Author Topic: I need a new keyboard.  (Read 2436 times)
Offline ANightOnCloudNine
« on: Sat, 26 September 2015, 08:26:25 »
The current keyboard I have is quite bad for typing, razer deathstalker (i know i know i fell for the marketing trap) I like wrist rests and I would like a keyboard that fits this criteria
- 65-90 grams of force to actuate
-feel of a membrane but more sturdiness and less mushyness
-can fit lots of 3rd party wrist wrests or keyboard holders (that have built in wrist wrests with the keyboard holder)
-good grippy feet
Offline absyrd
  • CPT HYPE PADAWAN
Re: I need a new keyboard.
« Reply #1 on: Sat, 26 September 2015, 09:21:12 »
Are you SURE about 65-90g?
You won't get more of a "sturdy membrane" feel unless you try out a 55g Realforce. Built like a tank and you can just get a custom wrist wrest for it.
« Reply #2 on: Sat, 26 September 2015, 09:39:18 »
Thanks for the suggestion, I'll look into it. BTW FROM NOW ON anyone reading this thread I changed my mind to at least 55g because i just considered the feeling of MX reds.
« Reply #3 on: Sat, 26 September 2015, 10:34:05 »
(just finished looking at some reviews and sound tests) It looks, sounds and feels awesome since I pulled out some old cheap chinese keyboards out of my closet that are about 45-50 grams actuation weight and the realforce probably feels better too, I'm def gonna try it out, thanks dude.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #4 on: Sat, 26 September 2015, 10:38:08 »
No problem!
55g Realforce is very tactile, satisfying sound, solid. Don't even think of comparing activation weight to equivalent weight of a 55g MX switch. Apples and oranges.
Offline Charizard
« Reply #5 on: Sun, 27 September 2015, 21:51:04 »
I second the Realforce 55g, it's my favorite board.
Offline daerid
    • Rossipedia
« Reply #6 on: Sun, 27 September 2015, 21:59:01 »
Typing this post on a RealForce 55g. Hands down the best switch ever made.
Offline Charizard
« Reply #7 on: Tue, 29 September 2015, 00:33:35 »
^^ This guy knows what's up.
« Reply #8 on: Tue, 29 September 2015, 00:55:45 »
^^ both these guys are newbs...
The switches don't matter whatsoever,   It's all about the layout, the split,  and the Tenting...
