5 port POE router.
  • Live long and prosper
« Reply #47 on: Fri, 18 March 2016, 14:20:30 »
Just upgraded to an AC68U; I had to factory reset it once to resolve some intermittent latency issues, but it has been fine ever since.
tp thread is tp thread
Offline LiquidEvilGaming
    • LiquidEvilGaming Youtube
« Reply #48 on: Sat, 19 March 2016, 04:11:16 »
Asus - N900 Dual-Band Wireless-N Gigabit Router currently though i may upgrade to AC wireless eventually.
It's a fairly solid router mines one glaring flaw it runs....HOT! like fry an egg on it hot.   I have an external USB fan pointed at it which keeps it within normal levels but without the fan it gets way too hot for a router for my liking.
Current Daily Driver/s
White Leopold 750R MX Reds
Head of LiquidEvilGaming on Youtube
i7 4790k/16GB DDR3/GTX 1060 6GB SSC/256GB Samsung SSD/2TB SSHD/W10
« Reply #49 on: Sat, 19 March 2016, 11:16:10 »
u mean the N66 U?
I run mine with the top lid off, and it's on a shelf, so I rigged a fone charger to a 120mm fan to cool it.
