Author Topic: For my next board, should I get...  (Read 7904 times)
Offline macguy80
« on: Mon, 21 December 2015, 01:37:43 »
I can't decide, so I respectfully ask you:
A. KUL with browns (I love my KUL with clears, but after a while it's just too tiring. I know, ideally, you're not supposed to bottom out clears, but for some (strange?) reason, I just love the CLACK that Cherry MX switches make when they bottom out., so therefore mx browns!?
—OR—
B. Matias Tactile Pro 4 (SO much more tactile and crisp than the QuietPro it would effectively replace)?
Yeah, I know there are so many other and possibly better boards out there, but those are the two I'm debating between. The price difference is only $20 between the two.
Offline bocahgundul
  • a seal
Re: For my next board, should I get...
« Reply #1 on: Mon, 21 December 2015, 01:51:06 »
HHKB bro   :p
« Reply #2 on: Mon, 21 December 2015, 01:53:09 »
Browns are terrible, matias are great!
Hhkb would be top though :D
Offline macguy80
« Reply #3 on: Mon, 21 December 2015, 01:56:21 »
I hear ya on the HHKB -- if I could wrap my head around the layout, I'd go for it, but type-S of course.
For me the dream Topre board would be a RF 87u all 55g type-S, but, barring that, so far Matias 1 browns 0 :)
Offline fanpeople
« Reply #4 on: Mon, 21 December 2015, 02:50:19 »
HHKB
Offline sth
  • 2 girls 1 cuprubber
« Reply #5 on: Mon, 21 December 2015, 02:59:29 »
hhkb
« Reply #6 on: Mon, 21 December 2015, 03:29:28 »
SSK
Offline bocahgundul
  • a seal
« Reply #7 on: Mon, 21 December 2015, 03:34:13 »
« Reply #8 on: Mon, 21 December 2015, 03:34:57 »
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #9 on: Mon, 21 December 2015, 18:57:51 »
Just to give some insight about wrapping your head around the HHKB layout, I've had the pleasure of using some HHKB's but don't own one and just in a days time or so of using an HHKB I've actually changed my layout because it really did make sense to put backspace on backslash and ctrl on caplocks.
GON NerD TKL DTA Edition
Offline ileben
« Reply #10 on: Mon, 21 December 2015, 19:31:33 »
[...] it really did make sense to put backspace on backslash and ctrl on caplocks.
I still don't understand the Ctrl on Capslock hype. I'm a programmer and the combo I use by far the most is Ctrl+XCV. Pressing that with Caps seems to require much more strain, at least for my hand (and my hands a big). The natural position for pinkie keys is offset downwards from other fingers, not upwards, that's also why all the ergo builds shift the last column down. Can someone enlighten me?
RF 87 55g (silenced) | FC660C (silenced) | Unicomp Ultra Classic | Filco MJ2 Brown | Matias Mini Quiet Pro
Offline fanpeople
« Reply #11 on: Mon, 21 December 2015, 19:39:48 »
To add to this, I was comfortable with the traditional layout of keyboards and dont generally stray from the norms when it comes to technology (plus only learnt to touch type about a year prior, although this could have made it easier to adapt). It took me possibly a week to be comfortable with the layout and then maybe another 1-2 weeks for it to be instinct.
Offline Macsmasher
« Reply #12 on: Mon, 21 December 2015, 19:55:15 »
I'm also a dev, and live on Ctrl+ZXCV. I love having Ctrl on home row. Left hand never leaves home row. And since you copy / paste a lot, Ctrl+L or R Arrow to jump by words instead of characters is much faster. Just my 2 cents. And for non-coding stuff, Ctrl on home row works great for Ctrl+R / S / P / N.
Offline Altis
« Reply #13 on: Mon, 21 December 2015, 21:14:33 »
I'm with ileben on the Control in Caps Lock position... I find the pinky finger does not fall there naturally, and becomes especially awkward for the Ctrl+ZXCV keys.
OP, the KUL ES-87 allows you to have a similar layout to the HHKB. The DIP switches on the bottom let you swap CapsLock/Control and even the Backspace/'\', making it similar to the HHKB. You just don't have the function keys for the navigation keys.
« Reply #14 on: Mon, 21 December 2015, 22:50:37 »
Shouldn't you be refactoring instead of copying code? :p
I find on HHKB with Ctrl on the home row I just have to move my pinky slightly to the left.
With Ctrl on the bottom row, I tend to use my thumb, and end up with my left hand in a more awkward position.
Offline Bucake
« Reply #15 on: Mon, 21 December 2015, 23:01:14 »
on my hhkbp2 (with hasu's controller) i turned LAlt into LCtrl; which is actually a pretty sweet spot!
(although it does feel a little bit weird when LCtrl is 1u)
edit, picture:
« Last Edit: Mon, 21 December 2015, 23:06:02 by Bucake »
Offline Dongulator
« Reply #16 on: Mon, 21 December 2015, 23:05:46 »
Everyone is saying hhkb... hhkb.. The obvious choice is the Leopold Fc660c.Happy Hacking Professional.... more like Happy Hipster Professional.. amiright :rolleyes:
Offline Bucake
« Reply #17 on: Mon, 21 December 2015, 23:07:29 »
60% with blank caps and programmable can't really be beaten.
nice try, but sorry mate :cool:
« Reply #18 on: Mon, 21 December 2015, 23:09:23 »
Cheeky :p
Offline Dongulator
« Reply #19 on: Mon, 21 December 2015, 23:20:22 »
http://deskthority.net/wiki/Leopold_FC_660C
I'll just leave that here and let  macguy80 make the decision.
Offline bocahgundul
  • a seal
« Reply #20 on: Mon, 21 December 2015, 23:28:04 »
HHKB fo sho
choose wisely macguy
Offline macguy80
« Reply #21 on: Mon, 21 December 2015, 23:59:05 »
If I were going to choose another Topre board, it would definitely be HHKB Type-S. The upstroke sound on a stock RF board makes the experience less enjoyable for me. I don't know if standard HHKB or even the Novatouch is different in that regard.
Youtube videos only help so much, as I never noticed the upstroke sound until I actually typed on it.
I do wish it had dedicated arrow keys though. I do wish it had dedicated arrow keys though. There is the JIS model, but I gotta wonder, could I *ever* get used to such a small spacebar? :)
Offline macguy80
« Reply #22 on: Tue, 22 December 2015, 00:04:54 »
Altis, thanks for that! I pretty much switched it to Mac mode, then forgot about them. That will help me "test the waters," to a degree, anyway. :)
Offline bocahgundul
  • a seal
« Reply #23 on: Tue, 22 December 2015, 00:10:01 »
Nothing is impossible JUST BUY IT!!!!!!!!!!
Offline Bucake
« Reply #24 on: Tue, 22 December 2015, 00:17:06 »
any (unsilenced) topre switch has a noisy clack on the upstroke. consider getting silencing-rings for your topre switches if it's the upstroke that you dislike. (i believe hypersphere rings are hyped around here.)
a type-s might be a better option, but that would also be a bunch more expensive.
also: HHKB has the option to be fully programmable (with hasu's controller)
also: MX browns are one of the worst switches i've ever typed on. buying a keyboard with them is like joining the dark side.
Offline bcredbottle
« Reply #26 on: Tue, 22 December 2015, 06:37:15 »
Offline macguy80
« Reply #27 on: Tue, 22 December 2015, 13:52:36 »
ERGODOX
That one won't be making my list. With my cerebral palsy, typing on anything that unconventional would be difficult for me.
Offline bcredbottle
« Reply #28 on: Tue, 22 December 2015, 13:58:08 »
ERGODOX
Interesting. I was under the impression that a split board was better for people with muscular or nerve-based disorders. Is it difficult for your hands to "learn" new patterns or is it just a bad angle for you?
Offline fanpeople
« Reply #29 on: Tue, 22 December 2015, 15:41:35 »
ERGODOX
Tp passed away from child germs this morning. But I am happy to answer any dox related questions
Forget ergodox, aquire HHKB
Offline clacktalk
  • circa 2015
« Reply #30 on: Tue, 22 December 2015, 15:46:33 »
qfr w/ frosty flake
and v blacks/ergoclears/zealios
diary of a clacktalk
radio_killah: too much frank
Offline macguy80
« Reply #31 on: Tue, 22 December 2015, 18:27:23 »
Cerebral palsy affects each person differently. For me, it would probably be a little of both those problems. :)
I only type with my middle, index, and thumb on each hand. The other two fingers on each hand don't work well enough to control them precisely enough, with the exception being my left pinky, which I can use to hit left ctrl, shift, or caps lock, but not tab, backtick, or Escape. :)
Offline ideus
  • Björkö.
« Reply #32 on: Tue, 22 December 2015, 19:38:35 »
If you like clears but you feel them a bit in the strong side you should try ergo clears, I found them to be the best tactile with the right amount of force, not at all tiring for long typing sessions.
Regarding the OP I am not sure if you want to get any recommendation, but Topre are totally different.
Offline macguy80
« Reply #33 on: Tue, 22 December 2015, 19:53:28 »
@ideus,
I would get ergo clears in a heartbeat, if they were commercially available. My cerebral palsy prevents doing those sorts of mods myself.
As for Topre, I am well acquainted. I love my uniform 55f Realforce, except for the upstroke sound.  :)
Offline ideus
  • Björkö.
« Reply #34 on: Tue, 22 December 2015, 19:55:58 »
@ideus,
There are some fellow at GH that may be happy to make a custom build for you, or to mod some switches if you want to solder them yourself. Otherwise, if you have the patience you can get a keyboard assembled according with your specifications from GON, just be aware that it may take some time, but it worth every peny and every day you wait for it.
