Author Topic: Stepmania. A.k.a. pure distilled RSI  (Read 9167 times)
Offline jacobolus
« on: Mon, 11 January 2016, 05:09:08 »
This is ridiculous: http://youtu.be/avwFMVG8x-A#t=14m12s
I am afraid the guy will wreck his wrists and fingers though.
Offline bocahgundul
  • a seal
Re: Stepmania. A.k.a. pure distilled RSI
« Reply #1 on: Mon, 11 January 2016, 05:16:18 »
These guy are awesome  :cool:
Offline Jokrik
« Reply #2 on: Mon, 11 January 2016, 05:20:35 »
ahahaha
only 4 keys will die first from the 50 million clicks
Offline Glenmael
« Reply #3 on: Mon, 11 January 2016, 05:28:49 »
Wow, that's insane.
Offline jacobolus
« Reply #4 on: Mon, 11 January 2016, 05:47:31 »
Not quite as fast or as much injury risk, but arguably harder, this is also insane: http://youtu.be/XIeYb_vLirQ#t=12m25s
Game is Crypt of the Necrodancer. It’s a combination of DDR-style rhythm game / roguelike game.  You need take some movement/action on every beat of the music, while fighting your way through a randomly generated dungeon full of randomly moving enemies.
In particular, the guy does a live try (during a marathon) of the Coda character in the game, which is nearly impossible to finish. Any missed beat or hit from an enemy is instant death, and the character requires double the normal beat speed. A bunch of the enemies drop gold when they die; walking on the gold is instant death.
Offline henz
  • What?
« Reply #5 on: Mon, 11 January 2016, 05:48:50 »
The destroyer of keyboards !
« Reply #6 on: Mon, 11 January 2016, 06:28:36 »
K, i'll admit.  that's pretty hard..  I've only ever played with one hand, and it's impossible to do that many 3keys with 1 hand.
« Reply #7 on: Mon, 11 January 2016, 06:52:56 »
Stepmania! I love this game.  :)  Don't play nearly as much as I used to and I'm by no means spectacular, but it is a fun game.
Offline KRKS
  • Your friendly neighbourhood umbrella
« Reply #8 on: Mon, 11 January 2016, 11:04:34 »
It's impressive, even if as a BMS doubles player I have to post the obligatory
>only 4 keys
and yawn.
The increasing power of Massdrop WILL kill the community group buys - don't come crying to me after it happens when you're too stupid to see it now. Join me in saving the community!
MD = NO $, NO EXCEPTIONS
« Reply #9 on: Tue, 12 January 2016, 04:00:31 »
you won't get rsi if you play with 2 hands..  but one handed, the jumps are too heavy on the wrist.
« Reply #10 on: Tue, 12 January 2016, 04:31:17 »
Training to become Cherry switch longevity tester?
Offline jerue
  • (Whenever that happens :P)
« Reply #11 on: Tue, 12 January 2016, 06:57:22 »
long time DDR/stepmania fan checking in...
the secret sauce for stepmania is to not use a mech keyboard. rubber domes perform significantly better IMO. You aren't worried about weird actuation points. Topre kind of works but I wouldn't do that to such a board.
« Reply #12 on: Tue, 12 January 2016, 10:38:11 »
I've played on mechanical, it works fine..
The mid travel actuation time is well below the marvelous timing threshold for perfect/marvelous which is 2 frame and 1 frame..
Offline Nai_Calus
  • CLACK
« Reply #13 on: Tue, 12 January 2016, 14:21:14 »
Ah good old Stepmania. No substitute for the real thing unless you have an arcade replica hard pad and a kicking sound system, but an amusing diversion nonetheless. I still play it sometimes. The muscle memory, once formed, never goes away.
I never got too big into fanmade stuff, most of it I've tried just aims for being lolcrazyhard! rather than anything original or fun or even following the damn music. (There are of course exceptions to this, such as the old Bemaniruler versions of A and V, which are composed of utter madness but still follow things in the actual song, or a version of Stoic that came out before Extreme did that did lots of fun nonsense with freezes and BPM changes... Well back then I was using DWI but the files still work.) I have motor issues that make moving that fast basically physically impossible so it's not even attainable, let alone enjoyable. I've always been the same way with official stuff too. So much stuff just falls into lol 16th/32nd step jump streams because I can!1. Pfft.
Now if only I could get a decent Doubles experience on a keyboard. Maybe whenever I finally get my Planck, that'll have enough gridded keys. Still no substitute for the real thing though. Gods I miss having DDR machines around. :(
...I'm still irritated that you can get an AA without a full combo nowadays. What is this nonsense.
- IBM 4704 Model F 107-key "Bertha"
Other boards: Kinesis Essential, Infinity(G.Clears), Ergodox(MX Blues), Monoprice 9433
Eternally searching for Celestial Blue BS V2 and blue/purple Bros.
Offline jacobolus
« Reply #14 on: Tue, 12 January 2016, 14:33:27 »
In that video they said that at 60 frames/s “marvelous” is actually a 3 frame window.
The guy in the video had what appeared to be some kind of board with Cherry MX switches. He seemed to be doing fine with the timing.
If you watch this video, his hands and fingers are extremely tense, and he’s holding his hands in a pretty uncomfortable way for his wrists (extended and pronated) while also pressing the keys pretty hard (this might be inevitable with such keying speed requirements), causing a fair amount of shock with each keypress. Using most types of rubber dome boards would be even worse from a mashing perspective, because they don’t actuate reliably until the very bottom of the stroke.
Actually pretty much everything about his posture (neck, back, shoulders, arms, hands) is pretty far from a neutral position and pretty tensed up. I hope he takes frequent breaks and doesn’t practice too long at a stretch, or injury seems pretty likely.
« Last Edit: Tue, 12 January 2016, 14:48:06 by jacobolus »
« Reply #15 on: Tue, 12 January 2016, 18:34:32 »
Plus or minus 1 frame is 3 frames..
Plus or minus 2 frames is 5 frames..
Offline jacobolus
« Reply #16 on: Tue, 12 January 2016, 19:07:11 »
In any event, the key is that the actuation be predictable/uniform and known to the player. There’s a delay of several frames between the brain directing the finger to move and the actual keypress, and a time mismatch between when the brain gets audio, visual, and finger touch feedback. Luckily human brains are really good at blending these different signals together to make them seem instantaneous, and at timing motor actions to correspond to a rhythmic beat.
It would be interesting to test whether rubber dome or e.g. MX switches work better for this type of game. My own suspicion is that the experiment would tell you that whatever keyboard you practiced on resulted in the “best” performance. (At least as far as time accuracy is concerned; different switches might have different peak keying speed.)
« Last Edit: Tue, 12 January 2016, 19:09:15 by jacobolus »
Offline saxophone
« Reply #17 on: Wed, 27 January 2016, 08:31:51 »
Where's the osu mania reply?
t=8m14s
Offline KRKS
« Reply #18 on: Thu, 28 January 2016, 03:12:13 »
In the "99% of charts inherently mistimed because of bad format and then there's mistimings galore from the engine" trash can.
Offline sth
  • 2 girls 1 cuprubber
« Reply #19 on: Thu, 28 January 2016, 04:34:19 »
i like ergo clears for stepmania. never got a chance to swap in zealios on my cmstorm stepmania board but i would like to at some point. anyone got 4 zealios to donate?
Offline iLLucionist
  • Topre is Love.
« Reply #20 on: Thu, 28 January 2016, 15:31:07 »
Anybody any ideas what kind of switch he is using there? clicky/tactile?
Offline Auxo
  • Formerly CJD_Anthony
« Reply #21 on: Fri, 29 January 2016, 22:00:56 »
Played DDR for like... 10 years previously, I wish I still had the stamina back then. I can barely pass Healing Vision ~Angelic Mix~ without my legs giving out
