Author Topic: Any of you guys own Printers?  (Read 4637 times)
« on: Sun, 10 May 2015, 12:56:01 »
So.. I print @ home maybe 3 times a year..
But pretty much each and every time.. I have to refill the cartridge, or shoot some alcohol and water in there, and shake it up.. hahahaa
Which er,  printer doesn't dry EVER,  so I can use it the 3 times a year and not have to go through this silly routine..
This is for the I need printing NOW moments,  which is seldom, but necessary.
No COLOR..
Just black.
Offline azhdar
  • Praise the AZERTY god
Re: Any of you guys own Printers?
« Reply #1 on: Sun, 10 May 2015, 12:59:16 »
#print@work
Azerty Propagandiste
Offline jonathanyu
« Reply #2 on: Sun, 10 May 2015, 13:10:50 »
get a laser printer
« Reply #3 on: Sun, 10 May 2015, 13:11:20 »
My brother printer was on the same cartridge for about 2-3 years. And it was the starter cartridge that doesn't have that much ink.
Laser ftw.
Offline Asininity
« Reply #4 on: Sun, 10 May 2015, 13:12:16 »
Your only bet would be a laser printer. The heads on inkjet printers will dry out over time and there's nothing that can be really done about that other than alcohol baths. Since laser printers use a powder there's not dried ink to clog the heads. All you have to worry about is dust which can mess with your print quality. So either way you may have to clean the printer but a laser printer is going to be a lot less hassle than inkjet.
So buy a monochrome laser printer.
« Reply #5 on: Sun, 10 May 2015, 13:38:24 »
So..  ANY laser printer will NOT dry up right?
Has technology come so far?
Offline Asininity
« Reply #6 on: Sun, 10 May 2015, 14:29:05 »
Yes. Laser printers don't use liquid ink they use powdered ink. So there's no pesky printer heads getting all mucked up with dry bits. Dusts still a issue though, so it's not a perfect solution.
« Reply #7 on: Sun, 10 May 2015, 15:29:26 »
Could you elaborate on the Dust issue.
Is it dust from outside, or dust from within the printer?
I can keep it covered, since I will only use it 3 times a year..
Offline Asininity
« Reply #8 on: Sun, 10 May 2015, 20:11:24 »
Dust from outside getting into the printer. Sometimes dust can get on the laser and mess with the focus, producing blurry text or so I've heard. I've never had a problem with laser or inkjet printers (until they die naturally) but I use my printer a lot so that's probably why. It really shouldn't be that much of a issue. Your only choices are really inkjet or laser and laser is the less likely of the two to have problems from sitting around.
If you only print three times a year why bother getting a printer? You could just take your files to Office Depot or wherever. If you print only a dozen pages a year it'll take many, many years to reach the cost of a entry level printer.
« Last Edit: Sun, 10 May 2015, 22:04:37 by Asininity »
« Reply #9 on: Sun, 10 May 2015, 22:58:05 »
The 3 times a year when it's a 'murgency..
Offline Asininity
« Reply #10 on: Sun, 10 May 2015, 23:46:24 »
Then don't have emergencies or "'murgency(s)."
Then you have no need for a printer.
« Reply #11 on: Sun, 10 May 2015, 23:48:51 »
The odd Things happen..
I am planning accordingly for just such occasions..
Offline Hak Foo
  • Make America Clicky Again!
« Reply #12 on: Sun, 10 May 2015, 23:53:54 »
Laserjet 4 or 5.  Indestructible.
Overton130, Box Pale Blues.
Offline fanpeople
« Reply #13 on: Mon, 11 May 2015, 01:52:17 »
« Reply #14 on: Mon, 11 May 2015, 02:10:44 »
Or get an old printer from work which has its maintenance contract expired, but which is otherwise perfectly serviceable for 3 print jobs a year (assuming small to moderate print jobs, of course).
Bonus if you get toner cartridges and paper too!
Offline jacobolus
« Reply #15 on: Mon, 11 May 2015, 02:14:43 »
Laser printer technology has been fine for 30+ years, at this point. 15–20 year old printers still work great, and can be bought used for cheap.
Offline FoxWolf1
  • 154
« Reply #16 on: Mon, 11 May 2015, 15:22:46 »
Offline tbc
« Reply #17 on: Mon, 11 May 2015, 15:29:02 »
any laser printers with eprint?
wireless printing is too gawd damn useful for me to give up
« Reply #18 on: Mon, 11 May 2015, 16:21:28 »
There are options for that. You could also get a router that supports printers if you don't want to spend more on the printer.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #19 on: Mon, 11 May 2015, 16:42:11 »
I don't keep a printer at home so when I get a call to do work at 10pm I can say "Sorry... no printer". Saved me countless times.
Offline tbc
« Reply #20 on: Mon, 11 May 2015, 16:45:36 »
well, to be more specific, i want printing over email, rather than just wireless.
« Reply #21 on: Mon, 11 May 2015, 22:08:20 »
Ah.  This sounds like a smartphone-centric thing, which I have little experience with.  :P
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #22 on: Mon, 11 May 2015, 22:14:10 »
For me, anything that is more than 2 pages, or I need it immediately, I don't print at home and wait until I get to school where they have the laser printers. Really nice & fast.
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #23 on: Mon, 11 May 2015, 22:19:24 »
I do not, I usually print whatever I need to print at work before I leave.
« Reply #24 on: Mon, 11 May 2015, 22:24:11 »
I need this for 'Murgency printing..
Yes,  I too know that pilfering @ work is the golden-standard.
