Author Topic: So many types of Aluminum..  (Read 4418 times)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Re: So many types of Aluminum..
« Reply #1 on: Wed, 13 January 2016, 15:12:58 »
There are more alloys of aluminum than any other base metal.  Last number I heard was over 11,000.  And that is without taking different tempers into factor.
« Reply #2 on: Wed, 13 January 2016, 15:41:19 »
Gives me a headache cuz I'm just making keycaps in my spare time for fun..
But dang so many...
Offline Melvang
« Reply #3 on: Wed, 13 January 2016, 16:03:50 »
But dang so many...
Just go with 6061 T6.  One of the cheaper alloys, very easy to find, and machines easy.
Offline jerue
  • (Whenever that happens :P)
« Reply #4 on: Wed, 13 January 2016, 16:39:53 »
To me, love all aluminum. Except maybe aluminum foil...wouldn't make for a good keyboard.
Offline Leslieann
« Reply #5 on: Wed, 13 January 2016, 18:07:04 »
That's okay, we need to save it for cookies and pizza.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #6 on: Wed, 13 January 2016, 19:22:13 »
But dang so many...
Yea,  I'm thinkin  6061 as well..  but it seems that it doesn't work as well with bright color anodizing..
Offline Melvang
« Reply #7 on: Wed, 13 January 2016, 19:48:43 »
But dang so many...
That, I have no idea on.  I don't have any experience with different alloys and how they react with different anodizing colors and depths.  I do know a lot of bicycle parts are anodized 6061
« Reply #8 on: Thu, 14 January 2016, 00:17:38 »
"aluminium"
« Reply #9 on: Thu, 14 January 2016, 01:19:35 »
Offline bazh
« Reply #11 on: Thu, 14 January 2016, 05:35:01 »
have you not learnt something from Weird Al?
HHKB Pro2 white
Newbie again
Offline jerue
« Reply #12 on: Thu, 14 January 2016, 09:26:47 »
apparently not :(
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #13 on: Thu, 14 January 2016, 09:50:23 »
Offline Leslieann
« Reply #14 on: Fri, 15 January 2016, 02:50:06 »
Both are right, but if you want to point blame, blame the person who named it (a Brit) and changed it twice (originally it was Alumium), once after it was picked up by dictionaries.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #15 on: Fri, 15 January 2016, 02:58:20 »
i knew it.. british people...
Offline Rotwitt
  • I'm trying to have fun designing keyboards
« Reply #16 on: Mon, 18 January 2016, 14:03:43 »
Did someone say aluminium? Because I love that ****.
If you're having trouble figuring out what the various series contains, and their properties take a look at this table I've just made. :thumb:
New version of document, including tempers further down.
« Last Edit: Tue, 19 January 2016, 08:47:32 by Rotwitt »
« Reply #17 on: Mon, 18 January 2016, 18:30:38 »
which would you recommend for bright color anodizing + easily machinable..  so far i'm thinking 6061 T6
Offline Melvang
« Reply #18 on: Mon, 18 January 2016, 18:43:39 »
That would be my suggestion.  Keep in mind that the 6061 is the composition of the alloy (the actually ingredients in the molten metal mixture) and the T6 is the temper (how hard it is).  If you see a T65, or T651, the 5 and 51 means that there was a mechanical straightening process 51 more so than the 5, after the tempering process.  For 6061 the most common tempers are gong to be T0 (not that common really unless you need it and know where to look) and T3, T6.  For anything keyboard related, I recommend T6.  That is barring odd manufacturing
Offline Rotwitt
« Reply #19 on: Tue, 19 January 2016, 08:45:22 »
Good point. I'll be adding the tempers as a separate table, for easy identification.
Offline Rotwitt
« Reply #20 on: Tue, 19 January 2016, 08:55:24 »
EN AW-6061 T6 is great for machining purposes and fairly good for anodising. Something you should be aware of when choosing this type however is that an iron content larger than 0.2% will produce a matte anodisation finish, rather than a bright one.
